    unable to home[xyz] using my homing scripts
    1.1k
    • spllgundefined
      spllg @Phaedrux
      @Phaedrux done but did not solve my problem
      homex.g
      M564 H0
      G91 ; relative positioning
      ;M208 X-26 S1 ; set axis minima
      G1 Z5 F6000 H2 ; lift Z relative to current position
      G1 H1 X-355 F3000 ; move quickly to X axis endstop and stop there (first pass)
      G1 X2 F3000 ; go back a few mm
      G1 H1 X-355 F100 ; move slowly to X axis endstop once more (second pass)
      G1 x+26 f3000
      G1 Z-5 F1000 H2 ; lower Z again
      G90 ; absolute positioning
      M564 H1
      btw: i can see that G1 Z5 F6000 H2 is executed
      • Danalundefined
        Danal @spllg
        @spllg said in unable to home[xyz] using my homing scripts:
        the strange ting is that homing works when i enter the commands into th console
        Hmm... then, just for debugging, try that set of commands in a macro (not in sys) and try them in a 'print job'.
        And/or, basic debugging: Shorten the script. Assuming that works, add things back slowly. Minimal is probably something like:
        G90
        spllgundefined 1 Reply Last reply Reply Quote 0
          Phaedrux Moderator @spllg
          which makes me think that there might be a dwc <-> duet timing issue
          That's certainly a possibility, which is why it would help to have things cleaned up as much as possible so that we can rule out configuration error.
          In cases like this it can be helpful to go to the web configurator, input your printer specifics, and generate a fresh set of files to compare against. You can backup your config and try the configurator version. If it works and yours doesn't what is the difference?
          • spllgundefined
            spllg @Danal
            @Danal created the macro.
            executing
            M564 H0
            ;G1 H1 X-355 F100 ; move slowly to X axis endstop once more (second pass)
            ;G1 x+26 f3000
            ;G1 Z-5 F1000 H2 ; lower Z again
            ;G90 ; absolute positioning
            M564 H1
            works fine and i can move in x direction after execution. when i uncomment ;G1 H1 X-355 F100 i cannot move in x-direction after execution.
            oh no, not again this complete configuration process.
            but why did homing via scrip ever work?
            • spllgundefined
              spllg @Phaedrux
              @Phaedrux
              changing
              M201 X1500.00 Y1500.00 Z100.00 E3000.00 ; set accelerations (mm/s^2)
              (i was advised to try this but forgot about it)
              to
              M201 X500.00 Y500.00 Z100.00 E3000.00 ; set accelerations (mm/s^2)
              did the trick.
              thanks for your assistance.
              btw: g- and- m-codes are horrible - the g-m language reminds me on assembler languages of the early 1970's (e.g. honeywell) but i cannot and don't want to remember details.
                So at 1500 acceleration the motor was stalling preventing the endstop from being hit and thus hanging?
                • spllgundefined
                  spllg @Phaedrux
                  @Phaedrux looks like - but only for a small feed rate (G1 H1 X-355 F100) and a small distance (2 mm back to end stop) and not if command was executed from the console.
                  i feel this is strange, maybe someone wants to have a look at the code.
                  i do not know if the stepper(s) were/are stalling of if the 'firmware was stalling' - only a reset (hard or soft, power cycling the board was not necessary ) could end the faulty state.
                  • Danalundefined
                    Danal
                    There is a reproducible behavior in RRF3: If a homing move does not end, everything hangs, and it takes a reset to get out of that state. Furthermore, if you have a Pi, both the Duet board and the Pi must be reset.
                    spllgundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • spllgundefined
                      spllg @Danal
                      @Danal in my case it is sufficient to reset the duet - don't have to touch the rpi.
                        dc42 administrators @Danal
                        @Danal said in unable to home[xyz] using my homing scripts:
                        Firmware version? Does it happen in standalone mode as well as in SBC mode?
                        • spllgundefined
                          spllg @dc42
                          • firmware version = 3.01-RC2
                          • it happens in sdc mode
                          • never tried standalone mode (although probably is should)
