    Conditional GCode and object model variables
    Gcode meta commands
    32
    66
    7.7k
    • gtj0undefined
      gtj0 @dc42
      @dc42 said in Conditional GCode and object model variables:
      @gtj0 said in Conditional GCode and object model variables:
      I kinda missed this thread but in reading it and the Meta Commands stuff it looks pretty good. Variables are the most important for me since I really want to make changes to things temporarily then set them back to the original value when I'm done.
      Can you give me an example?
      If you need to restore everything to the values in config.g, you can do that by re-running config.g. To restore a subset of values, set those up in a macro that config.g calls.
      I also didn't see this in the discussion ( or I missed it ) but being able to get things set in config.g that aren't already in the object model is something I think we'd need. Kinda like a JSON output of M503 that we can reference in the macro.
      The plan is that everything you can configure (and some things you cannot) will be in the OM. Now that the OM framework is complete, it's mostly a matter of adding entries to tables and a few simple getter functions.
      The one that sprang to mind immediately was defining the mesh grid
      M557 X0:460 Y0:450 S25
      • DaBitundefined
        DaBit
        Should I ask these questions here or in the 3.01beta topic?
        I flashed 3.01 on my Duet2; I want more intelligent heating/cooling in my toolchanges.
        Two things I notice right away:
        • In heat.heaters there is both a sensor number (heat.heaters[x].sensor) and a copy of the sensor value's lastReading (heat.heaters[x].current). That is redundant. And the actual setpoint is missing?
        • There is no information about tools in the object model, right?
        Part of the M409 response:
        "heat": {
              "coldExtrudeTemperature": 160,
              "coldRetractTemperature": 90,
              "heaters": [
                  "current": 16.5,
                  "sensor": 0,
                  "state": "Off"
                  "current": 66.4,
                  "sensor": 1,
                  "state": "Active"
                  "current": 40,
                  "sensor": 2,
                  "state": "Standby"
              "sensors": [
                  "lastReading": 16.5,
                  "name": "",
                  "type": "Thermistor"
                  "lastReading": 66.4,
                  "name": "",
                  "lastReading": 40,
                  "name": "",
                  "lastReading": 29.5,
                  "name": "mcu-temp",
                  "type": "microcontroller embedded temperature sensor"
        Can I also access the response given by M408 P1 somehow?
          dc42 administrators @DaBit
          @DaBit said in Conditional GCode and object model variables:
          Here is good.
          Correct. We could remove the one in the Heater object, but then you would have to write heat.sensors[heat.heaters[n].sensor].lastReading instead of just heat.heaters[n].current. Maybe that's acceptable and I should remove the redundant one.
          I haven't got round to adding it yet.
          Not yet, just the current tool number.
          Yes, see the wiki page about the object model.
          • DaBitundefined
            DaBit
            Duplicating data is not often a good idea so my vote goes to heat.sensors[heat.heaters[n].sensor].lastReading. On the other hand there is a line length limit of 160 characters.
            About accessing the M408 P1 object in Gcode (which at least contains active/standby temps): how? 'echo heaters[0]' does not work.
            Now that I look at the JSON response I see something weird in the M408 P1 response; after executing these G10's with T0 active and T1 in standby:
            G10 P0 S60 R30
            G10 P1 S70 R40
            The M408 P1 response is:
              "status": "I",
              "heaters": [
                18.4,
                60,
                40
              "active": [
                0,
                60,
                0
              "standby": [
                0,
                30,
                40
            Heater 0 is the bed heater, 1 is for T0, 2 is for T1
            The active temperature for heater 2 returns 0 instead of the 70 I would expect.
            (RRF 3.01-beta1+1 (2020-01-15b2), by the way)
              As stated in the wiki page on GCode meta commands, object model expressions in them must evaluate to primitive types, not objects. Try 'echo heat.heaters[0].current'.
              • DaBitundefined
                DaBit
                That refers to the object model as returned by M409. I can access those. M408 does not return a 'heat' sub-object or whatever the official JSON name for nested items is.
                I was just hoping that I could use the values in the JSON object as returned by M408 also. Those contain info about the tools.... 😊
                Nevermind, I will exercise a bit of patience until more is added to the object model.
                • appjawsundefined
                  appjaws
                  Just a few question for @dc42
                  1. Has the object model been updated recently?
                  2. Is it possible to have the fan[].fanPercent included?
                  3. What test can I used to check if a filament is loaded?
                  4. When will we be able to define a variable?
                  Thanks for any help
                  appjaws - Core XYUV Duet Ethernet Duex5
                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                  Ormerod 1-converted to laser engraver, Duet wifi
                  OpenSCAD version 2024.03.18
                  Simplify3D 5.1.2
                  dc42undefined 3 Replies Last reply Reply Quote 0
                    dc42 administrators @appjaws
                    @appjaws said in Conditional GCode and object model variables:
                    Yes, in 3.01-RC2.
                    I will look into it.
                    Currently you would need to define a GP input pin for the filament present switch and then test it.
                    In the 3.02 release.
                      fan[].requestedValue and fan[].actualvalue are already provided.
                        Filament monitors of type 1 and 2 (simple switch) already provided a filamentPresent field in the object model. I have just added the same field for type 4 (rotating magnet + switch) and type 6 (laser + switch).
                        • appjawsundefined
                          appjaws
                          Thanks dc42,
                          The fan entries are failing with "Error: unknown value"
                          I'm I using it correctly?
                          while true
                          if fan[3].actualvalue <0.2
                          M106 P3 Sfan[3].requestedValue+0.1
                          M400
                          echo "LED Red value = " ^ fan[3].actualvalue
                          Where can I print out the latest object models?
                          Simplify3D 5.1.2
                            I'm sorry, it's actualValue with uppercase V.
                            • appjawsundefined
                              appjaws
                              actualValue
                              Sorry but none of these work
                              "Cooling"
                              echo "LED Red value = " ^ fan[0].actualValue
                              "Extruder"
                              echo "LED Red value = " ^ fan[1].actualValue
                              "System"
                              echo "LED Red value = " ^ fan[2].actualValue
                              "LED Red"
                              echo "LED Red value = " ^ fan[3].actualValue
                              "LED Green"
                              echo "LED Red value = " ^ fan[4].actualValue
                              "LED Blue"
                              echo "LED Red value = " ^ fan[5].actualValue
                              Simplify3D 5.1.2
                                I'm sorry again, it's "fans" not "fan".
                                Send M409 K"fans" to see all the fan OM values.
                                • NexxCatundefined
                                  NexxCat
                                  Apologies is this is a stupid question, or I'm overthinking this problem, but currently I run a delta calibration prior to every print. Whilst it's not a big issue normally, if I'm doing one print after another, allowing the nozzle to cool to my probing temperature (130C), probe, and then heat back up, is time wasted. With the release of 3.02 and variable support, would the following be possible for example?
                                  • On startup (in config.g?) assign a variable (say deltaCalibrated) to 0
                                  • After G32 is run, set deltaCalibrated to 1
                                  • If G28 is called, check to see if the calibration has been run, if so override the homing and move to Z-Max instead. If not, act as normal
                                  • If M84 is called, reset deltaCalibrated to 0
                                  This would mean I would only have to run the delta calibration once per power-on under normal circumstances. It wouldn't re-home and mess up the existing Z height, and would only re-calibrate when needed.
                                  Again, apologies if I'm overthinking this, or something like this is already possible, but this has been in the back of my mind since conditional gcode was first talked about 🙂
                                    You can already test whether calibration is run. The results for the most recent calibration are available in the object model, and if the final deviation is reported as zero then calibration has not been run.
                                    NexxCatundefined 1 Reply Last reply Reply Quote 0
                                    • NexxCatundefined
                                      NexxCat @dc42
                                      Sounds like I need to get my config moved over to RRF3 and have a play then! Thanks for all your hard worth with the Duet and firmware @dc42 🙂
                                        Also, if you turn the motors off using M84 then the axes will all be flagged as not homed, and you can test this too.
                                        • Argoundefined
                                          Argo
                                          I think this thread might be the right location for this I guess because it's something I would need 😃
                                          Since I upgraded my Prusa MK3s to a Duet 2 WiFi board I try to enable all the features the Prusa original FW had.
                                          This means:
                                          • automatic loading of filament when there is no filament in the extruder
                                          • PINDA temperature compensation table because the probe Z offset differs depending on the temperature. In my experience this is not linear and the higher the temperature the lower Z = 0 becomes meaning if you calibrate your printer with PLA, ABS will need recalibration as the nozzle will be too low.
                                          My target is to create a config package for others so they can 1:1 swap their board and don't need to tweak much as my config uses all the convenient features, like the filament sensor, with explanation of what needs to change in the config depending of the used extruder or stepper motors (e.g. 0.9/1.8 degree).
                                          1.
                                          Feature to load the filament automatically.
                                          Status: no filament in the extruder, extruder has PLA temperature (210°C)
                                          Behaviour: Putting filament in the extruder triggers the filament sensor which then automatically loads filament.
                                          Problem I had: The firmware only allows me to operate the filament sensor in one direction because the pin is blocked/reserved. Meaning I could only enable auto load or run out detection at once. So I had to split it in two over macros and start gcode.
                                          So here is my (over complicated?) solution right now:
                                          config.g
                                          ; Filament Sensor Port and Loading Feature ON
                                          M950 J1 C"e0stop" ; Input 1 e0 Filament Sensor
                                          M581 P1 T2 S0 R0 ; Filament Sensor P1 triggers Trigger2.g always (R0)
                                          Runout is not working right now. So when the printer is starting up and there is no filament and filament is put into the extruder trigger2.g is called:
                                          trigger2.g:
                                          ; Loading Filament Script
                                          M300 S800 P200
                                          M581 P1 T2 S-1 R0 ; Filament Sensor does not listen anymore (S-1). Autoload is disabled.
                                          M291 P"Please wait while the nozzle is being heated up" R"Loading PLA" T5 ; Display message
                                          T0 ; Activate Hotend
                                          M291 P"Feeding filament Trigger2" R"Loading PLA" T5 ; Display new message
                                          G1 E70 F800 ; Feed 70mm of filament at 800mm/min
                                          G1 E55 F300 ; Feed 50mm of filament at 300mm/min
                                          G4 P1000 ; Wait one second
                                          G1 E-5 F800 ; Retract 3mm of filament at 800mm/min
                                          M400 ; Wait for moves to complete
                                          M292 ; Hide the message
                                          G10 S150 ; Set current tool temperature to 150C
                                          ;G10 S0 ; Turn off the heater again
                                          ; Filament Sensor Port and Runout Feature ON
                                          M581 P1 T2 S-1 R0 ; Filaent Sensor does not listen anymore (S-1). Autoload is disabled.
                                          M950 J1 C"nil" ; Input 1 e0 Filament Sensor
                                          M591 D0 P2 C"e0stop" S1 ; Filament Runout Sensor
                                          After the loading script the sensor is put into mode "runout detection ON"
                                          But what if you turn your printer on and filament is already loaded and you directly start your print? This would mean that there is no runout detection enabled.
                                          My solution right now is putting this into the Start GCODE in the slicer software:
                                          ; Prime Filament Sensor for Runout
                                          M581 P1 T2 S-1 R0 ; Filament Sensor P1 triggers Trigger2.g always (R0)  TRIGGER OFF
                                          And there is a third scenario. What if you want to manually change your your color (filament) mid print?
                                          After unloading the filament the sensor needs to be in mode "autoload" and after the autoloading is complete it has to go back to the mode "runout detection".
                                          So i added this to my filament-change.g macro:
                                          M25
                                          G91 ; Relative Positioning
                                          G1 Z20 F360; Raise Z
                                          G90 ; Absolute Values
                                          G1 X200 Y0 F6000 ; Parking Position
                                          M300 S800 P8000 ; play beep sound
                                          M98 Pejectfilament.g
                                          M400
                                          Called Pejectfilament.g:
                                          M591 D0 P0 C"e0stop" S1 ; Filament Runout Sensor
                                          M950 J1 C"nil"
                                          M291 P"Please wait while the nozzle is being heated up" R"Unloading PLA" T5 ; Display message
                                          M109 S210
                                          M291 P"Retracting filament..." R"Unloading PLA" T5 ; Display another message
                                          G1 E+8 F300 ; Extrude 8mm of filament at 300mm/min
                                          G1 E-45 F800 ; Retract 480mm of filament at 800mm/min
                                          G1 E-15 F900 ; Retract 480mm of filament at 900mm/min
                                          G1 E-25 F900 ; Retract 480mm of filament at 900mm/min
                                          M400 ; Wait for the moves to finish
                                          M292 ; Hide the message again
                                          M300 S800 P200
                                          ; Filament Sensor gets ready for next load
                                          M581 P1 T3 S0 R0 ; Filament Sensor P1 triggers Trigger3.g
                                          At the end trigger3.g:
                                          M300 S800 P200
                                          M291 P"Feeding filament Trigger3" R"Loading PLA" T5 ; Display new message
                                          G1 E-1 F800 ; Retract 1mm of filament at 800mm/min
                                          I know it first seems quite complex but when runout is enabled the port is blocked and can't be used for autoload.
                                          Now I've read about the implementation of if / else statement which could make things quite simpler and also lowers the change of error as there would be no need to put code into the start gcode.
                                          Like so (be aware, I'm no coder! 😳)
                                          Filament Sensor Status = 1 means no filament
                                          func autoload {
                                          func runout_detection {
                                          if Filament_Sensor state changed to "1" {
                                          autoload
                                          } else {
                                          runout_detection
                                          Something like that 🤕
                                          2. PINDA Temperature calibration
                                          The PINDA (v2) has an built in thermistor to use the Prusa FWs temperature compensation table.
                                          RRP FW has has similar feature built in into the G31 command:
                                          G31 P1000 X23 Y5 Z0.995 C0.0010 S20 H2
                                          I've measured the Z trigger height with several temperatures from 20°C, 25°C up to 50°C and saw that the variance was not linear. At first the offset got bigger meaning the nozzle would be too close to the bed and after 40°C the difference were much smaller up to 50°C.
                                          I'm not quite sure how the Prusa FW stores and uses the recorded values when the FW does it's auto temperature PINDA calibration but what would work is if you could use different G31 code lines depending of the temperature of the PINDA thermistor.
                                          My "I'm no coder" mind thinks of the following:
                                          if PINDA_Thermistor <25°C {
                                          else if PINDA_Thermistor >=25° AND PINDA_Thermistor <30° {
                                          G31 P1000 X23 Y5 Z1.005
                                          else if PINDA_Thermistor >=30°C AND PINDA_Thermistor <35° {
                                          G31 P1000 X23 Y5 Z1.020
                                          . and so on...
                                          else {
                                          G31 P1000 X23 Y5 Z2.0 ; safety height
                                          Hope it is clear what I mean 🙂
                                          • o_lampeundefined
                                            o_lampe
                                            I'm just gathering bits and pieces for the TicTacToe-macro.
                                            So I'd like to know if and how I can create an two-dimensional array? (rows and collums)
                                            I would also like to use vectors for the AI calculations? How could I express length and direction in a single variable?
