    Help with DWC layer chart
    Duet Web Control
    1.1k
    • Marco Bonaundefined
      Marco Bona @droftarts
      @droftarts , sorry I said badly, how can I move the Z at the end of the program without changing object heigh and keeping the layer chart correct?
      If there is a solution, otherwise I delete the line in the program.
      deckingmanundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        deckingman @Marco Bona
        @Marco-Bona said in Help with DWC layer chart:
        When there is a G1 Z command in your end gcode to raise the print head when the print is complete, and that command is confusing the object height detection, the remedy is to add a comment starting with ;E to that line.
          droftarts administrators @Marco Bona
          @Marco-Bona Like I said, you just have to add 'E' to the comment. You can still do the move. You just have to disrupt the way RRF reads the file to extract information. I'm not sure why it's looking at that, rather than using the statistics at the beginning of the file:
          ;FLAVOR:RepRap
          ;TIME:7463
          ;Filament used: 15.047m, 0m
          ;Layer height: 0.2
          ;MINX:-63.44
          ;MINY:-78.44
          ;MINZ:0.2
          ;MAXX:63.44
          ;MAXY:78.44
          ;MAXZ:7
          ;Generated with Cura_SteamEngine 4.5.0
          Where MAXZ = 7. I'll ask @dc42.
          Also, just noticed; you probably want to flip the order of these two lines, so G90 is before G28:
          G28                      ;homing all axes
          G90                      ;absolute positioning
            Marco Bona
            Very clear, thanks again for the informations
              @Marco-Bona If you don't want to put 'E' in the comment, you could change the G1 Z370 F1200 move to a relative move, because that's the other way RRF will ignore it. While this may cause a move beyond the length of the carriage (eg if the print stops at 100mm, and you move +370mm, it will ask to move to Z470), but if you have your axis limits set correctly, it shouldn't matter, and it will stop at the Z axis limit, which I assume is Z370. eg:
              M117 Finishing Up        ;write Finishing Up
              M104 S0                  ;extruder heater off
              M140 S0                  ;bed heater off (if you have it)
              G91                      ;relative positioning
              G1 Z370 F1200            ;go to Z+370
              G1 E-1 F300              ;retract the filament a bit, to release some of the pressure
              G1 E-5 F9000             ;retract filament even more
              M84                      ;steppers off
              M117 Print finished      ;write Print finished
              I assume your Z axis homes at maximum Z (Z370) rather than minimum Z (Z0)? If it homes at Z0, you probably only want to home X and Y, not all axes (G28), or the print may strike the nozzle/X axis.
                Marco Bona
                The origin of the machine where I have the sensor is at Z374, then it is the IR probe that zeroes the axis for the first layer.
                However I corrected the lines in the print file but I continue to have problems with the correct visualization of the layers.
                I also tried to restart the machine but I still have some problems.Layer.png
                  @Marco-Bona Okay, post another file (perhaps the one shown printing) and I'll take a look. Can you remind me what firmware version you are on, by sending M115 and posting the response.
                    Marco Bona
                    @droftarts , The firmware is RRF3.01 RC5 while the version of the DWC is 2.0.7.
                    If it can help, I noticed that at the end of the print the Layer chart is not reset, so in the next print I believe that I continue to display the layer of the previous print.
                    The strange thing is that it always stops on the second layer.
                    I send you a couple of print files, surely I would have been wrong to insert something in cura even if I don't notice anything strange in the gcode.
                    HA_Bridge01F.gcode
                    HA_Mast.gcode
                    HA_Bridge02.gcode
                    Marco Bonaundefined 1 Reply Last reply Reply Quote 0
                      Marco Bona @Marco Bona
                      M115
                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC5 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2020-03-27b3
                        @Marco-Bona Actually, I'm mid-print, and experiencing exactly the same thing with 3.01-RC5 and DWC 2.0.7!
                        I just checked with @dc42, and he has confirmed this is a bug in RRF 3.01-RC5. It counts the start of the print from when the printer was turned on! Will be fixed in next release. If this is important to you, and you don't need changes in RC5, revert to 3.01 RC4 firmware.
                          @droftarts, Thanks for the reply, you took a heavy weight off me.
                          Viewing the layers is not a problem, I will wait for the next build, but at least I know that my cura file is correct.
                          Thanks again!!
                          • chrishammundefined
                            chrishamm administrators
                            If this issue still persists in DSF 2.1.1 and RRF 3.01-RC6, please provide some more details. Do you leave the web interface running in the background or do you close it, open it back up, and then it is no longer updated? How can you reproduce this?
                            Duet software engineer
                              Marco Bona @chrishamm
                              @chrishamm, I'm using Duet Wifi for the moment, I don't have DSF.
                                Marco Bona
                                If it can help, this morning I noticed that after power on, the DWC print starts from layer 0, performs homing, probing and head cleaning cycle but when the first layer (layer0) starts, it is in progress that the layer2 / XX and does not change.
                                I saw that a new DWC build has come out, tomorrow I install and check it.
                                  Marco Bona
                                  @droftarts, @chrishamm , @dc42, I updated the DWC to 2.1.1, but the problem persists.
                                  I found what causes the error, this line in the startup script
                                  G1 X-137 E25 F500         ;move to X-137 and extrude 25mm of feed stock
                                  creates some problems. It seems that after deleting the first part of the command is working properly
                                  G1 E25 F500         ; extrude 25mm of feed stock
                                  If it cannot be solved, it is not a problem for me to bleed the nozzle while holding the head steady.
                                  I point out that at the beginning of the printing, the estimation of the layers is still incorrect, it is then corrected around the tenth layer.
                                    Can you post the entirety of your slicer start gcode?
                                    One way to work around it is to move some or all of the slicer start gcode into start.g in the /sys folder. Start.g will be run at the start of every print before any of the sliced gcode file is executed. Same can be done with stop.g and the ending slicer gcode. Stop.g is called by M0 when present. So the slicer end gcode can simply have M0.
                                    start.g in combination with other macros called with M98 can allow you to have most of the print prep gcode live outside of the slicer. This has the benefit of making it mostly slicer agnostic so you can use multiple slicers and only need to change the start code in a single place, and it's a workaround for any issues DWC may have when scanning the gcode file.
                                    For example, my start.g does a preheat and homing, then passes off to the slicer start gcode to get the heater temps set for printing, then it calls a macro to prime wipe the nozzle and then starts the print. At the end of the print M0 is run to call stop.g which then does a cool down cycle, etc.
                                      Marco Bona @Phaedrux
                                      @Phaedrux , there he is:
                                      M117 Preparing            ;write Preparing
                                      G4 S2                     ;delay 2 seconds
                                      M140 S60                  ;set bed temperature and move on
                                      M141 S0                  ;set heated chamber temperature and move on
                                      M104 T0 S195              ;wait for the extruder to reach desired temperature
                                      M107                      ;start with the fan off
                                      G28                       ;home all axes
                                      T0                        ;select tool 0
                                      G1 X-23 Y-24 F10000       ;go to the center of bed
                                      G1 Z10 F1000              ;E go to Z10
                                      M107 P0                   ;turn off leds
                                      G30 X-23 Y-24 S-2 H1.915  ;probe current position and ajust Z offset
                                      G1 Z40 F1000              ;E go to Z40
                                      M106 P0 S1                ;turn on leds
                                      T0                        ;reset current tool
                                      M584 P4                   ;apply custom setting
                                      G1 X-137 Y160 F10000      ;go to X-137 Y160
                                      M117 Spray print adhesive ;write Spray print adhesive
                                      M226                      ;pause
                                      M190 S60                  ;wait for the bed to reach desired temperature
                                      M109 S205                 ;wait for the extruder to reach desired temperature
                                      G1 U130 F10000            ;go to U130
                                      G92 E0                    ;reset the extruder position
                                      G1 E-4 F5000              ;retract 4mm
                                      G1 X-187 F500             ;go to X-187
                                      G1 Y165 F500              ;go to Y165
                                      G10                       ;retract
                                      G1 X-137 F500             ;go to X-137 and clean nozzle
                                      G1 XO Y0 U0 F10000        ;go to X0 Y0 U0
                                      M584 P3                   ;apply custom setting
                                      G21                       ;metric values
                                      M117 Print starting       ;write Print starting
                                      G1 E4 F500                ;unretract 4mm
                                      G11                       ;unretract
                                      I was considering doing operations using subprograms.
                                      I have to find some time to write and try them.
