    Cannot connect Duet Wifi to new Wifi Router
    57
    3.5k
    • GaRv3undefined
      GaRv3
      Ok, so I updated the frimware and Wifi server:
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DGM-95BLL-N6PSS-6J1F0-3S86R-90TVM
      Used output buffers: 1 of 24 (1 max)
      Static ram: 25712
      Dynamic ram: 93132 of which 0 recycled
      Exception stack ram used: 264
      Never used ram: 11964
      Tasks: NETWORK(ready,540) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:04:44 ago, cause: software
      Last software reset at 2020-01-26 16:51, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 24.3, current 27.3, max 27.4
      Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 513307291
      Slowest loop: 4.16ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "M122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1173.89ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      - WiFi -
      Network state is changing mode
      WiFi module is trying to connect
      WiFi firmware version 1.23
      WiFi MAC address 2c:3a:e8:0b:17:0f
      WiFi Vcc 3.32, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27928
      The problem persists.
      About the physical conditions:
      The printer is right next to the router (ap) with one wall in between. The signal strength should be easily sufficient with the 2.4GHz wifi. I even get full 5GHz signal strength right next to the printer on my phone.
      There are many wifi signals around here. It's a pretty crouded place. But I made sure to use the wifi channel that has the fewest SSIDS. Currently it's 2AM and there should be near to no interference.
        A Former User @GaRv3
        @GaRv3 said in Cannot connect Duet Wifi to new Wifi Router:
        is it a fixed channel (not auto?), if auto it could be the Duets wifi module cannot follow across all channels due to differing country regulations, but I have no idea whats set for either product.
        re signal strength, see if you can run M122 repeatedly and catch the Duet in a moment where it is connected and shows its signal strength, it will likely have (significantly) lower receive sensitivity than your router (and phone)
        • GaRv3undefined
          GaRv3
          It's channel 11 fixed.
          M122 always reports
          Doesn't seem I can get a report in the very short time frame, when a connection is established.
          But I am shure, the signal strength is very good. This can't be the issue. I can easily establish a very good wifi connection two rooms further from the router with any device.
            Channel=2412MHz;
            does not compute, but might not be relevant as its usally 12-14 that gives problems.
            Don't underestimate the ESP8266 module's ability to not get a signal; after all as it stands the options are defective module or poor singal as far as I can tell.
            • GaRv3undefined
              GaRv3
              Some more information on the 2.4GHz wifi:
              SSID: GarMir 2,4GHz
              SSID broadcast: off
              Security: WPA2
              Wifi mode: Mixed 802.11 g/n
              Channel: 11
              Bandwidth: 20/40 MHz
              By the way: Sometimes I can see the Duet in my router status as
              IPv4: 192.168.0.37
              IPv6:
              MAC: 2C:3A:E8:0B:17:0F
              WiFi: 2.4GHz
              with full signal strength.
                A Former User
                If its inconvenient to move the printer you could try switching roles; put the Duet in AP mode and see what signal strength you get where the router is (although it won't quite be an apples to apples thing).
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
                  what it transmits and what it receives could differ by a lot tbh.
                  • GaRv3undefined
                    GaRv3
                    Yeah, but to be honest, this should really not be a thing.
                    The physical distance between the router and the Duet is maybe 0.5m. It's literally just this one wall in between.
                    I will actually try to remove the special chars from the wifi SSID and password now to see if this could be a thing.
                    Edit: No success
                      A Former User
                      All I'm saying is the Duet people are normally more than willing to replace faulty boards, but I'd hate to see you waste time with a replacement if the problem isn't the board; which I don't think is the case but thats just my $0.02.
                      • GaRv3undefined
                        GaRv3
                        I don't think it is a hardware problem with the board. This would be a strange coincidence cause it worked until I changed the router.
                        I will power up my old router now an check if the Duet connects to it.
                        Edit:
                        Connecting to the old router works just fine.
                        This has to be some kind of incompatibility...
                          samme ssid and key?
                          GaRv3undefined 1 Reply Last reply Reply Quote 0
                          • bondusundefined
                            bondus
                            I used to work with wifi routers a few years back and spent countless hours staring at sniffed packet logs to figure out why things did not connect.
                            Some things are simply not compatible with each other. It has nothing to do with radio quality, just that one of the parts involved has interpreted the standard in a different way. If it's a ISP provided router it will be the lowest bidder that has interpreted the standard...
                            • GaRv3undefined
                              GaRv3 @A Former User
                              @bearer
                              Tried same SSID and PW on the new one. Yes
                              • GaRv3undefined
                                GaRv3 @bondus
                                @bondus
                                This is so frustrating. What is the use of standards if no one sticks to them?
                                A Former User? droftartsundefined 2 Replies Last reply Reply Quote 1
                                • Danalundefined
                                  Danal
                                    see if the new one has some ultra mega max 2000 multimedia streaming extensions and try fixing the channel width to 20mhz and setting bgn mode to a lower common denominator, apart from that sounds like you might be better off briding the Duet to the old router?
                                      droftarts administrators @GaRv3
                                      @GaRv3 Did you check/update the firmware on the router? Also, what router is it?
                                      • GaRv3undefined
                                        GaRv3
                                        It's a so called "Vodafone Station".
                                        To be precise it is the ARRIS Touchstone TG3442DE.
                                        The firmware gets updated by the ISP automatically.
                                        • GaRv3undefined
                                          @bearer said in Cannot connect Duet Wifi to new Wifi Router:
                                          Limiting to 20 MHz didn't make any difference.
                                          The mode cannot be changed to anything but "Mixed 802.11 g/n" for the 2.4 GHz wifi on this router.
                                          Edit: I cannot use the old router as an access point because I have to send it back to the ISP soon.
                                            A Former User
                                            I'm afraid I'm running out of suggestions; if running the Duet as an AP and your AP as a client* isn't a workable option (which sounds unlikely if its an ISP device).
                                            *) in addition to the regular AP
