failed to parse major T-code number (he)
Duet Web Control
532
    In that case you can pop out the SD card, and replace the contents of /www with the contents of the 2.0.7 zip file.
      Also, what firmware version exactly are you using? Send M115 to check.
        Government_Bacon
        i am using a SBC
          I think you're going to need to do some updating of your versions.
          Can you delete the offending file in the meantime?
          undefined 1 Reply Last reply 1 Mar 2020, 05:55 Reply Quote 0
            Government_Bacon
            got the dwc updated will update the firmware now
              Government_Bacon @Phaedrux
              @Phaedrux ok updated the firmware and the web-controller and i am getting the same errorCapture5.PNG
                Can you post that gcode file please?
                  Government_Bacon
                  BLtouch Support Volcano v2.gcode
                    I notice two things about the file.
                    1 it looks like you're using T1 instead of T0 as your first tool.
                    G90
                    M82
                    M106 S0
                    M104 S210 T1
                    M109 S210 T1
                    G28
                    G29 S1
                    ; process Process1
                    ; layer 1, Z = 0.180
                    T1
                    2 at the end of the file there is a section with some text that isn't commented out.
                    ; layer end
                    M104 S0 ;extruder heater off
                    G91 ;relative positioning
                    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle
                    to release some of the pressure
                    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
                    G28 X0 Y450 ;move X to min endstops and Y max to bring to front
                    so the head is out of the way
                    M84 ;steppers off
                    G90 ;absolute positioning
                    Possibly your endgcode. It might be choking on that when it's being scanned.
                    undefined 1 Reply Last reply 1 Mar 2020, 06:07 Reply Quote 0
                      @Phaedrux it is the ending gcode i got rid of it and it is fine now
                      13 out of 13
