    Simplify 3D configuration
    Third-party software
    1.4k
    • appjawsundefined
      appjaws @arhi
      @arhi What's the advantage of running directly from S3D?
      I have macros to start up, bed levelling, auto set trigger height, shut down, LED control etc.
      My print files are on my computer and SD card so I can print without needing to switch on my computer and control the printer remotely via my phone.
      This is my S3D start script
      M98 P"0:/macros/Set LED Red"
      if !move.axes[0].homed || !move.axes[1].homed
      G28
      G28 Z
      M98 P"0:/macros/Conditional/Auto_Bed_Levelling"
      M98 P"0:/macros/Auto Nozzle Cleaning"
      T0
      M98 P"0:/macros/Set LED Blue"
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      • arhiundefined
        arhi @appjaws
        @appjaws said in Simplify 3D configuration:
        You do not have to get the SD card out of the Duet, plug into PC, safe files, eject, get out of PC and put into duet again. For me personally that's tedious, the card is miniature, I dropped it many times, getting it out of duet is complicated as sd card port is not easily accessible. The SD card port on Duet is maybe high quality but that's mechanical device click/clacking it non stop etc etc etc.. So if I can avoid all that I surely would. Not to mention, for e.g. "today" my printers and my computers are in the same room, in 7 months that will, if all goes by plan, not be so. In that case it would be order of magnitude worse to go get card, from printer and get it back to printer.
        How does that link to the question, I don't get it. Or you are talking about startup script you configure in S3D for your printer?
        You have to generate the files on your computer so it has to be on when you generate them. For that CURL script to work you have to save the gcode. So what you do is you save the gcode locally and postprocessing script uploads it to your printer, so again, you have gcode file saved locally and uploaded to your printer, you don't have to move SD card around and do anything by hand. You can turn off your computer and start / control print via phone. Everything exactly the same except you did not need to remove ths SD card twice for every code :).
        That is the benefit. The downside is that the script can't handle files that start with digit and can't handle file name that has spaces, so when you save file you should name it accordingly. It can probably be easily fixed only I don't myself put spaces into file names so I have not tried.
        Danalundefined appjawsundefined 2 Replies Last reply Reply Quote 1
        • Danalundefined
          Danal @arhi
          @arhi said in Simplify 3D configuration:
          You do not have to get the SD card out of the Duet, plug into PC, safe files...
          YIKES! No, don't do that. You should almost never have to touch the card in a Duet. I have about five of them that I haven't touched in literally years. Through firmware upgrades, thousands of print jobs, etc.
          Any slicer. Save the file. Open Duet Web Console (DWC) in a browser. Jobs tab. Upload the file. Print it. Rinse, repeat. A few seconds, a few clicks, no card manipulation.
          Or, automate. Several slicers have plugins to do the upload and start print step automatically. Or use the curl script, it basically does what those plugins do... and looks great! Saves a few clicks.
          But to be clear, for others reading this thread: Almost never any need to move the card around like icky old Marlin printers.
          • Danalundefined
            Danal
            But I think your real question is the BLtouch. A properly configured Duet will make the BLt work with no special G-Codes from your slicer. It "just works" as various homing and probing occur.
            Please post your config.g, homez.g, and bed.g. And your deployprobe.g and retractprobe.g. All of those are in /sys (none in /macros)
            arhiundefined 1 Reply Last reply Reply Quote 1
            • arhiundefined
              arhi @Danal
              @Danal said in Simplify 3D configuration:
              well you do need "some" startup stuff... S3D won't even add homing if you don't add it to start script 😄
              • Weevilundefined
                Weevil
                I think the issue starts with the homeall script. I am no expert on this coding stuff but it looks like there;s no command to operate the BLTouch:
                ; homeall.g
                ; called to home all axes
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
                G91 ; relative positioning
                G1 H1 X305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                G1 H1 X305 ; home X axis
                G1 H1 Y-305 ; home Y axis
                G1 X-5 Y5 F6000 ; go back a few mm
                G1 H1 X305 F360 ; move slowly to X axis endstop once more (second pass)
                G1 H1 Y-305 ; then move slowly to Y axis endstop
                G1 H1 Z-505 F360 ; move Z down stopping at the endstop
                G90 ; absolute positioning
                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                ;G91 ; relative positioning
                ;G90 ; absolute positioning
                  Phaedrux Moderator @Weevil
                  @Weevil said in Simplify 3D configuration:
                  You are correct. You have it setup as if you were using an endstop instead of a probe.
                  You need to replace those lines with something like this:
                  G1 X150 Y150 ; move probe to the center of the bed
                  G30 ; use the probe to find Z0
                  G1 X0 Y0 Z5 ; return to parked position
                  Weevilundefined 1 Reply Last reply Reply Quote 0
                  • appjawsundefined
                    appjaws @arhi
                    @arhi I never remove the SD card, just use DWC to load files, print them and update the system firmware etc.
                    That was my script for the startup is S3, you will notice that it checks if the machine has been homed, if not it carries out a home procedure..
                    Simplify3D 5.1.2
                    • Danalundefined
                      Danal
                      G30 works MUCH better for a BLt. Here's my homez, and deploy/retract files. These "just work", including probing for 3-motor bed tramming, mesh probing, etc.
                      My /sys/homez.g:
                      ; Home Z Axis
                      G90 G1 X150 Y150 F10000   ; Move to the center of the bed
                      M558 F500                ; Set the probing speed
                      G30
                      M558 F50                 ; Set a slower probing speed
                      G30
                      my /sys/deployprobe.g:
                      M280 P0 S10
                      And /sys/retractprobe.g:
                      M280 P0 S90
                      /sys/bed.g
                      G0     X152.5 Y50 H1 F10000
                      G30 P0 X152.5 Y50 Z-99999       ; probe near back leadscrew
                      G0     X265   Y260 H1 F10000
                      G30 P1 X265   Y260 Z-99999      ; probe near front left leadscrew
                      G0     X0     Y315 H1 F10000
                      G30 P2 X0     Y315 Z-99999 S3   ; probe near front right leadscrew and calibrate 3 motors
                      G1     X150   Y150 F10000
                      • Weevilundefined
                        Weevil @Phaedrux
                        @Phaedrux I tried your suggestion. It almost works. It is assuming the endstops are on the other end of the rail and rattles off before I hit emergency stop.
                        This is the code I have for homex which works:
                        G1 H1 X305 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 X-5 F6000 ; go back a few mm
                        G1 H2 Z-5 F6000 ; lower Z again
                        Here's the code for homey which works:
                        G1 H1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                        G1 Y5 F6000 ; go back a few mm
                        G1 H1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
                        And here's the working code for homez:
                        G30
                        G30
                        Just to make sure here, when a send a file to print per the file created by S3D, the extruder is sent to coordinates 0,0,0 which I perceive as homeall. The homez code I have centers the head (150,150,0). Does this matter when starting a print?
                          You can add another G1 X Y move after the last G30 to move the head wherever you want to park it, as I showed in my example. Once the print starts, it will move to wherever it needs to go to print, regardless of where the print head is when it starts.
                          I don't understand what you mean. What did you try and what did it do?
                          It may be time to post your config.g and homing files along with a description of your printer, where the endstops are, etc, and maybe even a picture.
                          Weevilundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                          • Weevilundefined
                            Weevil @Phaedrux
                            @Phaedrux The head is moving to the end that does not have the end stop. Then it rattles away until I do an emergency stop. MY homex and homey codes work just fine. It's the homeall that is causing the issue.
                              Phaedrux Moderator @Phaedrux
                              @Phaedrux said in Simplify 3D configuration:
                              • Weevilundefined
                                Weevil
                                Problem solved. The whole issue was in the location of the end stops. It is now working. Thanks everyone!
