failed to parse major T-code number (he)
Duet Web Control
532
    Government_Bacon
    started up my printer and now have this Capture.PNG using duet 3 dwc V 2.0.4
    undefined 1 Reply Last reply 1 Mar 2020, 04:41 Reply Quote 0
      Phaedrux Moderator @Government_Bacon
      @Government_Bacon said in failed to parse major T-code number (he):
      duet 3 dwc V 2.0.4
      Update to DWC 2.0.7 and see if that makes a difference.
      undefined 1 Reply Last reply 1 Mar 2020, 04:44 Reply Quote 0
        Government_Bacon @Phaedrux
        @Phaedrux im trying to but having trouble doing that i uploaded the new files but cant get them to install
          In that case you can pop out the SD card, and replace the contents of /www with the contents of the 2.0.7 zip file.
            Also, what firmware version exactly are you using? Send M115 to check.
              Government_Bacon
              i am using a SBC
                I think you're going to need to do some updating of your versions.
                Can you delete the offending file in the meantime?
                undefined 1 Reply Last reply 1 Mar 2020, 05:55 Reply Quote 0
                  Government_Bacon
                  got the dwc updated will update the firmware now
                    @Phaedrux ok updated the firmware and the web-controller and i am getting the same errorCapture5.PNG
                      Can you post that gcode file please?
                        Government_Bacon
                        BLtouch Support Volcano v2.gcode
                          I notice two things about the file.
                          1 it looks like you're using T1 instead of T0 as your first tool.
                          G90
                          M82
                          M106 S0
                          M104 S210 T1
                          M109 S210 T1
                          G28
                          G29 S1
                          ; process Process1
                          ; layer 1, Z = 0.180
                          T1
                          2 at the end of the file there is a section with some text that isn't commented out.
                          ; layer end
                          M104 S0 ;extruder heater off
                          G91 ;relative positioning
                          G1 E-1 F300 ;retract the filament a bit before lifting the nozzle
                          to release some of the pressure
                          G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
                          G28 X0 Y450 ;move X to min endstops and Y max to bring to front
                          so the head is out of the way
                          M84 ;steppers off
                          G90 ;absolute positioning
                          Possibly your endgcode. It might be choking on that when it's being scanned.
                          undefined 1 Reply Last reply 1 Mar 2020, 06:07 Reply Quote 0
                            @Phaedrux it is the ending gcode i got rid of it and it is fine now
                            6 out of 13
