    Duet 3 Mainboard 6HC - initial production run.
    243
    34.2k
    • Selecta_Motaundefined
      Selecta_Mota @dc42
      @dc42 any news on the toolboard?
      or are you also affected by corona?
        We're not affected by Corona yet. Tool boards are in production and should be listed very soon. Tool distribution boards will follow shortly.
        mundsenundefined 1 Reply Last reply Reply Quote 0
        • mundsenundefined
          mundsen @dc42
          @dc42 Do I need the distribution board if I`m going to use only one Tool Board?
          Does the toolboard include wire terminals for the CAN bus (+ the other not using screw terminals) wires between the ToolBoard and the Duet 3?
            dc42 administrators @mundsen
            @mundsen said in Duet 3 Mainboard 6HC - initial production run.:
            The distribution board is optional. It provides a convenient way of providing individually fused power to up to 4 tool boards, converting the CAN cable from RJ11 to JST ZH (because RJ11 was too big to fit on the tool board), and terminating the CAN cable. Without it, you should provide your own power fuse (e.g. an in-line auto fuse) and terminate the CAN bus with a 120 ohm resistor unless the bus goes on to an expansion board.
            • mundsenundefined
              mundsen
              @dc42 said in Duet 3 Mainboard 6HC - initial production run.:
              distribution
              Any price info on the distribution board?
              I may order ToolBoard + distribution board - so I`m ready for more projects in the future 🙂
                Provisional price for the distribution board is £20 ex tax. This includes connectors, fuses and probably a 0.5m CAN cable. We plan to offer a £10 discount on orders of 4 tool boards + distribution board.
                • mundsenundefined
                  mundsen
                  So then I can install the distribution board at the printer top-right side (A) and the toolboard at the top of the hemera (B) ?
                    droftarts administrators @mundsen
                    @mundsen If you only have one tool, you don't need the distribution board.
                      A Former User @dc42
                      Stop teasing us, take my money and ship I need a Homer picture here.....
                      mundsenundefined 1 Reply Last reply Reply Quote 1
                      • mundsenundefined
                        mundsen @A Former User
                        @CaLviNx Agree - ToolBoard is the missing part on my printer
                        • stefmaundefined
                          stefma @dc42
                          @dc42 Are there any concrete plans on implementing an EtherCAT-master? If yes, until when and do you plan to do an own implementation or use something like https://github.com/OpenEtherCATsociety/SOEM
                          Btw thanks for that great piece of hardware/software!
                          • rjenkinsgbundefined rjenkinsgb referenced this topic
