M117 Bad Command
Try using double quotes around the message as in
M117 "purging material" -
It is indeed in the simplify 3d Start script:
; Ender 5 Custom Start G-code M80; Turn on Printer M117 Pre-heating Bed M140 S[bed0_temperature] ; Set Heat Bed temperature M190 S[bed0_temperature] ; Wait for Heat Bed temperature M117 Pre-heating extruder M117 Heating extruder M104 S[extruder0_temperature] ; Set Extruder temperature G28 ; Home all axes M117 Auto bed-leveling G29 ; Auto bed-level (BL-Touch) G92 E0 ; Reset Extruder M109 S[extruder0_temperature] ; Wait for Extruder temperature G1 Z1.0 F3000 ; move z up little to prevent scratching of surface G1 X0.1 Y20 Z0.3 F5000.0 ; move to start-line position M117 Purging Material G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line G1 X0.4 Y200.0 Z0.3 F5000.0 ; move to side a little G1 X0.4 Y20 Z0.3 F1500.0 E30 ; draw 2nd line G92 E0 ; reset extruder G1 Z1.0 F1500 ; move z up little to prevent scratching of surface M117 Printing ; End of custom start GCode However, the "Purging Material" lines seems to be the only one that the Duet complains about. Several of the other M117 commands execute just fine.
Just for curiosity sake, put the quotation marks around it and see what happens.
I know it doesn't make sense but humour me, please ! -
Will do. I have a print still running for the rest of the day. I will try that as soon as this one completes.
The only thing I see that makes that line unique is the blank line before it??
Yes, I have noticed that as well. The reason I am asking you to run that line with quotes is because I had a similar issue where some M117 commands without quotes didn't work and then worked fine once quoted. According to DC42, both quoted and unquoted should work (and they do for you) but since I have seen the weirdness before, I think it is worthwhile testing it.
I dunno what happened to me in my formative years, but having a string WITHOUT quotes makes me nervous.
@mitch, please can you post (either here or on a file sharing site such as Dropbox) a GCode file that demonstrates the problem, so that I can try to reproduce the problem and fix it.
I have already tested that your failing M117 line preceded by a blank line works for me.
Will do. I am on travel so it may be a few days but happy to post a file with the issue when I return.
I truncated the file to meet the upload limit but here is the offending file. same error on that same M117 line every print.
I haven't tried with quotes. Pretty confident that would fix it. But I get that it should work both ways and you want to see why is causing the problem. Much appreciated.
thanks
