Cannot connect Duet Wifi to new Wifi Router
  • Hey there,
    I've got a new wifi router. Now I cannot connect the Duet Wifi to the network.
    I followed this guide with no success: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
    Because the SSID is hidden, I included it in the M552 command when connecting, but I also tried with a broadcasted SSID.
    The Duet responds with:
    WiFi reported error: Timed out while trying to connect to GarMir 2,4GHz
    WiFi module is idle
    WiFi reported error: Unknown WiFi state while trying to connect to GarMir 2,4GHz
    WiFi module is idle
    The router logs:
    03/17/2020	20:29:36	MAC 2c:3a:e8:00:00:00 authentication with GarMir 2,4GHz; WG-MAC=D4:3F:CB:91:5F:69; IF=wlan0_0	Wi-Fi
    03/17/2020	20:29:36	MAC 2c:3a:e8:00:00:00 associated to GarMir 2,4GHz; WG-MAC=D4:3F:CB:91:5F:69; IF=wlan0_0	Wi-Fi
    03/17/2020	20:29:36	WG-MAC=D4:3F:CB:91:5F:69; STA-MAC=2c:3a:e8:00:00:00; IF=wlan0_0; SSID=GarMir 2,4GHz; ConnectionState=connected; WirelessMode=802.11n; LastTxPhyRate=52Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:0Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-33dBm; Channel=2412MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=0	Wi-Fi
    03/17/2020	20:29:34	REASON-CODE-DESCR=DISASSOC_STA_HAS_LEFT;REASON-CODE=8; WG-MAC=D4:3F:CB:91:5F:69; STA-MAC=2c:3a:e8:00:00:00; IF=wlan0_0; SSID=GarMir 2,4GHz; ConnectionState=other_deassociate; WirelessMode=802.11n; LastTxPhyRate=52Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:0Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-33dBm; Channel=2412MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=8	Wi-Fi
    03/17/2020	20:29:34	REASON-CODE-DESCR=DISASSOC_STA_HAS_LEFT;REASON-CODE=8; WG-MAC=D4:3F:CB:91:5F:69; STA-MAC=2c:3a:e8:00:00:00; IF=wlan0_0; SSID=GarMir 2,4GHz; ConnectionState=clientDisassociated; WirelessMode=802.11n; LastTxPhyRate=52Mbps; LastRxPhyRate=6Mbps; MaxSupportedRate:0Mbps; EncryptMode=AES; AuthMode=WpaPsk; RSSI=-33dBm; Channel=2412MHz; Radio=2.4G; Bandwidth=20M; TxFailPkts=0; RetransPkts=8	Wi-Fi
    03/17/2020	20:29:34	DISASSOC - MAC=2c:3a:e8:00:00:00, Reason=8; WG-MAC=D4:3F:CB:91:5F:69; IF=wlan0_0	Wi-Fi
    What can cause these problems? Are there any special chars not allowed in the SSID or password?
    I am not using " or ' but some special chars like , $ %
    Do I need to excape those and if yes: how?
    Best
    GaRv3
  • Your new router, is it a 5Ghz by chance?
    The Duet boards only support 2.4ghz.
    If there is an option to enable a 2.4 SSID, Try that.
    HTH
    Paul
  • See the attached logs.
    The wifi I am trying to connect to is 2.4 GHz.
  • My bad🤦
    You could try un-hiding the SSID temporarily to see if that helps.
    With the previous router, did it have the same SSID?
    If it did, clear the associations in the Duet and reconnect again, could be an authentication issue.
    P.
  • Moderator
    @GaRv3 what firmware version? Send M115 and post response. There’s a bug in early RRF 3 releases where the SSID password is not stored.
  • @GaRv3 said in Cannot connect Duet Wifi to new Wifi Router:
    afaik only ' is a problem, and ' is the escape key. see the note on
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
    reason=8 may suggest the key is stored in the duet and accepted by the access point.
    https://www.cisco.com/assets/sol/sb/WAP371_Emulators/WAP371_Emulator_v1-0-1-5/help/Apx_ReasonCodes2.html
  • @droftarts
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
    @bearer
    Yeah I knew ' too. That's why I wrote I don't have it in the SSID or pw.
    What does "sending STA is leaving or has left Basic Service Set (BSS)" on the page you linked mean? Incompatible protocol versions?
  • @PaulHew
    See my first post again "but I also tried with a broadcasted SSID" 😁
    And no, the SSID was not the same and I even tried using another SSID.
    not sure I found anything relevant, but it does suggest client side issue, most topics relate to signal quality and roaming.
    could be the wifi is confused after the hidden bssid, try clearing all stored networks and adding just the one? try:
    M552 S-1
    M552 S0
    M588 S"*"
    M587 S"GarMir" P"key"
    M552 S1 P"GarMir"
    Edit: also could you confirm your wifi is set to channel 1 as a fixed channel, not auto? (log said 2412MHz)
  • Moderator
    It would be good to update your firmware to the latest RRF2 version, 2.05.1. Get it from https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
    Update instructions, by copying file to SD card on your PC: https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_1
    So long as you have named the SSID correctly, it doesn't matter if it's hidden.
    How is the WiFi encryption set on the router? Duet 2 Wifi only supports WPA and WPA-2 with either AES or TKIP encryption (I think!). Maybe take a screenshot of the WiFi setup page on the router?
  • @droftarts said in Cannot connect Duet Wifi to new Wifi Router:
    also, the log suggest the client is leaving, after successfully having connected, so unlikely to be a encryption issue (unless I'm reading the log incorrectly)
  • @bearer
    Didn't help unfortunately.
    @droftarts
    As mentioned by @bearer , this should not be an encryption issue. Router is set to WPA2 and encryption mode is AES.
    I will try this next.
    mkay, still, try to make sure there arent more than one entry if you do make changes, just to rule out that going forward.
    maybe its time to elaborate a little on the pysical conditions of the network. locations, other APs etc?
  • I will go into detail about this if the firmware update does not solve the issue.
    But I've got a question about the fallback update procedure. There is no "iap4e.bin" in the repo but the guide tells me to copy it over. Should I simply leave the old file in place?
  • Moderator
    Check this release for the iap files https://github.com/dc42/RepRapFirmware/releases/tag/2.03
    it won't do any harm, and will be needed if you should ever wish to downgrade. however as 2.03 is likely using wifi firmware 1.23 i doubt there is any change relevant to the issue; but won't hurt to be up to date. while you're at it do confirm the wifi firmware is 1.23. (its part of the M122 output.
  • Ok, so I updated the frimware and Wifi server:
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-95BLL-N6PSS-6J1F0-3S86R-90TVM
    Used output buffers: 1 of 24 (1 max)
    Static ram: 25712
    Dynamic ram: 93132 of which 0 recycled
    Exception stack ram used: 264
    Never used ram: 11964
    Tasks: NETWORK(ready,540) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:04:44 ago, cause: software
    Last software reset at 2020-01-26 16:51, reason: User, spinning module GCodes, available RAM 11284 bytes (slot 0)
    Error status: 0
    Free file entries: 10
    MCU temperature: min 24.3, current 27.3, max 27.4
    Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Cache data hit count 513307291
    Slowest loop: 4.16ms; fastest: 0.05ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 1173.89ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    - WiFi -
    Network state is changing mode
    WiFi module is trying to connect
    WiFi firmware version 1.23
    WiFi MAC address 2c:3a:e8:0b:17:0f
    WiFi Vcc 3.32, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 27928
    The problem persists.
    About the physical conditions:
    The printer is right next to the router (ap) with one wall in between. The signal strength should be easily sufficient with the 2.4GHz wifi. I even get full 5GHz signal strength right next to the printer on my phone.
    There are many wifi signals around here. It's a pretty crouded place. But I made sure to use the wifi channel that has the fewest SSIDS. Currently it's 2AM and there should be near to no interference.
    is it a fixed channel (not auto?), if auto it could be the Duets wifi module cannot follow across all channels due to differing country regulations, but I have no idea whats set for either product.
    re signal strength, see if you can run M122 repeatedly and catch the Duet in a moment where it is connected and shows its signal strength, it will likely have (significantly) lower receive sensitivity than your router (and phone)
  • It's channel 11 fixed.
    M122 always reports
    Doesn't seem I can get a report in the very short time frame, when a connection is established.
    But I am shure, the signal strength is very good. This can't be the issue. I can easily establish a very good wifi connection two rooms further from the router with any device.
    Channel=2412MHz;
    does not compute, but might not be relevant as its usally 12-14 that gives problems.
    Don't underestimate the ESP8266 module's ability to not get a signal; after all as it stands the options are defective module or poor singal as far as I can tell.
  • Some more information on the 2.4GHz wifi:
    SSID: GarMir 2,4GHz
    SSID broadcast: off
    Security: WPA2
    Wifi mode: Mixed 802.11 g/n
    Channel: 11
    Bandwidth: 20/40 MHz
    By the way: Sometimes I can see the Duet in my router status as
    IPv4: 192.168.0.37
    IPv6:
    MAC: 2C:3A:E8:0B:17:0F
    WiFi: 2.4GHz
    with full signal strength.
  • If its inconvenient to move the printer you could try switching roles; put the Duet in AP mode and see what signal strength you get where the router is (although it won't quite be an apples to apples thing).
    https://duet3d.dozuki.com/Wiki/Gcode#Section_M589_Configure_access_point_parameters
    what it transmits and what it receives could differ by a lot tbh.
  • Yeah, but to be honest, this should really not be a thing.
    The physical distance between the router and the Duet is maybe 0.5m. It's literally just this one wall in between.
    I will actually try to remove the special chars from the wifi SSID and password now to see if this could be a thing.
    Edit: No success
  • All I'm saying is the Duet people are normally more than willing to replace faulty boards, but I'd hate to see you waste time with a replacement if the problem isn't the board; which I don't think is the case but thats just my $0.02.
