Tool was not driven
@skayred This is your gcode up to when it's printing the outline around the cube:
G90 M82 M106 S0 M140 S80 ; set bed temp M190 S80 ; wait for bed temp G28 ; home all M104 S60 ; set calibration extruder temp M109 S60 ; wait for extruder temp G32 ; auto-level G29 S0 ; G1 X60 F360 ; keep hotend away from the model M104 S240 ; set extruder temp M109 S240 ; wait for extruder temp ; process Process1-4 ; layer 1, Z = 0.200 T0 G1 E-2.0000 F1800 ; feature outer perimeter ; tool H0.200 W0.500 G1 Z0.200 F1002 G1 X9.750 Y9.750 F3000 G1 E0.0000 F1800 G1 X-9.750 Y9.750 E0.7560 F225 G1 X-9.750 Y-9.750 E1.5120 G1 X9.750 Y-9.750 E2.2680 G1 X9.750 Y9.750 E3.0241 G1 X9.500 Y9.750 E1.0241 F225 G1 X4.750 Y9.750 F225
Looking at your gcode, there's only G32 (which should call bed.g) and G29 (which starts bed mesh), none of which should cause extruder movement. So, going back to config.g, can you try changing the following:
AddM584 X0 Y1 Z2 E3
(to make sure you drives map correctly)
Remove 'U16' fromM350 X16 Y16 Z16 E16 U16 I1
(configuring microstepping for non-existent axis)
Remove ':1' fromM572 D0:1 S0.75
(pressure advance enabled for non-existent extruder drive)
Remove 'U2'M574 X2 Y2 Z2 U2 S1
(endstop for non-existent axis)I'd expect one of the above to be causing the hiccup, but not sure which!
Edit: and what @dc42 said above! Missed that one...
@dc42 hmm, thats quite curious as in both files I commented out 4th tower arm length, seems like calibration uses it, but where it gets that information?
@skayred said in Tool was not driven:
Possibly defining the M350 microsteps would be enough.
@droftarts still no luck, same warnings still there, as well as 4th tower arms length
What's in your bed.g file?
Did you restart after deleting the M665 line in config-override.g?
@skayred Did you reset after changing config.g and override-config.g? Can you post your current versions of both?
Delta parameters in config-override.g should change from:
M665 L209.000:209.000:209.000:110.000 R90.873 H203.217 B100.0 X-0.717 Y-0.982 Z0.000
to
M665 L209.000:209.000:209.000 R90.873 H203.217 B100.0 X-0.717 Y-0.982 Z0.000
(or delete it, as @dc42 suggests)
@dc42 @droftarts I have commented out that line and restarted, but seems like file is regenerated after the calibration. Bed.g:
M561 ; clear any bed transform ; Probe the bed at 3 peripheral and 0 halfway points, and perform 3-factor auto compensation ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g. G30 P0 X0.00 Y70.00 Z-99999 H0 G30 P1 X60.62 Y35.00 Z-99999 H0 G30 P2 X60.62 Y-35.00 Z-99999 H0 G30 P3 X0.00 Y-70.00 Z-99999 H0 G30 P4 X-60.62 Y-35.00 Z-99999 H0 G30 P5 X-60.62 Y35.00 Z-99999 H0 G30 P6 X0.00 Y35.00 Z-99999 H0 G30 P7 X30.31 Y-17.50 Z-99999 H0 G30 P8 X-30.31 Y-17.50 Z-99999 H0 G30 P9 X0 Y0 Z-99999 S8
@skayred So likely something in your config.g is still creating the 4th axis. Please post current config.g.
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2 on Sat Feb 02 2019 19:10:31 GMT+0200 (Eastern European Standard Time) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; M665 L209:209:209:110 R91.5 H203 B100.0 X0 Y0 Z0.000 ; Set delta radius, diagonal rod length, printable radius and homed height M665 L209:209:209 R91.5 H203 B100.0 X0 Y0 Z0.000 M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them ; Network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; M584 X0 Y1 Z2 U4 E3 M584 X0 Y1 Z2 E3 ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes backwards WAS S0 M569 P4 S0 ; M350 X16 Y16 Z16 E16 U16 I1 ; Configure microstepping with interpolation M350 X16 Y16 Z16 E16 I1 ; M92 X400.00 Y400.00 Z400.00 U400.0 E404.545; ; Set steps per mm E was 400 M92 X400.00 Y400.00 Z400.00 E404.545 ; M566 X1000.00 Y1000.00 Z1000.00 U1000 E3000.00 ; Set maximum instantaneous speed changes (mm/min) M566 X1000.00 Y1000.00 Z1000.00 E3000.00 ; M203 X5000.00 Y5000.00 Z5000.00 U5000 E6000.00 ; Set maximum speeds (mm/min) 3000 M203 X5000.00 Y5000.00 Z5000.00 E6000.00 ; M201 X1000.00 Y1000.00 Z1000.00 U1000 E2500.00 ; Set accelerations (mm/s^2) 250 M201 X1000.00 Y1000.00 Z1000.00 E2500.00 ; M906 X2000.00 Y2000.00 Z2000.00 U1000 E2000.00 I60 ; Set motor currents (mA) and motor idle factor in per cent M906 X2000.00 Y2000.00 Z2000.00 E2000.00 I60 M572 D0 S0.75 ; pressure advance M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; Set minimum Z ; M669 X0 Y0 ; FLYING ; Endstops ; M574 X2 Y2 Z2 U2 S1 ; Set active high endstops M574 X2 Y2 Z2 S1 ; Z-Probe M558 P1 H5 I1 R0.4 F300 T6000 ; P1, Set Z probe type to unmodulated and the dive height + speeds G31 Z-0.3 P600 ; Set Z probe trigger value, offset and trigger height M557 R30 S9 ; Define mesh grid ; Heaters ; NEW? B3950 ; OLD B4138 ; E3D V6 thermo B4388 ; M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 M305 P0 B4725 C7.060000e-8 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F2 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Automatic saving after power loss is not enabled ; Custom settings are not configured M557 R70 S10 ; probe within a radius of 25mm from the centre with a mesh spacing of 20mm M579 X1.015892866 Y1.01156531665572173 ; 1.02 ;M915 X Y S40 F0 R2 M501
If you reboot (with the M665 line in config-override.g removed) and then send M665 without parameters, does it report 3 rod lengths or 4?
@dc42 3 length reported in that case.
If you now run auto calibration, does it report 3 or 4 after that?
@dc42 Surprisingly 3 lengths still o_O While config-override is not updated
15:57:53 M665 Diagonals 209.000:209.000:209.000, delta radius 91.146, homed height 203.228, bed radius 100.0, X -0.626°, Y -1.399°, Z 0.000° 15:57:44 G32 Calibrated 8 factors using 10 points, deviation before 0.324 after 0.009 15:57:12 G28 15:56:41 M665 Diagonals 209.000:209.000:209.000, delta radius 91.500, homed height 203.000, bed radius 100.0, X 0.000°, Y 0.000°, Z 0.000°
So does it auto calibrate now without those error messages?
config-override.g will only be updated if you send M500.
@dc42 yes, cold calibration was without warnings, 40C both hotend and bed as well, now I am going to try an actual Gcode
@dc42 yes, it solved also the printing problem. So, in short - if 4th arm is configured, some mechanism prevents the printer from actual printing due to triggering of heater failure
@skayred With the fourth arm configured, it's trying to map a driver to it, and erroneously mapping the extruder. Which generates the warning when it's asked to move as the U axis. I'm a little surprised that it does this, but we should test in the latest firmware versions and see if it still does this, and raise it as a bug if it does. I note you're running RRF 2.04, you should consider updating to the latest RRF 2 version, 2.05.1.
I expect if you'd kept the M584 you originally had, with the U axis defined, it would probably have been okay! Feel free to test...
@droftarts will test for sure but before I need to reprint the carriage Due to heavyweight of Titan with its default stepper, my 'arm' for flying extruder probably tilted LM8UU too much so extruder carriage stopped while effector continued its movement... Yeah, it was loud.
And about bug - pretty easy to reproduce. Set 4th arm in the delta configuration, set some temperature (hotend only should be fine but better both), then run let's say G32. If there is no warning, try some print - in my case it looked like extreme underextrusion or filament clog.
I've fixed it in RRF 3.01-RC3 so that you can only specify as many rod lengths as there are axes. This means that the M584 command to create the additional axes will need to be earlier in config.g than the M665 command.
