    Anycubic Predator printing skews in Y direction
    Example setups and prints
    • CoolioXundefined
      CoolioX
      Greetings --
      Recently, my Predator was having issues where it would automatically zero out at a higher position that it should have. As a result, I attempted many things (physical tightening of belts and software autocalibration) to try and get the printer to resolve. Thanks to this forum, I got the height issue resolved, but NOW I have issues where printing a simple XYZ calibration cube finishes in some messed up ways.
      To demonstrate this, I printed out a series of calibration cubes around the print bed. I've labeled them in the photo 2.1 - 2.7.
      First how I positioned them on the bed:
      Then, in a row:
      They all seem to have some skew in the Y-direction.
      Additionally, here's a photo of my height map (which seems extremely irregular)
      Also attached, are my config, config-override and bed files:
      bed.g
      config.g
      config-override.g
      Any advice will be graciously accepted. Thanks so much!
      Thanks in advance!
        droftarts administrators @CoolioX
        @CoolioX I’m sure you’re already familiar with the Duet delta calibration page, but can’t hurt to go through it again: https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        I also found this page useful for understanding what the bed mesh was trying to tell me: http://boim.com/DeltaUtil/CalDoc/Calibration.html
        • CoolioXundefined
          CoolioX
          @droftarts -- Thanks -- I have gone through "Calibrating a Delta Printer" many times previously. I should point out that at some point, my Predator WAS working with the Duet board, so I'm still trying to work out if it's a mechanical or software issue. I'll check the second link. Much appreciated!
            jay_s_uk
            @CoolioX
            I'm guessing its more than likely mechanical.
            I run a duet board in my predator without issue. In fact, looking at your config, you're running my version anyway.
            I've recently had to change a few mini wheels on one of the axis due to poor quality bearings. I have also had a belt snap. I would suggest removing a tower/axis at a time and stripping it to parts and inspecting.
            CoolioXundefined 1 Reply Last reply Reply Quote 1
            • CoolioXundefined
              CoolioX @jay_s_uk
              @jay_s_uk -- and thank YOU for your repo! It was a great help to getting me started!
              • CoolioXundefined
                CoolioX
                Thanks to everyone for their help and suggestions! Turns out it WAS totally a mechanical issue. There was a grub screw that fell out of the stepper motor pulley on the back motor. Here are the results after adjusting!
                Original in Purple, new in BLUE:
                  jay_s_uk
                  Glad you got it sorted
