    Need help with stopend switch.
    need help with stopend switch
    536
    • chris4undefined
      chris4
      Have followed this, do you know rotation on x y z stepper motor, maybe also my problem with switch.
      https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#3.3V-compatible_optical_endstop
        A Former User @SIam
        @SIam said in Need help with stopend switch.:
        NC normaly means not conneted you have to use NO & C
        on a switch NC is normally normally closed, and its preferred for limit switches as it would prevent movement if the wire breaks.
          A Former User @chris4
          @chris4 said in Need help with stopend switch.:
          can any of you help me with that.
          maybe post a picture of switch and duet connection?
          • chris4undefined
            chris4
            some pictures , where it appears that the endstop LED is on, but Z Y X is not in the home position, if I press each switch, the endstop LED is off on duet2wifi.
            Should it be so?
            home position OFF, not home location ON!
            • chris4undefined
              chris4
              And the config.g
              code_text
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:46:54 GMT+0100 (centraleuropeisk normaltid)
              M550 P"Anet A8" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P2 S0 ; physical drive 2 goes backwards
              M92 X100.00 Y100.00 Z400.00 E100.00 ; set steps per mm
              M566 X600.00 Y600.00 Z18.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
              M906 X500 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-33 Y-10 Z0 S1 ; set axis minima
              M208 X220 Y220 Z240 S0 ; set axis maxima
              M574 X1 Y1 Z1 S0 ; set active low and disabled endstops
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X20:200 Y20:200 S40 ; define mesh grid
              M305 P0 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 0
              M143 H0 S130 ; set temperature limit for heater 0 to 130C
              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
              M143 H1 S275 ; set temperature limit for heater 1 to 275C
              T0 ; select first tool
              • chris4undefined
                chris4
                Homeall:
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:52:04 GMT+0100 (centraleuropeisk normaltid)
                G1 H2 Z5 F6000          ; lift Z relative to current position
                G1 H1 X-258 Y-235 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000       ; go back a few mm
                G1 H1 X-258 Y-235 F360  ; move slowly to X and Y axis endstops once more (second pass)
                G1 H1 Z-245 F360        ; move Z down stopping at the endstop
                G90                     ; absolute positioning
                G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                ;G91                    ; relative positioning
                ;G1 Z5 F100             ; lift Z relative to current position
                ;G90                    ; absolute positioning
                • chris4undefined
                  chris4
                  ; homex.g
                  ; called to home the X axis
                  ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:55:31 GMT+0100 (centraleuropeisk normaltid)
                  G1 H1 X-258 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H2 X5 F6000    ; go back a few mm
                  G1 H1 X-258 F360  ; move slowly to X axis endstop once more (second pass)
                  G1 H2 Z-5 F6000   ; lower Z again
                  • chris4undefined
                    chris4
                    ; homey.g
                    ; called to home the Y axis
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 10:50:45 GMT+0100 (centraleuropeisk normaltid)
                    G1 H1 Y-235 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                    G1 H2 Y5 F6000    ; go back a few mm
                    G1 H1 Y-235 F360  ; move slowly to Y axis endstop once more (second pass)
                    • chris4undefined
                      chris4
                      ; homez.g
                      ; called to home the Z axis
                      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 11:09:06 GMT+0100 (centraleuropeisk normaltid)
                      G1 H1 Z-245 F1800 ; move Z down until the endstop is triggered
                        I suggest you start by testing the endstop switch and wiring. See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
                        • chris4undefined
                          chris4
                          Have fixed now, by changing the switch to NO and working now.
                          Thanks for the help.
                          But one more question, how can change the speed of Z axis on the way to endstop (low switch) to a slow speed last cm to endstop. The same speed, as on the x and y axis. I have this config.g
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 13:12:07 GMT+0100 (centraleuropeisk normaltid)
                          G90                                     ; send absolute coordinates...
                          M83                                     ; ...but relative extruder moves
                          M550 P"My Printer"                      ; set printer name
                          M569 P3 S0                              ; physical drive 3 goes forwards
                          M584 X0 Y1 Z2 E3                        ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
                          M92 X160.00 Y160.00 Z2560.00 E873.08    ; set steps per mm
                          M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
                          M201 X400.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                          M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
                          M208 X230 Y230 Z240 S0                  ; set axis maxima
                          M574 X1 Y1 Z1 S0                        ; set active high endstops
                          M557 X-18:215 Y5:195 S20                ; define mesh grid
                          M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
                          M143 H0 S120                            ; set temperature limit for heater 0 to 120C
                          M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
                          M143 H1 S280                            ; set temperature limit for heater 1 to 280C
                          M563 P0 D0 H1 F0                        ; define tool 0
                          G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                          G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                          T0
                          and the homez.g
                           homez.g
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Feb 21 2020 13:36:08 GMT+0100 (centraleuropeisk normaltid)
                          Thanks Christian
                            Phaedrux Moderator @chris4
                            It's not possible to slow down before the endstop, because it doesn't know where the endstop is before being homed. Typically homing would be done in two passes. A fast movement to the endstop, followed by a short movement back, and then a slower movement towards the endstop again for better accuracy.
                            • chris4undefined
                              chris4
                              @Phaedrux said in Need help with stopend switch.:
