    Keep losing Z offset
    1.1k
    • Weevilundefined
      Weevil @Turbo
      @Turbo I'll be damned. I threw a negative sign in front of the value and that seems to work. I am fine tuning now. Thanks.
      • Turboundefined
        Turbo
        Awesome!
        Cant stop tuning wont stop tuning.
        Dbot, Custom i3, Voron 0&2
        Weevilundefined 1 Reply Last reply Reply Quote 0
        • Weevilundefined
          Weevil @Turbo
          @Turbo It appears to still be an issue. I lost Z offset after last night's print. The settings are still there in config.g. Simply saving the file again without any changes restores the Z offset. Something is resetting my G31 numbers.
            What firmware are you using? What duet?
            Can you post your config.g and homeall?
            What do you have in your slicer start and end gcode?
            • Weevilundefined
              Weevil @Phaedrux
              @Phaedrux
              Board: Duet 3 MB6HC v0.6 or 1.0
              Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC4 (2020-03-16b1)
              Config.g:
              G90
              M83
              M550 P"MYTH3D"
              M667 S1
              ; Networking
              M552 P192.168.1.14 S1
              M553 P255.255.255.0
              M554 192.168.1.1
              M586 P1 S1
              M586 P2 S
              M552 S1
              M569 P0.0 S1
              M569 P0.1 S0
              M569 P0.2 S1
              M569 P0.5 S1
              M569 P0.3 S1
              M569 P0.4 S1
              M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5
              M350 X16 Y16 Z16 E16 I1
              M92 X78.74 Y78.65 Z394.04 E494.74
              M566 X900.00 Y900.00 Z12.00 E120.00
              M203 X6000.00 Y6000.00 Z180.00 E1200.00
              M201 X500.00 Y500.00 Z20.00 E250.00
              M906 X800 Y800 Z800 E800
              M84 S30
              M671 X-15:150:310 Y50:310:150 1S0.5
              M208 X0 Y0 Z0 S1
              M208 X300 Y300 Z500 S0
              M574 X2 S1 P"io5.in"
              M574 Y1 S1 P"io2.in"
              M950 S0 C"io7.out"
              M558 P9 C"io7.in" H5 F120 T6000
              G31 P500 X-38 Y0 Z0.75
              M557 X15:227 Y5:210 S50
              M308 S0 P"temp0" Y"thermistor" T100000 B4138
              M950 H1 C"out1" T0
              M143 H0 S280
              M950 F1 C"out7" Q500
              M106 P1 S1 H T45
              M950 F0 C"out8" Q500
              M106 P0 S255
              M501
              M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
              M563 P0 S"MYTHprint" D0 H1 F0
              M563 P0 D0 H1 F0
              G10 P0 X0 Y0 Z0
              G10 P0 R0 S0
              T0
              Homeall.g:
              G91
              G1 H2 Z5 F6000
              G1 H1 X305 Y-305 F2000
              G1 H1 X305
              G1 H1 Y-305
              G1 X-5 Y5 F6000
              G1 H1 X305 F360
              G1 H1 Y-305
              G1 X-150 Y150 F6000
              M558 F500
              G30
              M558 F50
              G30
              G32
              Slicer start code:
              G28
              Slicer end code:
              G91
              G1 H2 Z5 F6000
              G1 H1 X305
              G1 H1 Y-305
              G1 X-5 Y5 F6000
              G1 H1 X305 F360
              G1 H1 Y-305
              M104 S0
              M140 S0
              M84
              • fcwiltundefined
                fcwilt
                You can always reset in your "slicer start code" to be sure it is correct.
                  You've got g32 in your home all. What is in bed.g?
                  • Weevilundefined
                    Weevil @Phaedrux
                    @Phaedrux Bed.g:
                    ; bed.g
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Feb 20 2020 16:55:51 GMT-0800 (Pacific Standard Time)
                    G29 ; probe the bed and enable compensation
                    • JamesMundefined
                      JamesM
                      I'm no expert with firmware but comparing your homeall to mine, I have a G90 before calling any G30 commands...maybe an issue with relative vs absolute positioning???
                      This is my homeall.g
                      G91 ; relative positioning
                      G1 S1 X-350 Y350 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                      G1 S1 X-350 ; home X axis
                      G1 S1 Y350 ; home Y axis
                      G1 X5 Y5 F600 ; go back a few mm
                      G1 S1 X-10 ; move slowly to X axis endstop once more (second pass)
                      G1 S1 Y-10 ; then move slowly to Y axis endstop
                      G90 ; absolute positioning
                      G1 X170 Y160 F6000 ; go to first bed probe point and home Z
                      Weevilundefined 2 Replies Last reply Reply Quote 0
                      • Weevilundefined
                        Weevil @JamesM
                        @JamesM Thanks, I'll try that.
                        • Weevilundefined
                          Weevil @JamesM
                          @JamesM That one change threw the homing off. I reverted back to the original settings. Thanks anyway for the suggesstion.
                            Phaedrux Moderator @Weevil
                            @Weevil said in Keep losing Z offset:
                            I don't know what happened but now I keep losing my z offset each time the printer is homed, restarted or ends a print. I can't make sense of the thing.
                            What exactly do you mean by this? Do you mean that the first layer isn't good? Do you mean that G31 is literally blank?
                            But the head is too close to the bed now. I don't know what happened.
                            Head crash? Loose print head? Probe mount shifted?
                            I'd recommend removing G32 from your homeall. All it does is clear the current transform and then runs mesh compensation. May be overkill to re probe the entire bed every time you homeall. You could use G29 S1 instead at the end of homeall which would load a saved heightmap.
                            Change the P500 to P25 to make the BLTouch trigger a bit more sensitive.
                            Weevilundefined 1 Reply Last reply Reply Quote 1
                            • Weevilundefined
                              Weevil @Phaedrux
                              @Phaedrux I'll try that. Thanks.
