Temp sensors on tool board
the tool board documentation feature list mentionsTwo thermistor or PT1000 inputs. One uses a 16-bit ADC for high resolution reading of PT1000 sensors.
Which one uses the 16-bit ADC for high resolution reading of PT1000 sensors? That's not covered as far as I can see.
Also, just to make sure: I will not be able to use PT100 thermistors directly on the tool board, right? Those still need to go to the duet3 board and use the PT100 board?
@oliof said in Temp sensors on tool board:
That is my understanding. The PT1000 is more widely available now, is very reliable and accurate, and doesn't require a daughtboard/additional hardware.
Alright, time to go order new thermistors (my reserve Semitec seems to be broken)... @Phaedrux slightly off topic, would you choose a PT1000 over a Semitec? If yes, why?
@oliof I've not yet used a PT1000, but I would be tempted to try one over a semitec. That said, if you have a genuine Semitec with known values, and are printing at temps within it's accurate range, there isn't much incentive to use something else. (At least for typical 3D printing applications.)
https://blog.wika.com/knowhow/pt100-pt1000-or-ntc-which-is-the-right-measuring-element/
Is it true that in a Duet application, PT1000 requires an amplifier board and PT100 does not?
@Danal no it is the other way round the PT100 def needs the daughter board the 1000 does not
@oliof my goto sensor now is the PT1000 (haven't used a thermistor for some time now) the temp response from a PT1000 is more accurate and linear especially with a Meastro or Duet3 series board due to those using a 2200 ohm sense resistor!
Doug
@Danal I don't think that's the case. The PT100 requires the daughterboard and the PT1000 can be direct connected. The Maestro and Duet 3 have additional hardware to make the PT1000 more sensitive, not exactly sure what that is or how much better it is than on the Duet 2.
@Dougal1957 Right, the sense resistor. Back to drinking coffee, I haven't had enough obviosuly.
The TEMP0 input uses the 16-bit ADC.
@dc42 does the toolboard support the Slice thermistor? I assume/hope it will but mine hasn't yet arrived due to a shipping issue..
@gfisher said in Temp sensors on tool board:
It should do but I haven't tested that combination.
