Cannot connect Duet Wifi to new Wifi Router
57
3.4k
    GaRv3
    Hey there,
    I've got a new wifi router. Now I cannot connect the Duet Wifi to the network.
    I followed this guide with no success: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
    Because the SSID is hidden, I included it in the M552 command when connecting, but I also tried with a broadcasted SSID.
    The Duet responds with:
    WiFi reported error: Timed out while trying to connect to GarMir 2,4GHz
    WiFi module is idle
    WiFi reported error: Unknown WiFi state while trying to connect to GarMir 2,4GHz
    WiFi module is idle
    The router logs:
    03/17/2020 20:29:36 MAC 2c:3a:e8:00:00:00 authentication with GarMir 2,4GHz; WG-MAC=D4:3F:CB:91:5F:69; IF=wlan0_0 Wi-Fi
    03/17/2020 20:29:36 MAC 2c:3a:e8:00:00:00 associated to GarMir 2,4GHz; WG-MAC=D4:3F:CB:91:5F:69; IF=wlan0_0 Wi-Fi
    03/17/2020 20:29:36 WG-MAC=D4:3F:CB:91:5F:69; STA-MAC=2c:3a:e8:00:00:00; IF=wlan0_0; SSID=GarMir 2,4GHz; ConnectionState=connected; WirelessMode=802.11n; LastTxPhyRate=52Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:0Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-33dBm; Channel=2412MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=0 Wi-Fi
    03/17/2020 20:29:34 REASON-CODE-DESCR=DISASSOC_STA_HAS_LEFT;REASON-CODE=8; WG-MAC=D4:3F:CB:91:5F:69; STA-MAC=2c:3a:e8:00:00:00; IF=wlan0_0; SSID=GarMir 2,4GHz; ConnectionState=other_deassociate; WirelessMode=802.11n; LastTxPhyRate=52Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:0Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-33dBm; Channel=2412MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=8 Wi-Fi
    03/17/2020 20:29:34 REASON-CODE-DESCR=DISASSOC_STA_HAS_LEFT;REASON-CODE=8; WG-MAC=D4:3F:CB:91:5F:69; STA-MAC=2c:3a:e8:00:00:00; IF=wlan0_0; SSID=GarMir 2,4GHz; ConnectionState=clientDisassociated; WirelessMode=802.11n; LastTxPhyRate=52Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:0Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-33dBm; Channel=2412MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=8 Wi-Fi
    03/17/2020 20:29:34 DISASSOC - MAC=2c:3a:e8:00:00:00, Reason=8; WG-MAC=D4:3F:CB:91:5F:69; IF=wlan0_0 Wi-Fi
    What can cause these problems? Are there any special chars not allowed in the SSID or password?
    I am not using " or ' but some special chars like , $ %
    Do I need to excape those and if yes: how?
    Best
    GaRv3
      PaulHew
      Your new router, is it a 5Ghz by chance?
      The Duet boards only support 2.4ghz.
      If there is an option to enable a 2.4 SSID, Try that.
      HTH
      Paul
        GaRv3
        See the attached logs.
        The wifi I am trying to connect to is 2.4 GHz.
        undefined 1 Reply Last reply 17 Mar 2020, 20:30 Reply Quote 0
          PaulHew
          My bad🤦
          You could try un-hiding the SSID temporarily to see if that helps.
          With the previous router, did it have the same SSID?
          If it did, clear the associations in the Duet and reconnect again, could be an authentication issue.
          P.
          undefined 1 Reply Last reply 18 Mar 2020, 00:06 Reply Quote 0
            droftarts administrators @GaRv3
            @GaRv3 what firmware version? Send M115 and post response. There’s a bug in early RRF 3 releases where the SSID password is not stored.
            undefined 1 Reply Last reply 18 Mar 2020, 00:03 Reply Quote 0
              A Former User
              @GaRv3 said in Cannot connect Duet Wifi to new Wifi Router:
              afaik only ' is a problem, and ' is the escape key. see the note on
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
              reason=8 may suggest the key is stored in the duet and accepted by the access point.
              https://www.cisco.com/assets/sol/sb/WAP371_Emulators/WAP371_Emulator_v1-0-1-5/help/Apx_ReasonCodes2.html
                GaRv3 @droftarts
                @droftarts
                M115
                FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
                @bearer
                Yeah I knew ' too. That's why I wrote I don't have it in the SSID or pw.
                What does "sending STA is leaving or has left Basic Service Set (BSS)" on the page you linked mean? Incompatible protocol versions?
                ? 1 Reply Last reply 18 Mar 2020, 00:17 Reply Quote 0
                  GaRv3 @PaulHew
                  @PaulHew
                  See my first post again "but I also tried with a broadcasted SSID" 😁
                  And no, the SSID was not the same and I even tried using another SSID.
                  undefined 1 Reply Last reply 18 Mar 2020, 00:36 Reply Quote 0
                    A Former User @GaRv3
                    not sure I found anything relevant, but it does suggest client side issue, most topics relate to signal quality and roaming.
                    could be the wifi is confused after the hidden bssid, try clearing all stored networks and adding just the one? try:
                    M552 S-1
                    M552 S0
                    M588 S"*"
                    M587 S"GarMir" P"key"
                    M552 S1 P"GarMir"
                    Edit: also could you confirm your wifi is set to channel 1 as a fixed channel, not auto? (log said 2412MHz)
                      It would be good to update your firmware to the latest RRF2 version, 2.05.1. Get it from https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
                      Update instructions, by copying file to SD card on your PC: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
                      So long as you have named the SSID correctly, it doesn't matter if it's hidden.
                      How is the WiFi encryption set on the router? Duet 2 Wifi only supports WPA and WPA-2 with either AES or TKIP encryption (I think!). Maybe take a screenshot of the WiFi setup page on the router?
                      ? 1 Reply Last reply 18 Mar 2020, 00:43 Reply Quote 0
                        A Former User @droftarts
                        @droftarts said in Cannot connect Duet Wifi to new Wifi Router:
                        also, the log suggest the client is leaving, after successfully having connected, so unlikely to be a encryption issue (unless I'm reading the log incorrectly)
                          GaRv3
                          @bearer
                          Didn't help unfortunately.
                          @droftarts
                          As mentioned by @bearer , this should not be an encryption issue. Router is set to WPA2 and encryption mode is AES.
                          I will try this next.
                          ? 1 Reply Last reply 18 Mar 2020, 00:51 Reply Quote 0
                            mkay, still, try to make sure there arent more than one entry if you do make changes, just to rule out that going forward.
                            maybe its time to elaborate a little on the pysical conditions of the network. locations, other APs etc?
                              GaRv3
                              I will go into detail about this if the firmware update does not solve the issue.
                              But I've got a question about the fallback update procedure. There is no "iap4e.bin" in the repo but the guide tells me to copy it over. Should I simply leave the old file in place?
                              ? 1 Reply Last reply 18 Mar 2020, 01:03 Reply Quote 0
                                Check this release for the iap files https://github.com/dc42/RepRapFirmware/releases/tag/2.03
                                  it won't do any harm, and will be needed if you should ever wish to downgrade. however as 2.03 is likely using wifi firmware 1.23 i doubt there is any change relevant to the issue; but won't hurt to be up to date. while you're at it do confirm the wifi firmware is 1.23. (its part of the M122 output.
                                    GaRv3
                                    Ok, so I updated the frimware and Wifi server:
                                    M115
                                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                                    M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                                    Board ID: 08DGM-95BLL-N6PSS-6J1F0-3S86R-90TVM
                                    Used output buffers: 1 of 24 (1 max)
                                    Static ram: 25712
                                    Dynamic ram: 93132 of which 0 recycled
                                    Exception stack ram used: 264
                                    Never used ram: 11964
                                    Tasks: NETWORK(ready,540) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
                                    Owned mutexes:
                                    Last reset 00:04:44 ago, cause: software
                                    Last software reset at 2020-01-26 16:51, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 0)
                                    Error status: 0
                                    Free file entries: 10
                                    MCU temperature: min 24.3, current 27.3, max 27.4
                                    Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0, power good: no
                                    Driver 0: ok, SG min/max not available
                                    Driver 1: ok, SG min/max not available
                                    Driver 2: ok, SG min/max not available
                                    Driver 3: ok, SG min/max not available
                                    Driver 4: ok, SG min/max not available
                                    Cache data hit count 513307291
                                    Slowest loop: 4.16ms; fastest: 0.05ms
                                    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                                    === DDARing ===
                                    Segments left: 0
                                    Movement lock held by null
                                    http is idle in state(s) 0
                                    telnet is idle in state(s) 0
                                    file is idle in state(s) 0
                                    serial is ready with "M122" in state(s) 0
                                    aux is idle in state(s) 0
                                    daemon is idle in state(s) 0
                                    queue is idle in state(s) 0
                                    Code queue is empty.
                                    === Network ===
                                    Slowest loop: 1173.89ms; fastest: 0.00ms
                                    HTTP sessions: 0 of 8
                                    - WiFi -
                                    Network state is changing mode
                                    WiFi module is trying to connect
                                    WiFi firmware version 1.23
                                    WiFi MAC address 2c:3a:e8:0b:17:0f
                                    WiFi Vcc 3.32, reset reason Turned on by main processor
                                    WiFi flash size 4194304, free heap 27928
                                    The problem persists.
                                    About the physical conditions:
                                    The printer is right next to the router (ap) with one wall in between. The signal strength should be easily sufficient with the 2.4GHz wifi. I even get full 5GHz signal strength right next to the printer on my phone.
                                    There are many wifi signals around here. It's a pretty crouded place. But I made sure to use the wifi channel that has the fewest SSIDS. Currently it's 2AM and there should be near to no interference.
                                    ? 1 Reply Last reply 18 Mar 2020, 01:17 Reply Quote 0
                                      is it a fixed channel (not auto?), if auto it could be the Duets wifi module cannot follow across all channels due to differing country regulations, but I have no idea whats set for either product.
                                      re signal strength, see if you can run M122 repeatedly and catch the Duet in a moment where it is connected and shows its signal strength, it will likely have (significantly) lower receive sensitivity than your router (and phone)
                                        GaRv3
                                        It's channel 11 fixed.
                                        M122 always reports
                                        Doesn't seem I can get a report in the very short time frame, when a connection is established.
                                        But I am shure, the signal strength is very good. This can't be the issue. I can easily establish a very good wifi connection two rooms further from the router with any device.
                                        ? 1 Reply Last reply 18 Mar 2020, 01:27 Reply Quote 0
                                          Channel=2412MHz;
                                          does not compute, but might not be relevant as its usally 12-14 that gives problems.
                                          Don't underestimate the ESP8266 module's ability to not get a signal; after all as it stands the options are defective module or poor singal as far as I can tell.
                                          5 out of 57
