    Duet 2 wifi calibration - Anycubic Predator
    770
    • Danalundefined
      Danal
      Ah, six, but only four populated. Forget what I said about six, above
      • gpermanundefined
        gperman @Carlo
        @Carlo said in Duet 2 wifi calibration - Anycubic Predator:
        This is how my Predator motors are wired to Duet2
        Thanks
        C
        That is how mine is wired now.
          droftarts administrators @Carlo
          @Carlo There's no way to know if that is the correct order for the wires. It depends on the internal wiring of the motor.
          You need to plug the loom into the motor, and check continuity at the connector on the Duet end. You should have continuity between pin 1 and 2, and between pin 3 and 4, but not any other eg pin 1 to 3 or 4.
          See https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
          Carloundefined 1 Reply Last reply Reply Quote 0
          • gpermanundefined
            gperman
            @Danal said in Duet 2 wifi calibration - Anycubic Predator:
            Phases sound OK.
            You say those are six wire motors. Normally, the two extra wires are "center taps". Which would not be used on a Duet. I'm trying to think of a good way to verify that we have the coil (phase) pairs, and not the center taps. You sound like you grasp all this pretty well, and it is probably enough for me just to say "be sure we don't have a center tap".
            Do you happen to have any other stepper motors? Or stepper drivers? Time to do some very basic "swap and verify" things...
            I don't have spare drivers, I have a spare 4 wire stepper and a spare 6 wire, neither are the same unlabelled type steppers Anycubic supplies.
            • Danalundefined
              Danal @gperman
              @gperman said in Duet 2 wifi calibration - Anycubic Predator:
              Phases sound OK.
              You might try one of those plugged into the Duet, just to see if it turns smoothly, or makes the same noise. I'd unplug all the other steppers, just for debugging.
              Power off when changing motor plugs, of course.
              • Carloundefined
                Carlo @droftarts
                @droftarts
                I was simply illustrating the 4 vs 6 wire on the predator motors and made no mention of how to wire...
                Thanks
                • gpermanundefined
                  gperman
                  Solved one issue.
                  One wire on the wire harness for the X tower wire was severed at the molex crimp underneath the insulation. Recrimped. Homes fine. Moving axes works fine.
                  Still running through other procedures and need to dial in bed leveling which I haven't tried yet.
                  I'm still having issues with the wifi module not turning on intermittently upon startup. For some reason, this also doesn't allow my PanelDue to send commands either. Display works but does not send commands to the main board.
                  This forces me to need to reinstall the firmware but only after I open up the top case and pull the power in leads to the duet main board. Otherwise, I cannot connect, even if I unplug the external wire to the switch/power supply. It's very tedious and has happened to me 3 times since owning the board.
                  DuetWifiServer.bin firmware version 2.04
                  • Danalundefined
                    Danal
                    PanelDue interface is a serial port (UART) that is part of the processor. WiFi interface is SPI. In other words, they are very separate. Both of them not responding is an indicator of a deeper problem.
                    Power supply ok? Things like that.
                    gpermanundefined 1 Reply Last reply Reply Quote 0
                    • gpermanundefined
                      gperman @Danal
                      @Danal
                      The main switch is funky. Sometimes doesn't fully engage and will not fully boot before the system shuts off and I need to rethrow the switch. I can play around with that possibly. What should I look for/test for a bad power supply?
                      If I need to connect to the main board to install new software, it seems that I can't do it without physically pulling the DC VIN wires into the board. Unplugging the external AC in plug doesn't seem to work. When connecting VIA terminal I get Incoming bluetooth module instead of usbmodem1411
                        @Carlo Sorry, replied thinking you were the OP.
