    printer goes into home mode without printing anything
    526
    • chris4undefined
      chris4
      HI, how to print, I upload files, the one mode, with Cura4.4 connected to duet2wifi printer (duetRRF conection), the other mode, upload files directly through DWC G-code file.
      After that printer BED prepares for heating to 60C, and threat extruder to 200C.
      Then z axis moves up, Y axis forward, X axis in side slightly. After that, the printer goes into home mode without printing anything
      What a mistake i make?
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 13:12:07 GMT+0100 (centraleuropeisk normaltid)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"My Printer"                      ; set printer name
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1                              ; physical drive 0 goes forwards
      M569 P1 S1                              ; physical drive 1 goes forwards
      M569 P2 S0                              ; physical drive 2 goes backwards
      M569 P3 S1                              ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z2560.00 E873.08    ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
      M201 X400.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M208 X-33 Y-10 Z0 S1                    ; set axis minima
      M208 X230 Y230 Z240 S0                  ; set axis maxima
      M574 X1 Y1 Z1 S0                        ; set active high endstops
      M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
      M557 X-18:215 Y5:195 S20                ; define mesh grid
      M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                            ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S280                            ; set temperature limit for heater 1 to 280C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 S"TitanAero" H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0
      M302 ; Report current state
      M302 P1 ; Allow cold extrusion
      M375 ; Load height map                            ; set initial tool 0 active and standby temperatures to 0C
      T0
      Thanks again!
      • SIamundefined
        SIam
        please provide a sliced gcode file With this problem
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • chris4undefined
          chris4
          Hi, here it comes.
          ;FLAVOR:Marlin
          ;TIME:4104
          ;Filament used: 2.36321m
          ;Layer height: 0.1
          ;MINX:54.213
          ;MINY:61.735
          ;MINZ:0.3
          ;MAXX:136.813
          ;MAXY:82.335
          ;MAXZ:40
          ;Generated with Cura_SteamEngine 4.4.0
          M140 S60
          M105
          M190 S60
          M104 S200
          M105
          M109 S200
          M82 ;absolute extrusion mode
          G21 ;metric values
          G90 ;absolute positioning
          M82 ;set extruder to absolute mode
          M107 ;start with the fan off
          G28 X0 Y0 ;move X/Y to min endstops
          G28 Z0 ;move Z to min endstops
          M84 ;steppers off
          M0 S12 ;wait 12 seconds
          M17 ;turn steppers on
          G1 Z10.0 F300 ;move the platform down 10mm
          G92 E0 ;zero the extruded length
          G1 F200 E8 ;extrude 8mm of feed stock
          G92 E0 ;zero the extruded length again
          M0 S5 ;wait 5 seconds
          G1 F9000
          M117 Printing...
          G92 E0
          G92 E0
          G1 F1500 E-6.5
          ;LAYER_COUNT:398
          ;LAYER:0
          M107
          G0 F3600 X56.636 Y63.9 Z0.3
          ;TYPE:SKIRT
          G1 F1500 E0
          G1 F1800 X57.235 Y63.385 E0.03941
          G1 X57.883 Y62.934 E0.0788
          G1 X58.574 Y62.55 E0.11824
          G1 X59.299 Y62.238 E0.15762
          G1 X60.052 Y62.001 E0.197
          G1 X60.826 Y61.842 E0.23642
          G1 X61.611 Y61.761 E0.27579
          G1 X62.01 Y61.751 E0.29571
          G1 X102.01 Y61.735 E2.29131
          G0 F7200 X63.192 Y71.44
          G1 F1800 X63.928 Y70.704 E2363.20115
          G0 F7200 X63.363 Y70.704
          G1 F1800 X63.19 Y70.876 E2363.20521
          ;TIME_ELAPSED:4104.556897
          G1 F1500 E2356.70521
          M140 S0
          M107
          M104 S0 ;extruder heater off
          M140 S0 ;heated bed heater off (if you have it)
          G91 ;relative positioning
          G1 E-1 F300  ;retract the filament a bit before lifting the nozzle, to release some of the pressure
          G1 Z+4 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more
          G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
          G1 Y210 F9000 ;move out to get part off
          M84 ;steppers off
          M104 S0
          ;End of Gcode
          • SIamundefined
            SIam
            @chris4 said in printer goes into home mode without printing anything:
            M84 ;steppers off
            Remove the M84 M0 and the M17 from your startscript
            chris4undefined 1 Reply Last reply Reply Quote 1
            • chris4undefined
              chris4
              @SIam said in printer goes into home mode without printing anything:
              M17
              Yes... Thanks.
              • chris4undefined
                chris4 @SIam
                @SIam
                HI again,
                I have to remove every time M84, M0, M17, after slicing to print, isn't there in CURA that I can do to avoid it?
                  Check your printer profile in cura to see what it uses for start gcode.
                  It also appears that you have your gcode flavor set to marlin, it should be set to reprap.
                  Goto Settings > Printers > Manage printers > Select your printer > click machine settings
                  • chris4undefined
                    chris4
                    Thanks. I change it.
                    • chris4undefined
                      chris4
                      Hi, has changed in CURA but it will be the same.
                      need more changes in CURA to print?
                      ;FLAVOR:RepRap
                      ;TIME:3750
                      ;Filament used: 2.19156m
                      ;Layer height: 0.1
                      ;MINX:87.2
                      ;MINY:80.2
                      ;MINZ:0.3
                      ;MAXX:132.8
                      ;MAXY:139.8
                      ;MAXZ:30.1
                      T0
                      M190 S60
                      M104 S200
                      M109 S200
                      G21 ;metric values
                      M84 ;steppers off
                      G1 F9000
                      M117 Printing...
                      M83 ;relative extrusion mode
                      G1 F1500 E-6.5
                      ;LAYER_COUNT:299
                      ;LAYER:0
                      M107
                      G0 F3600 X89.08 Y82.929 Z0.3
                      ;TYPE:SKIRT
                      G1 F1500 E6.5
                      G1 F1800 X89.623 Y82.356 E0.03938
                      G1 X90.222 Y81.841 E0.03941
                      G1 X90.87 Y81.39 E0.03939
                      G1 X91.561 Y81.006 E0.03944
                      G1 X92.286 Y80.694 E0.03938
                      G1 X93.039 Y80.457 E0.03938
                      G1 X93.813 Y80.298 E0.03942
                      G1 X94.598 Y80.217 E0.03937
                      G1 X94.998 Y80.207 E0.01996
                      G1 X124.998 Y80.2 E1.49671
                      G1 X125.787 Y80.24 E0.03941
                      G1 X126.567 Y80.359 E0.03936
                      G1 X127.332 Y80.557 E0.03942
                      G1 X128.073 Y80.831 E0.03942
                      G1 X128.782 Y81.178 E0.03938
                      G1 X129.452 Y81.595 E0.03937
                        M84 ;steppers off
                        You still haven't changed the start gcode in Cura. It's in the same window as the reprap flavor change in a text box.
                        • chris4undefined
                          chris4
                          @Phaedrux said in printer goes into home mode without printing anything:
                          M84 ;steppers off
                          This changed should be done every time you print, CURA. "Goto Settings> Printers> Manage printers> Select your printer> click machine settings" and change, M84; steppers off
                          M0 S12; wait 12 seconds
                          M17; turn steppers on?
                          OK! excuse me, NOW I get it
                          • botundefined
                            bot
                            Why in the world is Cura defaulting to turning the motors off then on again AFTER homing the axes, and right before printing?
                            *not actually a robot
                              Phaedrux Moderator @bot
                              @bot Maybe it's a marlin thing? Or a profile from someone else?
