    Tool change macro
    2.6k
    • Danalundefined
      Danal
      @tekstyle said in Tool change macro:
      May I ask when your printer has just turned on, by default, is the x carriage freed of all tools?
      Yes, and this works on my printer because my Z probe is on the carriage, not on any particular tool.
      I am thinking of doing something this:
      turn on printer. if T0 is not selected , then drop bed and select T0. This will then invoke Tpre0.g which will set the temperature (is this where I put my G10 command?).
      You don't have to invoke G10. Put it in config.g and the firmware will activate/deactivate each different G10 statement as tools become mounted or dismounted.
      tpre is not a good place to set temperatures because the "to be mounted" tool is not considered active yet. You'd be setting temperatures for either the old tool, or system defaults.
      Quite often, tpre does nothing. I have it move the carriage "near" the "to be picked up" tool so that if the printer does wait (see below) for the tool to heat, a human looking at the printer can see the tool on which it is waiting.
      proceed with tpost0.g to pick up the tool.
      To be clear, the firmware "proceeds" to the next macro; you don't code anything.
      proceed with homing on all axis (my Z piezo probe is attached to the x carriage and uses the nozzle of the tool as Z=0.).
      Sort of. You don't want a G28 in tpre or tpost because it would happen at EVERY tool swap. You want a T0 G28 somewhere in your startup. Literally those two commands, on the same line if you wish.
      after homing, run codes from the print file and until the first T# command and repeat the steps at the link above?
      You don't do anything. Just run jobs. If they contain T0 and/or T1 and/or Tn commands, all the macros will happen as the firmware invokes them.
      I take it Tpost is a pick up tool code which will include the nozzle wipe and extrude?
      Tpre is to do all the preheating and apply tool offset
      As mentioned above, these need to be in Tpost so the the tool is "active" from the firmware's point of view. Also, you don't apply offsets, the firmware does.
      Tfree is only invoked when another tool is mounted?
      Correct. It will contain the G-Code to "park" a tool. Take a look at my tfree, and you will see it moves to a parking position (via several moves, so that it will never collide with another parked tool) and unlocks the tool. Also, my tfree0 and tfree1 are identical, except for the coordinates of the parking stall for each tool.
      • Danalundefined
        Danal
        Implied in some of your questions above is the "How does the firmware 'know' what tool is mounted at power up (or after a reset)?".
        The fundamental answer is: It does not and/or cannot.
        (OK, a very few printers have a way to sense a tool and sometimes even which tool is mounted... this really requires conditional gcode for full advantage or similar, and that's why this is pretty uncommon, so far).
        Therefore... The human operator MUST do whatever actions are required to put the printer in a known state. And then continue startup procedures.
        "Known state" can mean anything you want... it generally means "no tools mounted, every tool in its proper parking stall" simply because most toolchanging printers have no way for the human to lock a tool. But, again, it could mean "Tool 0 mounted" or whatever you want (that the human can do).
        For these same reasons, it is very typical for toolchanging printers to home X and Y (and the tool lock axis, if there is that kind of lock), then pick up a tool or probe or etc, and use that to home Z.
        So power up for a toolchanging printer may involve:
        1. Manually remove any mounted tool and return it to its parking stall.
        2. Power up.
        3. Once printer is cleanly up, press the "Home" button... or press the "PowerUpPrep" macro button, or similar.
        • Danalundefined
          Danal
          Also note that while you do NOT want a G28 (home) in a tpre/post/free file (because it would happen every time), it is perfectly OK to have T0 (or whichever) in the "homeall.g" file. If T0 is already mounted when the printer sees a T0 command, nothing happens.
          So the very first time the printer was homed after power up, it would mount T0. If it were homed again (and T0 is still mounted) the rest of the homing just proceeds.
          • tekstyleundefined
            tekstyle
            Thank you again. good to know Tpre isn't really useful because I was pulling my hair trying to figure out what goes in it. I assume it is best used to start preheat before the current tool finishes doing whatever it is doing and before Tfree#.g is invoked.
            Here is my config.g:
            it isn't complete as I still have to setup the extruder, thermistor, etc. I have turned off the T0 command in config as I will need the firmware to home XY before it can select tool 0 to home Z.
            ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 24 2020 22:39:52 GMT-0800 (Pacific Standard Time)
            M550 P"coreXY" ; set printer name
            M667 S1 ; select CoreXY mode
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P4 S1 ; physical drive 4 goes forwards
            M584 X0 Y1 Z2 E3:4 ; set drive mapping
            M92 X100.00 Y100.00 Z1600.00 E420.00:420.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
            M906 X1700 Y1700 Z1700 E595:595 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X416 Y398 Z365 S0 ; set axis maxima
            M558 P5 I1 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
            G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
            M557 X46:416 Y0:340 S70 ; define mesh grid
            M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
            M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
            M143 H2 S280 ; set temperature limit for heater 2 to 280C
            M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
            M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on
            M563 P1 D1 H2 F0 ; define tool 1
            M563 P2 F0 ; define tool 2
            G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
            G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
            M563 P3 F0 ; define tool 3
            G10 P3 X0 Y0 Z0 ; set tool 3 axis offsets
            G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
            M563 P4 F0 ; define tool 4
            G10 P4 X0 Y0 Z0 ; set tool 4 axis offsets
            G10 P4 R0 S0 ; set initial tool 4 active and standby temperatures to 0C
            ;T0 ; select first tool
            (made some changes based on your Tpost and pre files)
            home all.g
            ; Home XY prior to selecting the first tool and then home Z using tool 0
            ;X homing
            G91 ; relative positioning
            G53 G1 H2 Z25 F6000 ; lift Z relative to current position to avoid collision with bed clamps
            G53 G1 H1 Y-62 ; move -62mm in Y to avoid collision in X movement
            G53 G1 H1 X-436.8 F3600 ; move quickly to X axis endstop and stop there (first pass)
            G53 G1 X5 F6000 ; go back a few mm
            G53 G1 H1 X-436.8 F360 ; move slowly to X axis endstop once more (second pass)
            ;Y homing
            G53 G1 H1 Y-408.225 F3600 ; move quickly to Y axis endstop and stop there (first pass)
            G53 G1 Y5 F6000 ; go back a few mm
            G53 G1 H1 Y-408.225 F360 ; move slowly to Y axis endstop once more (second pass)
            ;pick up T0
            G53 G1 z3 ; lift Z a few mm to avoid collision during travel
            G90 ;absolute positioning
            G53 G1 x413 Y336 F6000 ;move into position in front of T0 dock
            G91 ;relative positioning
            G53 g1 z-3 ; drop Z few mm
            G53 G1 x0 y62 F1800 ;move in Y towards T0 dock
            G53 G1 x-8 y0 ;move in X towards T0 dock
            G53 G1 x2 y-62 ; move in X/Y away from T0 dock. now tool 0 is selected and out of the way of other parked tools.
            G90 ; absolute positioning
            ;M98 P"/sys/Tpost0"
            ;Z homing
            G53 G1 H2 Z5 F6000 ; lift Z relative to current position
            G53 G1 X230 Y148 F6000 ; go to first probe point
            G53 G1 Z5 F100 ; lift Z relative to current position
            1. since G10 Rnnn Snnn are in config.g, if I need to changes these values, can I do it in the slicer?
            2. throughout a print, some of the parked extruders will not be used for some time depending on what is being printed. putting G10 Rnnn Snnn in config would mean it will heat to R upon power up correct? can G10 command or Tpre#.g command be invoked later in the print process but maybe a few minutes before the print actually needs to do a Tpost#.g to select it? I don't want all my tools to be at standby temperature for the entire duration of the print if they aren't needed.
            3. i turned off the M98 command in the homeall.g file because I can't get the firmware to call the macro. maybe I got the root directory path wrong.
            tekstyleundefined 1 Reply Last reply Reply Quote 0
            • tekstyleundefined
              tekstyle @tekstyle
              my Tpost0.g:
              ; tpost0.g
              ; called after tool 0 has been selected
              ; Wait for set temperatures to be reached
              ;M116 P0
              ;pick up T0 macro
              tfree0.g:
              ;Drop off T0 macro
              G53 G1 z3 ; lift Z a few mm for travel
              G53 G1 x408 Y336 F6000 ;move in front of T0 dock
              G53 G1 x-3 y62 F1800 ;move 62mm in Y towards T0 dock
              G53 G1 x8 y0 ;move away 8mm in X from T0 dock
              G53 G1 x0 Y-62 ;move back 62mm in Y after drop off
              G53 G1 z-3 ; drop Z a few mm to resume
              • Danalundefined
                Danal
                Looks pretty good. I scanned it (did not read every coordinate in detail)
                Two thoughts:
                1. I'm just curious what locks and unlocks the tool when picking up or parking?
                2. I suggest "square" moves to avoid certain types of collision. That is, if you want to get to
                  G53 G1 x413 Y336
                  Just before picking up the tool, consider moving like this:
                  G53 G1 Y336
                  G53 G1 x413
                  G53 G1 x413 Y336
                (last one not strictly necessary... but it helps make the macro "self documenting").
                This can avoid a tool-to-parked-tool collision that results from a diagonal move. For example, if the tool was at X0 Y300 when you initiated that move, it would be a long shallow diagonal across the backs of all the tools, quite likely to 'clip' the one nearest the tool we are putting away.
                Ask me how I know...
                • tekstyleundefined
                  tekstyle
                  thanks for the suggesting in 2. I will impliment a square move instead of a linear move. I assume this would also be useful to avoid majority of the half printed workpiece by moving around its perimeter.
                  I don't have a call to lock and unlock because I am using magnets.
                  • tekstyleundefined
                    tekstyle
                    In the Config.g file, T0 automatically commanded at the end. however, after reading the T section in the Gcode documentation, it will only get invoked when all axis are homed. I can home X and Y but I need to select Tool 0 before I can home Z. therefore, it does basically nothing. I check the tool status with "T" and it would say T0 is selected but there were indeed no action to select it. i would give me a popup "G0G/1: insufficient axis homed" something like that. How can I get this to work?
                    interesting enough, my homeall.g which contains both home x and y macro has a G1 Z# component and it would still proceed. however, the (;pickup T0) macro won't run unless I deleted the G53 G1 z3 and G53 G1 Z-3 line.
                    I do not know why the firmware won't let me proceed with Home x and y when there is also a Z movement command in them but not later in the macro.
                    home all.g
                    ;X homing
                    G53 G1 H2 Z25 F6000 ; lift Z relative to current position to avoid collision with bed clamps this works
                    ;Y homing
                    ;pick up T0
                    G53 G1 z3 ; lift Z a few mm to avoid collision during travel had to semi-colon this line to work
                    G53 g1 z-3 ; drop Z few mm had to semi-colon this line to work
                    ;M98 P"/sys/Tpost0" ; just can't get this to work.
                    ;Z homing
                      dc42 administrators @tekstyle
                      Z hasn't been homed at this point, so use:
                      G53 G1 H2 Z-3
                      • tekstyleundefined
                        tekstyle
                        it works now! thank you. now I think I can use the Tpost0.g to pick up tool 0 before homing Z instead of all the extra instructions at the end instead of all the codes at the end of home Y.
                        Thank you Danal and DC42.
