    Remounting my print bed
    3D Printing General Chat
    1.1k
    • Danalundefined
      Danal
      At this time, PaneDue support is somewhat limited if you also have a Pi. A different tradeoff: A Pi is the only way to do WiFi (stand alone is wired Ethernet only).
      It is a tough call... and I realize a lot of people really like their Panel. For me, it is Pi all the way. Way, way, too many things that Pi can do...
      For example, I'm developing scripts that auto-align a multi tool printer. Requires the Pi. https://github.com/DanalEstes/DuetPython And a general interface to allow almost anything to be done in Python on the Pi. https://github.com/DanalEstes/PythonDSF (DSF = Duet Software Framework)
      • TLeTourneauundefined
        TLeTourneau
        Well, for cost savings I ordered a Duex 5 to use with my existing Duet. I'm going with the 3 T12x2 lead screws, now I'm just trying to figure out how to mount the bed. I think I see what you're saying about mounting the bed using U channel, I may be able to mount the bed to some small pieces of 2020 too. The ball screws I have seem to slide on that surface alright. I''l have to see what I can figure out, all of the parts will be here in a few days. I also ordered a Hemera and a Wham Bam magnetic print system to try out.
        Thanks,
        Tom
        TronXY X5S-500 (CoerXY)
        Duet 2 Ethernet v1.04
        Firmware Version: 2.02(RTOS) (2018-12-24b1)
        Web Interface Version: 1.22.6
        7" PanelDue
        E3D V6 Clone
        MOSFET's for hot end
        1000w Keenovo with SSR for heat bed
        dc42 Mini IR Sensor or BLTouch
          TLeTourneau
          Strange question but what c channel size would you guys recommend for the ball head screws? It looks like the most common would be 5/16" (8mm) which is actually 8.7mm across internally or 1/4" (6mm)? The ball head measures 8.7mm across so I am leaning towards the 5/16" but I thought I'd see advice first.
          Thanks in advance!
          Thanks,
          Tom
          7" PanelDue
          E3D V6 Clone
          • mrehorstdmdundefined
            mrehorstdmd
            How are you planning to implement the kinematic mount? Will the channel be on the bed plate or on the support(s)?
            Are you making a Maxwell or Kelvin type?
            I saw someone's design that put the spherical head screws in the bed plate and put the slot for the pitch adjuster on the lifter attached to the guide rail bearing block. The slot was made from two pieces of round steel mounted in a printed plastic block. They were lifting the bed with 3 screws and using auto tramming.
            TLeTourneauundefined Danalundefined 2 Replies Last reply Reply Quote 1
              TLeTourneau @mrehorstdmd
              @mrehorstdmd said in Remounting my print bed:
              I'm had attempted to implement and am shooting for a Kelvin type tetrahedron-vee-flat. I was not able to machine a smooth channel/groove for the two constraint point in my build plate and am wondering if affixing a c channel to the bottom of my build plate for the two constraint point will alleviate that issue. I plan on using that in conjunction with triple Z auto bed leveling.
              Thanks,
              Tom
              7" PanelDue
              E3D V6 Clone
                mrehorstdmd @TLeTourneau
                @TLeTourneau Do you have a drawing or CAD model of it?
                How will you mount a heater on the bed plate if there's a U channel there?
                  TLeTourneau
                  The heater is inset 25mm from the edge of the bed on all sides.
                  This is the front which is the single constraint:
                  This is the right rear which is the triple constraint:
                  This is the left rear which is the double constraint and the one I had the problem with creating a smooth channel. I'm hoping that mounting an U channel here will help with the issue.
                  Thanks,
                  Tom
                  7" PanelDue
                  E3D V6 Clone
                    @TLeTourneau OK, so the right rear screw is the reference, the left rear is the pitch adjuster and the front center is the roll adjuster. I see springs on all 3 screws. I assume they are there to keep the screw upright because they fit loosely in their holes. That means the entire bed plate is standing on 3 wobbly screws. That isn't going to be good for print quality.
                    You really want the screws to be threaded into something that will hold them tightly and prevent wobble while still allowing them to be turned for adjustment purposes. I used PTFE blocks for that. The blocks can be screwed down tightly, and using slightly undersized holes for the leveling screws will allow them to roll their threads into the PTFE. The leveling screws won't wobble, and that means the bed won't wobble. PTFE is good for this because it won't melt, no matter how hot you run the bed, and the screws can be turned easily. Nylon won't work because the friction is so high you won't be able to turn the leveling screws (I tried). There's a reason they use nylon in nylock nuts! You can find a small, inexpensive PTFE bar or block on ebay if you shop carefully and compare the price/weight of the different offerings.
                    This is how I mounted the screws in UMMD:
                    A single t-nut and screw hold the PTFE block on the t-slot, and the leveling screw threads into the PTFE. The PTFE blocks have antirotation tangs on the bottom that fit into the t-slot. If you can't cut tangs into the blocks, just mount them using 2 screws and t-nuts.
                    Cutting a short slot in the edge of the plate can provide the needed constraint at the pitch screw. Otherwise a short piece of C channel screwed to the bottom of the bed plate should work OK. The bed plate is only going to expand 0.5 mm or so, so you don't need a long slot for the leveling screw head to sit inside.
                    TLeTourneauundefined 2 Replies Last reply Reply Quote 1
                      PTFE bar or block
                      Yeah, I tried finding some when I built it out the first time and struck out. I'm going to give it another try. I really appreciate the responses!
                      Thanks,
                      Tom
                      7" PanelDue
                      E3D V6 Clone
                        Do you think derlin would work? My brother can get derlin in the sizes that would work.
                        Thanks,
                        Tom
                        7" PanelDue
                        E3D V6 Clone
                        • Danalundefined
                          Danal @mrehorstdmd
                          Jubilee does this. Works very well.
                          • Danalundefined
                            Danal
                            mrehorstdmdundefined TLeTourneauundefined 2 Replies Last reply Reply Quote 1
                              mrehorstdmd @Danal
                              @Danal That's the one!
                                TLeTourneau @Danal
                                @Danal
                                That is very nice, now I wish I had thought to have tabs machined into my build plate! 🙂 Looking at that design I'm wondering if I'll need the 12mm linear rods. I'm going to have 3 T12x2 lead screws, 2 on the outside edges of the build plate on one side and one in the center on the other side. The build plate is attached to a relatively solid frame mode of 2020 and aluminum bar shown in the first and thirteenth posts. The aluminum bar is being replaced with a 3/8"x1-1/2" piece of 6061-T6511 aluminum bar to minimize flex.
                                Thanks,
                                Tom
                                7" PanelDue
                                E3D V6 Clone
                                  @TLeTourneau It's just aluminum. You can cut it with many types of saws, including a hack saw. Machining is not required...
                                  TLeTourneauundefined 1 Reply Last reply Reply Quote 0
                                    @mrehorstdmd
                                    Yeah but I don't want to make my print bed smaller. 😀
                                    Thanks,
                                    Tom
                                    7" PanelDue
                                    E3D V6 Clone
                                      TLeTourneau
                                      I learned something this weekend, I'm not a machinist! 😆 Although I gave it a valiant effort I wasn't able to create the new side support bars for my bed out of the 1.5" x 3/8" 6061-T6511 aluminum bar. Although I had a vice on my drill press I was not able to get the holes for the lead screws and guide rods centered and square to each other on the bars. I've contacted a local machine shop and they should have them made for me in a week or two. I may put a small milling or CNC machine on my wish list for the future.
                                      Thanks,
                                      Tom
                                      7" PanelDue
                                      E3D V6 Clone
