    Simplify 3D configuration
    Third-party software
    1.3k
    • arhiundefined
      arhi @Danal
      @Danal said in Simplify 3D configuration:
      A properly configured Duet will make the BLt work with no special G-Codes from your slicer.
      well you do need "some" startup stuff... S3D won't even add homing if you don't add it to start script 😄
      • Weevilundefined
        Weevil
        I think the issue starts with the homeall script. I am no expert on this coding stuff but it looks like there;s no command to operate the BLTouch:
        ; homeall.g
        ; called to home all axes
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
        G91 ; relative positioning
        G1 H1 X305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X305 ; home X axis
        G1 H1 Y-305 ; home Y axis
        G1 X-5 Y5 F6000 ; go back a few mm
        G1 H1 X305 F360 ; move slowly to X axis endstop once more (second pass)
        G1 H1 Y-305 ; then move slowly to Y axis endstop
        G1 H1 Z-505 F360 ; move Z down stopping at the endstop
        G90 ; absolute positioning
        G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
        ;G91 ; relative positioning
        ;G90 ; absolute positioning
          Phaedrux Moderator @Weevil
          @Weevil said in Simplify 3D configuration:
          You are correct. You have it setup as if you were using an endstop instead of a probe.
          You need to replace those lines with something like this:
          G1 X150 Y150 ; move probe to the center of the bed
          G30 ; use the probe to find Z0
          G1 X0 Y0 Z5 ; return to parked position
          Weevilundefined 1 Reply Last reply Reply Quote 0
          • appjawsundefined
            appjaws @arhi
            @arhi I never remove the SD card, just use DWC to load files, print them and update the system firmware etc.
            That was my script for the startup is S3, you will notice that it checks if the machine has been homed, if not it carries out a home procedure..
            appjaws - Core XYUV Duet Ethernet Duex5
            firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
            Ormerod 1-converted to laser engraver, Duet wifi
            OpenSCAD version 2024.03.18
            Simplify3D 5.1.2
            • Danalundefined
              Danal
              G30 works MUCH better for a BLt. Here's my homez, and deploy/retract files. These "just work", including probing for 3-motor bed tramming, mesh probing, etc.
              My /sys/homez.g:
              ; Home Z Axis
              G90 G1 X150 Y150 F10000   ; Move to the center of the bed
              M558 F500                ; Set the probing speed
              G30
              M558 F50                 ; Set a slower probing speed
              G30
              my /sys/deployprobe.g:
              M280 P0 S10
              And /sys/retractprobe.g:
              M280 P0 S90
              /sys/bed.g
              G0     X152.5 Y50 H1 F10000
              G30 P0 X152.5 Y50 Z-99999       ; probe near back leadscrew
              G0     X265   Y260 H1 F10000
              G30 P1 X265   Y260 Z-99999      ; probe near front left leadscrew
              G0     X0     Y315 H1 F10000
              G30 P2 X0     Y315 Z-99999 S3   ; probe near front right leadscrew and calibrate 3 motors
              G1     X150   Y150 F10000
              • Weevilundefined
                Weevil @Phaedrux
                @Phaedrux I tried your suggestion. It almost works. It is assuming the endstops are on the other end of the rail and rattles off before I hit emergency stop.
                This is the code I have for homex which works:
                G1 H1 X305 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 X-5 F6000 ; go back a few mm
                G1 H2 Z-5 F6000 ; lower Z again
                Here's the code for homey which works:
                G1 H1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G1 Y5 F6000 ; go back a few mm
                G1 H1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
                And here's the working code for homez:
                G30
                G30
                Just to make sure here, when a send a file to print per the file created by S3D, the extruder is sent to coordinates 0,0,0 which I perceive as homeall. The homez code I have centers the head (150,150,0). Does this matter when starting a print?
                  You can add another G1 X Y move after the last G30 to move the head wherever you want to park it, as I showed in my example. Once the print starts, it will move to wherever it needs to go to print, regardless of where the print head is when it starts.
                  I don't understand what you mean. What did you try and what did it do?
                  It may be time to post your config.g and homing files along with a description of your printer, where the endstops are, etc, and maybe even a picture.
                  Weevilundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                  • Weevilundefined
                    Weevil @Phaedrux
                    @Phaedrux The head is moving to the end that does not have the end stop. Then it rattles away until I do an emergency stop. MY homex and homey codes work just fine. It's the homeall that is causing the issue.
                      Phaedrux Moderator @Phaedrux
                      @Phaedrux said in Simplify 3D configuration:
                      • Weevilundefined
                        Weevil
                        Problem solved. The whole issue was in the location of the end stops. It is now working. Thanks everyone!
