    Cannot connect Duet Wifi to new Wifi Router
    57
    3.4k
    • GaRv3undefined
      GaRv3
      I don't think it is a hardware problem with the board. This would be a strange coincidence cause it worked until I changed the router.
      I will power up my old router now an check if the Duet connects to it.
      Edit:
      Connecting to the old router works just fine.
      This has to be some kind of incompatibility...
        A Former User @GaRv3
        @GaRv3 said in Cannot connect Duet Wifi to new Wifi Router:
        samme ssid and key?
        GaRv3undefined 1 Reply Last reply Reply Quote 0
        • bondusundefined
          bondus
          I used to work with wifi routers a few years back and spent countless hours staring at sniffed packet logs to figure out why things did not connect.
          Some things are simply not compatible with each other. It has nothing to do with radio quality, just that one of the parts involved has interpreted the standard in a different way. If it's a ISP provided router it will be the lowest bidder that has interpreted the standard...
          • GaRv3undefined
            GaRv3 @A Former User
            @bearer
            Tried same SSID and PW on the new one. Yes
            • GaRv3undefined
              GaRv3 @bondus
              @bondus
              This is so frustrating. What is the use of standards if no one sticks to them?
              A Former User? droftartsundefined 2 Replies Last reply Reply Quote 1
              • Danalundefined
                Danal
                  see if the new one has some ultra mega max 2000 multimedia streaming extensions and try fixing the channel width to 20mhz and setting bgn mode to a lower common denominator, apart from that sounds like you might be better off briding the Duet to the old router?
                    droftarts administrators @GaRv3
                    @GaRv3 Did you check/update the firmware on the router? Also, what router is it?
                    • GaRv3undefined
                      GaRv3
                      It's a so called "Vodafone Station".
                      To be precise it is the ARRIS Touchstone TG3442DE.
                      The firmware gets updated by the ISP automatically.
                      • GaRv3undefined
                        @bearer said in Cannot connect Duet Wifi to new Wifi Router:
                        Limiting to 20 MHz didn't make any difference.
                        The mode cannot be changed to anything but "Mixed 802.11 g/n" for the 2.4 GHz wifi on this router.
                        Edit: I cannot use the old router as an access point because I have to send it back to the ISP soon.
                          A Former User
                          I'm afraid I'm running out of suggestions; if running the Duet as an AP and your AP as a client* isn't a workable option (which sounds unlikely if its an ISP device).
                          *) in addition to the regular AP
                          • GaRv3undefined
                            GaRv3
                            @bearer
                            That's not possible with this router.
                            So my only option is probably to buy an M.2 wifi module for the PC and use this to connect to the Duet run in AP mode. But first I would like to double check if the module is compatible to the Duet.
                            I would probably pick the Intel 9260NGW which is a Wifi 2.4/5Ghz + Wifi 6 + BT 5.0 chipset. Any experience with this chipset connecting to the Duet AP?
                              As it's the Duet setting the network, I'd guess almost any wireless adapter would work. We don't keep track of hardware that works, you're better off looking at more general 'works with ESP8266' pages.
                              Also found this, which sounds similar to the problem you're having: https://github.com/esp8266/Arduino/issues/4257
                              Might be useful for @dc42 to look at?
                              Sparatutto created this issue in esp8266/Arduino
                              closed v2.4.0 - wifi.status() and wifi.localIP not updated after a reconnect. #4257
                              • GaRv3undefined
                                GaRv3
                                @droftarts
                                Yes, actually seems like something @dc42 might be able to fix. I think I will try the wifi module in the meantime anyway.
                                  A Former User @droftarts
                                  @droftarts said in Cannot connect Duet Wifi to new Wifi Router:
                                  if related, setting a static IP in the duet may help
                                  M552 S-1
                                  M552 S0
                                  M588 S"*"
                                  M587 S"GarMir" P"key" I"192.168.0.37"
                                  M552 S1 P"GarMir"
                                  although bad mojo to set a static address inside a dhcp pool without at least making a reservation.
                                    @GaRv3 Please do try @bearer 's suggestion of setting a static ip address, too.
                                    • GaRv3undefined
                                      GaRv3
                                      Already tried that. And I reserved the IP on the router as well to make sure it is free.
                                        @GaRv3 Okay, fair enough. I've asked @dc42 to take a look.
                                        • Dougal1957undefined
                                          Dougal1957
                                          I had the exact same issue as this a couple of years ago eventually had to use a TP-LINK Travel router in AP Mode for the duet to connect to the issue was a Router that just didn't like the ESP at all (it was a nether one as well) once I replaced the router everything came back to normal.
                                          Doug
                                          • GaRv3undefined
                                            GaRv3
                                            @Dougal1957
                                            Did you replace the router with the sam model (so, was it defect) or did you pick another one?
