    Error: short-to-ground on driver 0
    473
    • tobias3333undefined
      tobias3333
      Hi Ian, no problem and thanks for the quick respond.
      The config file is attached and following is the M115 response.
      23:11:43M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-12-13b1
      config.json
      Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @tobias3333
        @tobias3333 said in Error: short-to-ground on driver 0:
        config.json
        Can you post the actual config.g from the sys directory? It's human readable and much easier to understand.
          droftarts administrators @tobias3333
          @tobias3333 Thanks for the info. The config.json is the output from the Firmware Config tool, and tells me a lot, but doesn't show how your machine is set up now. Ideally, we need to see the config.g file. If you can access the Duet through DWC, go to 'System', select 'config.g' from the file list, and copy the text from there into your reply post.
          Edit: @Phaedrux beats me to it, again!
            tobias3333
            Got it:
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Feb 12 2020 19:41:41 GMT+0100 (Mitteleuropäische Normalzeit)
            M550 P"CoreXY" ; set printer name
            M667 S1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P2 S0 ; physical drive 2 goes backwards
            M92 X200.00 Y200.00 Z400.00 E418.00 ; set steps per mm
            M566 X720.00 Y720.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M201 X500.00 Y500.00 Z250.00 E1000.00 ; set accelerations (mm/s^2)
            M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X350 Y350 Z350 S0 ; set axis maxima
            M574 Z0 S0 ; set active low and disabled endstops
            M558 P5 R0.4 H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
            G31 P25 X28.5 Y-5 Z0 ; set Z probe trigger value, offset and trigger height
            M557 X15:285 Y15:285 S20 ; define mesh grid
            M143 H0 S100 ; set temperature limit for heater 0 to 100C
            M143 H1 S260 ; set temperature limit for heater 1 to 260C
            M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              @tobias3333 Your config.g looks pretty standard, and I can't see anything obviously wrong. The X is configured the same as Y, which works. You are running in CoreXY mode, so it might be worth turning this off by commenting out the 'M667 S1 ; select CoreXY mode' with a semicolon ';' then testing the motor movement again. If X doesn't move and Y does, swap the motors and test again. Make sure you turn off power, or you can damage the stepper drivers by disconnecting/connecting motors when the driver is powered up. I think if this doesn't work, it's a damaged/failed/faulty driver chip.
              Let me know to confirm the above. If it's the chip, it's probably a warranty replacement. Sorry for the inconvenience.
                tobias3333
                @droftarts: I just check your suggestion and I have to reply that it is still the same result. On the Y-Side the motor is turning. Switching to the X-Side there is again the fault message with the shorted driver0
                  @tobias3333 okay. Is this a new Duet, or was it previously working? Where did you buy it, and when? If it’s a genuine Duet, bought from Duet3D or one of the resellers, and is within its warranty period, I’m happy to approve a warranty replacement. Contact your supplier, follow their warranty process, and refer them to this thread.
                  If you could post a picture of your Duet, or at least post the information from the sticker on the main processor, that would help identify the manufacturing date and supplier. Thanks!
                  As an aside, the only known causes of short-to-ground error reports are:
                  1. Genuine short (to ground or across the motor)
                  2. Motor phases not connected correctly
                  3. On a Maestro, running in stealthChop mode at high speeds (probably possible with Duet 3 too)
                  4. Failed driver
                  5. Bad SPI signals (especially if ALL drivers report short-to-ground)
                    tobias3333
                    @droftarts: Thanks for the clear statement. The board was bought at the Duet´s suggested German supplier Makerdise.com therefore it should be a genuine board?! I ordered it by the end of September 2019. Due to personel reasons there was no possibility for me to install the board since the last weeks.
                    So the board wasn´t running within the printer already. I started with the step by step guide from the Dozuki site.
                    When heading to the task to check the motors, the failure already appeared.
                    I already contacted the support from Makerdise to solve the issue but since 10 days there is no further feedback on how to go ahead / or initate a replacement.
                    Hopefully they will reply within the next days and give some feedback.
                    Anyway beside the support problems thank you very much for your time and the great support!
                      @tobias3333 no problem, hopefully your warranty replacement will work better!
                      If you could post a picture of your Duet, that would be great.
                      As you’re only using 4 of the 5 drivers, you could remap X to the spare one, while you wait for the replacement. Add this line after the other M569 commands:
                      M569 P4 sS1 ; physical drive 4 goes forwards
                      Change M584 to:
                      M584 X4 Y1 Z2 E3                                   ; set drive mapping
                      and connect X motor to E1 stepper driver.
                        tobias3333
                        @droftarts: The driver re-mapping seems to work for the moment.
                        Replacement is still on-going.
                        Attached a picture of the board as requested
