    Duet 3 Mainboard 6HC - initial production run.
    243
    32.8k
      T3P3Tony administrators @Selecta_Mota
      @Selecta_Mota I expect we will announce the production pre order before Christmas for shipping either end of Jan or beginning of Feb.
      Selecta_Motaundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        @T3P3Tony and now I'm going to have to order one of those too
        • Selecta_Motaundefined
          Selecta_Mota @T3P3Tony
          @T3P3Tony great to hear, thank you 🙂
          • Aurimasundefined
            Aurimas @T3P3Tony
            @T3P3Tony So Duet 3 is out. when is the expansion board coming out for the external stepper drivers? As I understand 3HC board still doesn't support external stepper drivers and/or servos.
            It sounds a bit one step forward two steps back with a loss of the external stepper driver support.
            Australian design and build large scale 3d printers
            https://aurarum.com.au
              A Former User @Aurimas
              @Aurimas said in Duet 3 Mainboard 6HC - initial production run.:
              A somewhat uniformed post that makes no real sense if you look at and understand the road map of what the duet team is preparing they have already given info on when the expansion boards will be available. (pre order is open)
                deckingman @A Former User
                @CaLviNx I think the key words in @Aurimas post were "external stepper drivers".
                  We finalised the tool board design and ordered the PCBs last Friday. We're now working on the single-external-stepper board, which is very simple because it is essentially a cut-down tool board. We are aiming to order the PCBs for them in time to get them before Chinese new year (25 January). We have already tested prototypes made from hacked prototype tool boards.
                    A Former User @deckingman
                    @deckingman said in Duet 3 Mainboard 6HC - initial production run.:
                    Yes I know what he meant. You of all people should well understand that is not the main priority/direction that the duet 3 appears to be travelling at this point in time, but as I already said all info has already been stated, one step at a time
                      Selecta_Mota @dc42
                      @dc42 any news on the toolboard?
                      or are you also affected by corona?
                        We're not affected by Corona yet. Tool boards are in production and should be listed very soon. Tool distribution boards will follow shortly.
                        mundsenundefined 1 Reply Last reply Reply Quote 0
                        • mundsenundefined
                          mundsen @dc42
                          @dc42 Do I need the distribution board if I`m going to use only one Tool Board?
                          Does the toolboard include wire terminals for the CAN bus (+ the other not using screw terminals) wires between the ToolBoard and the Duet 3?
                            dc42 administrators @mundsen
                            @mundsen said in Duet 3 Mainboard 6HC - initial production run.:
                            The distribution board is optional. It provides a convenient way of providing individually fused power to up to 4 tool boards, converting the CAN cable from RJ11 to JST ZH (because RJ11 was too big to fit on the tool board), and terminating the CAN cable. Without it, you should provide your own power fuse (e.g. an in-line auto fuse) and terminate the CAN bus with a 120 ohm resistor unless the bus goes on to an expansion board.
                            • mundsenundefined
                              mundsen
                              @dc42 said in Duet 3 Mainboard 6HC - initial production run.:
                              distribution
                              Any price info on the distribution board?
                              I may order ToolBoard + distribution board - so I`m ready for more projects in the future 🙂
                                Provisional price for the distribution board is £20 ex tax. This includes connectors, fuses and probably a 0.5m CAN cable. We plan to offer a £10 discount on orders of 4 tool boards + distribution board.
                                • mundsenundefined
                                  mundsen
                                  So then I can install the distribution board at the printer top-right side (A) and the toolboard at the top of the hemera (B) ?
                                    droftarts administrators @mundsen
                                    @mundsen If you only have one tool, you don't need the distribution board.
                                      A Former User @dc42
                                      Stop teasing us, take my money and ship I need a Homer picture here.....
                                      mundsenundefined 1 Reply Last reply Reply Quote 1
                                      • mundsenundefined
                                        mundsen @A Former User
                                        @CaLviNx Agree - ToolBoard is the missing part on my printer
                                        • stefmaundefined
                                          stefma @dc42
                                          @dc42 Are there any concrete plans on implementing an EtherCAT-master? If yes, until when and do you plan to do an own implementation or use something like https://github.com/OpenEtherCATsociety/SOEM
                                          Btw thanks for that great piece of hardware/software!
                                          • rjenkinsgbundefined rjenkinsgb referenced this topic
