    Webserver won't start
    Duet Web Control
    2.9k
    • Haffwalkerundefined
      Haffwalker
      Hi, SD looks like this:
      Inside of www:
      And my config.g looks like this:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Jan 28 2020 00:41:51 GMT+0100 (Central European Standard Time)
      M550 P"AKLP Plus+" ; set printer name
      M665 R135.4 L267 B118 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P1 S0 ; physical drive 1 goes forwards
      M92 X80.00 Y80.00 Z80.00 E418.50 ; set steps per mm
      M566 X250.00 Y250.00 Z800.00 E200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z2000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1100 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z-20 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P5 C"e0stop" H5 A3 F360 T6000 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z16.254 ; set Z probe trigger value, offset and trigger height
      M557 R110 S19 ; define mesh grid
      M950 F0 C"fan0" ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" ; create fan 1 on pin fan1 and set its frequency Hotend Cooler
      M106 P1 S127 H1 T50 ; set fan 1 value. Thermostatic control is turned on Hotend Cooler ab 50°C mit 12V
      M563 P0 S"Hotend 1" D0 H1 F0 ; define tool 0
        droftarts administrators @Haffwalker
        @Haffwalker Reading through the thread, it doesn't seem that this is a Duet-related problem, I think more likely is that the TL-WR802N is blocking http requests to the Duet from the network. What settings are there to configure it?
        To test the Duet, if you can move it to plug the ethernet directly into your main router, using a USB power adapter to power it, you should be able to access it.
          Haffwalker
          Hi, yes I already took the WR802N out of the equation - the Duet is currently directly plugged into my router.
          • Dougal1957undefined
            Dougal1957 @droftarts
            @droftarts I think his M552 line is wrong for an Ethernet version should it not have P0.0.0.0 to tell it to pick up an address via DHCP also not sure if you really need the S1 to enable it as well
              A Former User @Haffwalker
              @Haffwalker said in Webserver won't start:
              Is it possible, that when I erased the board, that any kind of firmware which is supposed to run on the ethernet module got deleted as well? Maybe I have to flash firmware on that thing too?
              The firmware relating to the network is part of the Duet's RepRap firmware which you have at v3.0, so no. As far as replacing the Ethernet module its a possibility, but I'd be surprised to see it make a difference.
              To get to the bottom of whats going on we'd need something like a wireshark log of the traffic, which is a bit difficult to do without a bridge or managed switch with a mirror feature as far as I can tell.
              I suppose you can as a last effort set up a static IP address on your computer using the same ethernet cable (and no wifi), then set up the Duet 2 Ethernet with the same address and see if it works to rule out issues with DHCP (but its such a simple, tried and true protocol that incompatibilities are rare)
                A Former User @Dougal1957
                @Dougal1957 said in Webserver won't start:
                He's supposedly tried the Duet without the SD card and thus no config, using only M552 S1
                  Okay! Sorry, just catching up...
                  Quite right. M552 should be M552 P0.0.0.0 S1 for DHCP, or for a fixed IP address, set the address using the P parameter.
                    @droftarts I think his config is the one from his WiFi first post says he swapped them over it's one of those little things that catch us all out from time to time!
                      A Former User
                      @droftarts said in Webserver won't start:
                      see my post https://forum.duet3d.com/post/142097 Duet2Ethernet, no SD card, only send M552 S1 gets IP from DHCP server no problem. M552 P0.0.0.0 S1 will also work, but isn't needed unless to override a stored/configured static IP for a Wifi network afaik.
                        Haffwalker
                        Well about the M552 P0.0.0.0 S1...I already tried that but it didnt make any difference...even if I specify an IP address eg. 192.168.0.14, it won´t work...I double and triple checked with my router and that IP isn`t occupied by any other device.
                          Dougal1957 @Haffwalker
                          @Haffwalker what's in your Config-overide.g?
                          Haffwalkerundefined 1 Reply Last reply Reply Quote 0
                            Haffwalker @Dougal1957
                            @Dougal1957 SD card isn't plugged in right now.
                              A Former User
                              With the risk of repeating myself, its not a config issue if it doesn't work with the SD card removed.
                                Dougal1957 @A Former User
                                @bearer I think you'll find that the duet won't come up at all without an SD Card inserted but I am prepared to be proved wrong
                                  @bearer said in Webserver won't start:
                                  see my post https://forum.duet3d.com/post/142097 Duet2Ethernet, no SD card, only send M552 S1 gets IP from DHCP server no problem. M552 P0.0.0.0 S1 will also work, but isn't needed unless to override a stored static IP for a Wifi network afaik.
                                  there you go; proven wrong. (i.e. the whole session from the serial terminal is shown, M552 is send over serial to rule out other config issues)
                                    @Haffwalker At some point you changed from 3.01-RC5, which got an IP address, to 3.0, which doesn't. At what point did you also disconnect the TL-WR802N?
                                    Just for completeness, can you downgrade to 2.05.1, and try connecting again, without SD card?
                                    Haffwalkerundefined 2 Replies Last reply Reply Quote 0
                                      @bearer I Stand corrected I know that wouldn't work several years back.
                                        Haffwalker @droftarts
                                        @droftarts I will downgrade to 2.05.1 now, will let you know how if it works.
                                          Haffwalker
                                          Didn´t help...
                                            @droftarts During my initial setup everything seemed to work nicely - duet got an IP and dwc was working. Then I unplugged everything - put it into the printer/attached cables and when I powered it up, it didnt work anymore. After that I got rid of the WR802N and connected it directly with my router and also I did downgrade from 3.01RC5 to RRF3.0 and now 2.05.
