    Bad Benchy Bottom
    1.2k
    • SIamundefined
      SIam
      hi,
      i would say your printig temperature is to hight and/or your component cooling is to low, which material on which temperatur you try to print?
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • wannathermalundefined
        wannathermal
        Slam
        Thanks for the quick response. I have found my problem, my Z axis threaded rods have some bad threads. I will replace them and move on!
        Corexyundefined 1 Reply Last reply Reply Quote 0
        • Corexyundefined
          Corexy @wannathermal
          @wannathermal said in Bad Benchy Bottom:
          Slam
          What sort of rods are they?
          That may be an issue, but there's likely some temp and extrusion issues in play here too. I'd really have a close look at your extruder esteps and extrusion multiplier as well.
          • supernovaeundefined
            supernovae
            I have this same issue in Cura with benchy...
            this one is more pronounced than others i did, but the top part prints beautifully.
              supernovae
              here is a less pronounced one - (printing at finer resolution)
                supernovae
                I've printed test cubes and they look fine.. printing a tall 20x20x400mm tower in vase mode right now to eliminate screw problems
                  supernovae
                  Prusa slicer isn't anywhere near as pronounced with defects.
                  Trying another with lower temps to see if it is too hot
                    Phaedrux Moderator @supernovae
                    @supernovae Probably fan speed settings differences between prusaslicer and cura. The bow is a very steep angle and needs a lot of cooling. The benchy is so tiny that it's prone to overheating. Try printing two at once in cura and I bet the bow will look much better.
                      supernovae
                      I checked cura, its set to be 100% fan on layer 2 - but it doesn't seem to be doing that. I'm going to try another benchy now in cura and see if i hear the fan at 100% or see if it gets louder progressively..
                      i guess i could just also read the gcode and see what the fan is set to as well heh. off to try that too
                        supernovae
                        Just to update, i swapped out cooling ducts - what a huge difference. I also tossed out this white PLA and used another brand and its now printing perfectly. I had to print the old white much hotter than i thought necessary to avoid jams but in doing so it stressed out a bad cooler. fixed both and happy now 🙂
