    How to force a stepper driver into full step position?
    27
    1.2k
    • DocTruckerundefined
      DocTrucker
      Ok, got the machine powered up and checked.
      M18 is not a switch command it is definitely a disable command. I checked the machine and you could definitely move the steppers easily after issuing M18.
      However, the home all command worked fine after M18 with the steppers moving and the process completing.
      The following process seems to work fine and the machine is flagged as homed after:
      G1 X0 Y0 Z0
      M18
      G92 X0 Y0 Z0
      I've moved the machine to touching the nozzle on the bed to increase the resistance against dropping the bed. But that said I'm using 1mm pitch lead screws, so the chance of a major movement is minimal. Yes my first layer may be a little crap but I've designed the test geometry so that the measurement point is well above the section of the part that is likely to suffer the 'elephant foot' and between any significant changes in section such as the upper and lower solid areas or any change in XY section in the Z direction.
      Next challenge is a deep dive into slic3r in order to directly specify the part locations of 16 parts. That's one LONG command line string!
        dc42 administrators @DocTrucker
        @DocTrucker said in How to force a stepper driver into full step position?:
        I'll read the driver docs about what happens when the current drops down then comes back up. I would have expected it to come back to the same point in the cycle, as the chip itself isn't powered down?
        That's correct AFAIK. Disabling the the driver only disables the output stage. Whereas removing VIN power and reapplying it will reset the chip.
          DocTrucker @dc42
          @dc42 Ahh ok, my responce there was my thoughts that dropping current to 0 and increasing may not do it, rather tham M18. Just to be clear you are saying M18 may not reset the chip either?
            DocTrucker
            Confirmed for the A4982 drivers of the Duet v0.6 and 0.8.5, a power cycle will be needed. Cycling reset could achieve the 'reset to home position' but that is hard wired on the v0.6 & v0.8.5 to the 3.3V line. I've not looked over the Duet3 or Duet2 drivers spec sheets. I guess there may be an SPI command that could achieve the reset but as the use cases are limited to probably just my test it's not worth a feature request.
              deckingman @DocTrucker
              @DocTrucker I'll leave you to it then. But for info in the past, I have thought about using a machine DRO (digital readout) as a secondary means of measuring the actual print head (and or build plate) position. I've just ordered a 3 axis kit for my milling machine from Ebay for a little over £200 from China. It's exactly the same as those supplied by UK machine suppliers for 2 or 3 times the price. Claimed accuracy is something like 5um (0.005mm) so even if that's out by 10 fold then the "real accuracy" might be 0.05mm. If your budget is really tight, you can pick up a 150mm digital caliper off Ebay for £3 or £4 and chop that up - I've seen people do that as a cheap way of getting a DRO on a lathe tailstock quill. I don't really know what you are doing though, so just ignore this post if none of it is relevant.
              DocTruckerundefined 1 Reply Last reply Reply Quote 1
                DocTrucker @deckingman
                @deckingman Cheers for the hints. I will invite more scrutiny of the work in the future but it is far too early to do so at the moment, I just wanted to test the set at full step for effectiveness but had no idea on how to achieve that.
                In a nutshell for those still reading it is set the head to a known position, power cycle, define the current position as the previously set position using G92. Yes there will be some settlement of the drivers, but that is kind of the point!
                  When the drivers are disabled (which you can do with M18), M569 will report the current microstep position. This value isn't yet included in the object model.
                  • arhiundefined
                    arhi
                    Do any of the TMC driver options come with interpolation enabled on full step operation? That would be ideal for this purpose? I think gecko has a driver that does 1/10 interpolation while always keeping your motor on full step (so you have precision) but I am not sure, anyhow 1/256 interpolation on full step (or half step) movement would be ideal.
                      A Former User
                      MicroPlyer™ Microstep interpolator for obtaining full 256 microstep smoothness with lower resolution step inputs starting from fullstep
                      The 5160 has it, think the 2209 as well
                      • arhiundefined
                        arhi
                        Isn't that a solution then?
                          When the driver is disabled, it's possible to read the microstep counter of a driver using the M569 command with just a P parameter to specify which drive.
