    Webserver won't start
    Duet Web Control
    2.9k
    • Haffwalkerundefined
      Haffwalker
      Hi, unfortunatly, I do not get "Network running, IP adress = ..."
        A Former User
        That would suggest an issue with DHCP, client or server cant say for sure.
        What you can do, is replace the Duet with your computer. Disable any Wifi connection, connect the same Ethernet cable that was in the Duet to you computer, no changes to anything else and see if your computer gets an IP address from your router.
          Haffwalker
          I just tried the cable, and it works with my computer.
            A Former User
            If thats the case then there is either a bug or incompatibility with the firmware's DHCP client or there is something wrong with the board.
            The assumption is that the link status leds suggest there isn't a problem with auto negotiation, and the computer confirms the ethernet cable and port on the router and DHCP service on the router is working.
              Haffwalker
              Hmm thats unfortunate...it is basically a brand new board (I got it like a year ago, but never had the chance to put it on any of my machines) but other than that it is literally brand new...
              Also I can`t be the only one, who runs into troubles with Duet 2 Ethernet+RRF 3.0....do you have any suggestens what to try/do next? If I remember correctly, the ethernet modules are also available as a spare part...maybe I should get one of those and try again.
                Haffwalker
                Is it possible, that when I erased the board, that any kind of firmware which is supposed to run on the ethernet module got deleted as well? Maybe I have to flash firmware on that thing too?
                droftartsundefined A Former User? 2 Replies Last reply Reply Quote 0
                • Dougal1957undefined
                  Dougal1957 @Haffwalker
                  @Haffwalker I note you said you formatted the SD Card you did install all the Config files as well as the DWC Files didn't you?
                  Can you post your Config.g file from the SD Card
                  Doug
                    Haffwalker
                    Hi, SD looks like this:
                    Inside of www:
                    And my config.g looks like this:
                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Jan 28 2020 00:41:51 GMT+0100 (Central European Standard Time)
                    M550 P"AKLP Plus+" ; set printer name
                    M665 R135.4 L267 B118 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P1 S0 ; physical drive 1 goes forwards
                    M92 X80.00 Y80.00 Z80.00 E418.50 ; set steps per mm
                    M566 X250.00 Y250.00 Z800.00 E200.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X2000.00 Y2000.00 Z2000.00 E1000.00 ; set accelerations (mm/s^2)
                    M906 X1100 Y1100 Z1100 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 Z-20 S1 ; set minimum Z
                    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                    M558 P5 C"e0stop" H5 A3 F360 T6000 ; set Z probe type to switch and the dive height + speeds
                    G31 P500 X0 Y0 Z16.254 ; set Z probe trigger value, offset and trigger height
                    M557 R110 S19 ; define mesh grid
                    M950 F0 C"fan0" ; create fan 0 on pin fan0 and set its frequency
                    M950 F1 C"fan1" ; create fan 1 on pin fan1 and set its frequency Hotend Cooler
                    M106 P1 S127 H1 T50 ; set fan 1 value. Thermostatic control is turned on Hotend Cooler ab 50°C mit 12V
                    M563 P0 S"Hotend 1" D0 H1 F0 ; define tool 0
                      droftarts administrators @Haffwalker
                      @Haffwalker Reading through the thread, it doesn't seem that this is a Duet-related problem, I think more likely is that the TL-WR802N is blocking http requests to the Duet from the network. What settings are there to configure it?
                      To test the Duet, if you can move it to plug the ethernet directly into your main router, using a USB power adapter to power it, you should be able to access it.
                        Haffwalker
                        Hi, yes I already took the WR802N out of the equation - the Duet is currently directly plugged into my router.
                          Dougal1957 @droftarts
                          @droftarts I think his M552 line is wrong for an Ethernet version should it not have P0.0.0.0 to tell it to pick up an address via DHCP also not sure if you really need the S1 to enable it as well
                            A Former User @Haffwalker
                            @Haffwalker said in Webserver won't start:
                            The firmware relating to the network is part of the Duet's RepRap firmware which you have at v3.0, so no. As far as replacing the Ethernet module its a possibility, but I'd be surprised to see it make a difference.
                            To get to the bottom of whats going on we'd need something like a wireshark log of the traffic, which is a bit difficult to do without a bridge or managed switch with a mirror feature as far as I can tell.
                            I suppose you can as a last effort set up a static IP address on your computer using the same ethernet cable (and no wifi), then set up the Duet 2 Ethernet with the same address and see if it works to rule out issues with DHCP (but its such a simple, tried and true protocol that incompatibilities are rare)
                              A Former User @Dougal1957
                              @Dougal1957 said in Webserver won't start:
                              He's supposedly tried the Duet without the SD card and thus no config, using only M552 S1
                                Okay! Sorry, just catching up...
                                Quite right. M552 should be M552 P0.0.0.0 S1 for DHCP, or for a fixed IP address, set the address using the P parameter.
                                  @droftarts I think his config is the one from his WiFi first post says he swapped them over it's one of those little things that catch us all out from time to time!
                                    A Former User
                                    @droftarts said in Webserver won't start:
                                    see my post https://forum.duet3d.com/post/142097 Duet2Ethernet, no SD card, only send M552 S1 gets IP from DHCP server no problem. M552 P0.0.0.0 S1 will also work, but isn't needed unless to override a stored/configured static IP for a Wifi network afaik.
                                      Haffwalker
                                      Well about the M552 P0.0.0.0 S1...I already tried that but it didnt make any difference...even if I specify an IP address eg. 192.168.0.14, it won´t work...I double and triple checked with my router and that IP isn`t occupied by any other device.
                                        @Haffwalker what's in your Config-overide.g?
                                        Haffwalkerundefined 1 Reply Last reply Reply Quote 0
                                          Haffwalker @Dougal1957
                                          @Dougal1957 SD card isn't plugged in right now.
                                            A Former User
                                            With the risk of repeating myself, its not a config issue if it doesn't work with the SD card removed.
