    Cannot connect Duet Wifi to new Wifi Router
    57
    3.6k
    • Danalundefined
      Danal
        A Former User @GaRv3
        @GaRv3 said in Cannot connect Duet Wifi to new Wifi Router:
        What is the use of standards if no one sticks to them?
        see if the new one has some ultra mega max 2000 multimedia streaming extensions and try fixing the channel width to 20mhz and setting bgn mode to a lower common denominator, apart from that sounds like you might be better off briding the Duet to the old router?
        GaRv3undefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @GaRv3
          @GaRv3 Did you check/update the firmware on the router? Also, what router is it?
          • GaRv3undefined
            GaRv3
            It's a so called "Vodafone Station".
            To be precise it is the ARRIS Touchstone TG3442DE.
            The firmware gets updated by the ISP automatically.
            • GaRv3undefined
              GaRv3 @A Former User
              @bearer said in Cannot connect Duet Wifi to new Wifi Router:
              Limiting to 20 MHz didn't make any difference.
              The mode cannot be changed to anything but "Mixed 802.11 g/n" for the 2.4 GHz wifi on this router.
              Edit: I cannot use the old router as an access point because I have to send it back to the ISP soon.
                A Former User
                I'm afraid I'm running out of suggestions; if running the Duet as an AP and your AP as a client* isn't a workable option (which sounds unlikely if its an ISP device).
                *) in addition to the regular AP
                • GaRv3undefined
                  GaRv3
                  @bearer
                  That's not possible with this router.
                  So my only option is probably to buy an M.2 wifi module for the PC and use this to connect to the Duet run in AP mode. But first I would like to double check if the module is compatible to the Duet.
                  I would probably pick the Intel 9260NGW which is a Wifi 2.4/5Ghz + Wifi 6 + BT 5.0 chipset. Any experience with this chipset connecting to the Duet AP?
                    As it's the Duet setting the network, I'd guess almost any wireless adapter would work. We don't keep track of hardware that works, you're better off looking at more general 'works with ESP8266' pages.
                    Also found this, which sounds similar to the problem you're having: https://github.com/esp8266/Arduino/issues/4257
                    Might be useful for @dc42 to look at?
                    Sparatutto created this issue in esp8266/Arduino
                    closed v2.4.0 - wifi.status() and wifi.localIP not updated after a reconnect. #4257
                    • GaRv3undefined
                      GaRv3
                      @droftarts
                      Yes, actually seems like something @dc42 might be able to fix. I think I will try the wifi module in the meantime anyway.
                        A Former User @droftarts
                        @droftarts said in Cannot connect Duet Wifi to new Wifi Router:
                        if related, setting a static IP in the duet may help
                        M552 S-1
                        M552 S0
                        M588 S"*"
                        M587 S"GarMir" P"key" I"192.168.0.37"
                        M552 S1 P"GarMir"
                        although bad mojo to set a static address inside a dhcp pool without at least making a reservation.
                          @GaRv3 Please do try @bearer 's suggestion of setting a static ip address, too.
                          • GaRv3undefined
                            GaRv3
                            Already tried that. And I reserved the IP on the router as well to make sure it is free.
                              @GaRv3 Okay, fair enough. I've asked @dc42 to take a look.
                              • Dougal1957undefined
                                Dougal1957
                                I had the exact same issue as this a couple of years ago eventually had to use a TP-LINK Travel router in AP Mode for the duet to connect to the issue was a Router that just didn't like the ESP at all (it was a nether one as well) once I replaced the router everything came back to normal.
                                Doug
                                • GaRv3undefined
                                  GaRv3
                                  @Dougal1957
                                  Did you replace the router with the sam model (so, was it defect) or did you pick another one?
                                  • GaRv3undefined
                                    GaRv3
                                    So for now (until the wifi module arrives) I have connected an AP which I found in a closet to the second LAN port of my PC, created a wireless network and connected the Duet. Works just fine... as a temporary workaround.
                                    droftartsundefined GaRv3undefined 2 Replies Last reply Reply Quote 0
                                      @GaRv3 Glad you have a (temporary) solution!
                                        Dougal1957 @GaRv3
                                        @GaRv3 picked a different one I have just ordered a new connection with Vodafone UK so hope I don't have the same issue again (My current VF router is fine but the new line will come with the newer square ash router but in the UK I think they tend to use HuaWei stuff (Not that I am happy about but got no real choice))
                                        • GaRv3undefined
                                          GaRv3
                                          @dc42 Any suggestions?
                                            @GaRv3 @dc42 said to me yesterday “yes, possible bug. It's on my list to do a new wifi server using the newer expressiv SDK, but it's not a quick job.”
