    unable to home[xyz] using my homing scripts
    1.1k
    • Danalundefined
      Danal
      Even though it worked before...
      You might add
      M564 H0 ; Allow unhomed axis to move.
      and, of course, turn it off later
      M564 H1
        Phaedrux Moderator @Danal
        @Danal said in unable to home[xyz] using my homing scripts:
        You might add
        M564 H1
        Shouldn't be necessary since he has H2 on his Z moves to allow unhomed movement.
        Danalundefined spllgundefined 2 Replies Last reply Reply Quote 1
        • spllgundefined
          spllg @Phaedrux
          @Phaedrux you're right, there is another m208 in homex.g - commented it out. i know that i should do cleanup and i'm sure i will do that when everything is working.
          yes, i was using homeall.g but as long as home[xyz] are not working i do not care.
          the strange thing is that homing works when i enter the commands into the console one by one which makes me think that there might be a dwc <-> duet timing issue.
          Danalundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • Danalundefined
            Danal @Phaedrux
            @Phaedrux said in unable to home[xyz] using my homing scripts:
            Ah, good point, I missed that.
            • spllgundefined
              spllg @Phaedrux
              @Phaedrux done but did not solve my problem
              homex.g
              M564 H0
              G91 ; relative positioning
              ;M208 X-26 S1 ; set axis minima
              G1 Z5 F6000 H2 ; lift Z relative to current position
              G1 H1 X-355 F3000 ; move quickly to X axis endstop and stop there (first pass)
              G1 X2 F3000 ; go back a few mm
              G1 H1 X-355 F100 ; move slowly to X axis endstop once more (second pass)
              G1 x+26 f3000
              G1 Z-5 F1000 H2 ; lower Z again
              G90 ; absolute positioning
              M564 H1
              btw: i can see that G1 Z5 F6000 H2 is executed
              • Danalundefined
                Danal @spllg
                @spllg said in unable to home[xyz] using my homing scripts:
                the strange ting is that homing works when i enter the commands into th console
                Hmm... then, just for debugging, try that set of commands in a macro (not in sys) and try them in a 'print job'.
                And/or, basic debugging: Shorten the script. Assuming that works, add things back slowly. Minimal is probably something like:
                G90
                spllgundefined 1 Reply Last reply Reply Quote 0
                  Phaedrux Moderator @spllg
                  That's certainly a possibility, which is why it would help to have things cleaned up as much as possible so that we can rule out configuration error.
                  In cases like this it can be helpful to go to the web configurator, input your printer specifics, and generate a fresh set of files to compare against. You can backup your config and try the configurator version. If it works and yours doesn't what is the difference?
                  • spllgundefined
                    spllg @Danal
                    @Danal created the macro.
                    executing
                    M564 H0
                    ;G1 H1 X-355 F100 ; move slowly to X axis endstop once more (second pass)
                    ;G1 x+26 f3000
                    ;G1 Z-5 F1000 H2 ; lower Z again
                    ;G90 ; absolute positioning
                    M564 H1
                    works fine and i can move in x direction after execution. when i uncomment ;G1 H1 X-355 F100 i cannot move in x-direction after execution.
                    oh no, not again this complete configuration process.
                    but why did homing via scrip ever work?
                    • spllgundefined
                      spllg @Phaedrux
                      @Phaedrux
                      changing
                      M201 X1500.00 Y1500.00 Z100.00 E3000.00 ; set accelerations (mm/s^2)
                      (i was advised to try this but forgot about it)
                      to
                      M201 X500.00 Y500.00 Z100.00 E3000.00 ; set accelerations (mm/s^2)
                      did the trick.
                      thanks for your assistance.
                      btw: g- and- m-codes are horrible - the g-m language reminds me on assembler languages of the early 1970's (e.g. honeywell) but i cannot and don't want to remember details.
                        So at 1500 acceleration the motor was stalling preventing the endstop from being hit and thus hanging?
                        • spllgundefined
                          spllg @Phaedrux
                          @Phaedrux looks like - but only for a small feed rate (G1 H1 X-355 F100) and a small distance (2 mm back to end stop) and not if command was executed from the console.
                          i feel this is strange, maybe someone wants to have a look at the code.
                          i do not know if the stepper(s) were/are stalling of if the 'firmware was stalling' - only a reset (hard or soft, power cycling the board was not necessary ) could end the faulty state.
                          • Danalundefined
                            Danal
                            There is a reproducible behavior in RRF3: If a homing move does not end, everything hangs, and it takes a reset to get out of that state. Furthermore, if you have a Pi, both the Duet board and the Pi must be reset.
                            spllgundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • spllgundefined
                              spllg @Danal
                              @Danal in my case it is sufficient to reset the duet - don't have to touch the rpi.
                                dc42 administrators @Danal
                                Firmware version? Does it happen in standalone mode as well as in SBC mode?
                                • spllgundefined
                                  spllg @dc42
                                  • firmware version = 3.01-RC2
                                  • it happens in sdc mode
                                  • never tried standalone mode (although probably is should)
