    Duet3D System won't turn on now
    107
    4.9k
    • Jim46undefined
      Jim46
      Today, the system came back on properly. Input the IP address and the Duet Web Control 2 sais the DCS was not working...couldn't connect... what is not happening?
      Jim
        I've seen that once a second flash when incompatible versions of RRF and DCS are used. What versions are you using?
        • Jim46undefined
          Jim46
          How does one determine the version numbers of RRF and DCS?
          • Danalundefined
            Danal
            Of course, the board has to come up to find this...
            To diagnose, disconnect the Pi from the D3 and power the Pi separately. Either use the touch screen, or SSH to the Pi, and perform:
            sudo apt-get upgrade
            sudo apt-get update
            sudo apt-get install --reinstall duetsoftwareframework
            Then power off and reconnect the D3 and the Pi. After it comes up, use the web console to enter "M997". If you have expansion boards, enter "M997 B1", etc, for however many boards you have. Wait for each to finish before doing the next.
            • Jim46undefined
              Jim46
              Hello
              The Pi4 is disconnected from the Duet3D.
              I ran the
              then
              sudo apt-get update
              then tried
              sudo apt-get install with --reinstall duetsoftwareframework...enter
              sudo apt-get install......enter
              in neither case did it progress....
              don't know what to do next?
              • jens55undefined
                jens55
                Just to clarify one thing, the order is:
                sudo apt-get update
                Note the switched order of things.
                Danalundefined 1 Reply Last reply Reply Quote 1
                • Jim46undefined
                  Jim46
                  Okay, I just did
                  sudo apt-get update
                  what next?
                  • Danalundefined
                    Danal @jens55
                    @jens55 said in Duet3D System won't turn on now:
                    sudo apt-get update
                    THANKS!!!
                    • Danalundefined
                      Danal
                      @Jim46 said in Duet3D System won't turn on now:
                      What happened, any messages at all?
                      • jens55undefined
                        jens55
                        Sorry, wasn't clear, it's unlikely that this would make a difference in this case but the order is important and others may have used the wrong order.
                        You could try:
                        just to be complete
                        Unfortunately I have no other suggestions, sorry ...
                        • Jim46undefined
                          Jim46
                          this is the screen after performing
                          it seems okay... what is it really... 🙂
                          If good then I'll go back to
                          • jens55undefined
                            jens55
                            Looks good as far as the screenshot is concerned. I know nothing about connecting a pi and a duet3, sorry.
                            • Jim46undefined
                              Jim46
                              I reconnected the Pi4 and Duet3D. As you can see, the DCS is still unavailable.
                              Its never gone past this point. So, I don't think I can get to the point of determining the rev number of RRF and DCS.
                              Anyone know of another way of getting this info? Once I do have it, then how does it help getting the system to run?
                              thanks,
                              Jim
                                A Former User @Jim46
                                Connect to the micro usb of the Duet 3 with either the Pi or your computer and run M115 from the serial console to retrieve the RRF version.
                                from ssh you can run apt list 2>/dev/null | grep duet | awk -F'[/ ]' '{print $1" "$3 }' and it should list all the duet packages and their installed versions.
                                • jens55undefined
                                  jens55
                                  This suggest to me that you have a networking issue and not a Duet/pi issue.
                                  WIth that in mind, and recalling that I have never set up anything like this, here are a few suggestions I would look into:
                                  1. try a different browser. Make sure that the browser isn't locked down with various add on packages. I use Firefox and have ad blockers and script blockers and what-have-you blockers installed. Unless I open a path, the browser would never connect properly.
                                    Despite me KNOWING this to be an issue, it catches me way too often!
                                  2. A USB connection has been suggested and is a good way to help figure things out.
                                  3. verify that ip address you are attempting to reach is in fact the right address. Has the Duet been assigned a static IP address ? Are the pi and the Duet on the same IP address block (192.168.1.xxx).
                                    A Former User
                                    I was looking at the IP address and wondering a bit myself, the Duet 3 when used with a rPi shouldn't have an IP address as the interfacing is done over the SPI bus - as such only the rPi has an IP address.
                                    Might still be an idea to also confirm the rPi is using the address shown. hostname -I or ifconfig should bring up the address used for the rPi.
                                    • Danalundefined
                                      Danal
                                      The re-install looks good. This means that DCS (the Pi part) is good, and that there will be a "whatever.bin" file sitting there to install on the Duet board itself, when we figure out how to do that. Because it still won't connect Pi<>Duet, we may have to use the USB on the Duet, as mentioned above.
                                      A couple of things before we get to the USB:
                                      Just a basic check: There is NOT an SD card in the Duet, correct? Should be empty when using a Pi.
                                      Also, as mentioned, please do an "ifconfig" on the Pi (via your touchscreen). Verify that the IP address shown is the one that you are attempting to connect in the browser.
                                      • Jim46undefined
                                        Jim46
                                        @bearer said in Duet3D System won't turn on now:
                                        I managed download PuTTy, enable SSH on the Pi and run the apt list 2>
                                        and received:
                                        duetcontolserver 1.2.4.0
                                        duet runtime 1.2.4.0
                                        duetsd 1.0.5
                                        duet softwareframework 1.2.4.0
                                        duet tools 1.2.4.0
                                        duet webcontrol 2.0.7-1
                                        duet webserver 1.2.3.1
                                        Hope we are getting closer.
                                        The Duet Web Control 2 still says the DCS is still unavailable. Running on new Firefox download.
                                        • Danalundefined
                                          Danal
                                          This is what I get:
                                          duetcontrolserver 1.2.5.0
                                          duetruntime 1.2.5.0
                                          duetsd 1.0.5
                                          duetsoftwareframework 1.2.5.0
                                          duettools 1.2.5.0
                                          duetwebcontrol 2.0.7-1
                                          duetwebserver 1.2.3.1
                                          • Danalundefined
                                            Danal
                                            • Please do these exact commands. You can copy paste. The top group will take only seconds. The re-install takes one or two minutes.
                                            wget -q https://pkg.duet3d.com/duet3d.gpg
                                            wget -q https://pkg.duet3d.com/duet3d-unstable.list
                                            sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                                            sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                                            sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                                            sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                                            • Then re-run
                                            • Because of those first commands, it should show the same releases 1.2.5.0, etc, as shown above.
                                            • Also, please verify IP address as shown further above.
