Duet Wifi Wlan vs WPA2 = Connection Error
As the titled say: i got a connection problem with my Duet Wifi. A friend and i configured the Board and linked it up to his home w-lan without any problem. We do all the necessary things to get the printer started and it worked.
When i get home, i just entering the commands as shown:
M552 S-1
M552
M552 S0
M552
M587 S“My SSID“ P“ My Password“
M587
M552 S1After that i get connection error (see protocol below). Several attempts later I changed the SSID and passwords but nothing worked.
So I decided to set up a WiFi HotSpot with my Galaxy S7 and zoom … the Duet connected to the Smartphone after 3 Secs.
So I tried to connected back to my home Wifi and get the typical message: error
I retry the Smartphone which was working fine and then decided to try a connection to my neighbors WiFi and again: zooom connection after 3 secs (ask for his Password and SSID)
I went further and enabled MAC in my Router Option … nothing … the only way for connecting was to disable the WPA / WPA2 protocol in my router and surprise: we get a stable connection after 3 secs …
Hopefully someone has a idea to fix this, I use a Vodafone Router with the newest firmware. Other devices as our smartphones, the normal HP printer and Smart- TV / TV- Stick work still fine with the router settings.
YAT Protocol
M552 S-1
WiFi module stopped
ok
M552 S-1
ok
M552 S0
ok
WiFi module started
M552 S1
ok
WiFi reported error: Timed out while trying to connect to DWTN
WiFi module is idle
WiFi reported error: no known networks found
WiFi module is idle
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6JKD0-3S46Q-TTFGP
Used output buffers: 2 of 24 (3 max)
Static ram: 25712
Dynamic ram: 93176 of which 0 recycled
Exception stack ram used: 304
Never used ram: 11880
Tasks: NETWORK(ready,1280) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
Owned mutexes:
Last reset 01:35:48 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11872 bytes (slot 3)
Error status: 0
Free file entries: 10
MCU temperature: min 24.0, current 26.2, max 27.0
Supply voltage: min 0.1, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Slowest loop: 99.79ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.34ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is changing mode
WiFi module is idle
Failed to get WiFi status
ok
Error retrieving WiFi status message: bad reply format version
WiFi module is idle
Failed to change WiFi mode (code -4)
- WiFi -
i think this is the second report of an incompatbility with vodafone routers. no solution as far as I know.
Doubt its relevant, but any special characters in the key?
No, just a standard Key like "A1234567b" (was my testing Key)
is the SSID hidden? that can sometimes cause issues
it wouldn't try to connect to DWTN without it specified on the M552 command if it was hidden
SSID is broadcasted
The Router know the MAC of the Duet
The Duet is remembering the SSID (and Password)Executing config.g...Error: M587: Failed to add SSID to remembered list
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
M552 S-1
WiFi module stopped
ok
M552 S0
ok
WiFi module started
M587
Remembered networks:
DWTN IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok -
@Warstone as @bearer said, there seems to be an issue with Vodafone Station routers. This may be related to an obscure bug in the Duet WiFi firmware. See this thread https://forum.duet3d.com/topic/14993/cannot-connect-duet-wifi-to-new-wifi-router
Ideally, use an access point to connect for now.
Hooked up my old D-Link Wifi router between the Vodafon router and my PC. It slows down my connection a bit, but the Duet is connecting without any problems to the D-Link instead of the Vodafon Router.
