    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.7k
    • ChrisPundefined
      ChrisP @chas2706
      @chas2706 Did power cycling fix that issue for you? It did for me. MInd you, even when that works, the printer is still unusable.
      A colleague of mine is just upgrading an E3D toolchanger to the same Duet3 + SBC setup, has just updated before we saw all this and is now in the same situation. (edit: post below)
      • elliott.griffithsundefined
        elliott.griffiths @tobias_munich
        @tobias_munich I got the same behaviour after updating.
        tobias_munichundefined 1 Reply Last reply Reply Quote 0
          A Former User @ChrisP
          @ChrisP said in RepRapFirmware 3.01-RC6 released:
          drive is unmounted
          by the sound of it its unable to load the config.g so that could explain why nothing else works.
          could you also try doing ls -l /opt/dsf/sdand ls -l /opt/dsf/sd/sys in an ssh shell to see what permissions you have?
          edit: or did the power cycle solve it?
          ChrisPundefined 1 Reply Last reply Reply Quote 0
          • tobias_munichundefined
            tobias_munich @elliott.griffiths
            @elliott-griffiths it’s frustrating.
            After setting it up from scratch.
            Means... downloading the current image, and setup a new sd...
            still issues.
            Stand-alone with SD, no problem.
            But the SBC version.
            After starting with the new image the sbc connects to the duet. So far so good.
            DWC is able to acces the virtual SD with all folders.
            But after uploading the config.g to the sys folder and rebooting,
            the system has problems to access to the virtual SD with a lot of error messages .
            It’s not able to read and access any folder of the virtual SD
            It’s so frustrating
            Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
            Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
            Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
            • ChrisPundefined
              ChrisP @A Former User
              @bearer said in RepRapFirmware 3.01-RC6 released:
              drive is unmounted
              Thanks for picking this up, but that is not the porblem at this point. I've only seen that error once immediately after update and after power cycle, that hasn't happened again.
              Everything now seems to load and I can see all the files on the interface, however, it's still not booting properly. After a reinstall, I'm still getting a persistant "busy" state and no the tools show the bed, but not the extruder, temperature chart still sows both. Pressing emergency stop now seems to work, but then nothing is listed in the tools and it still sits being "Busy" - see image.
                A Former User @tobias_munich
                @tobias_munich said in RepRapFirmware 3.01-RC6 released:
                care to share the file and/or try a empty file?
                  tobias_munich @A Former User
                  @bearer I tried a lot of ways ....
                  And after all the tests I made it seems it’s a problem with the virtual SD.
                    no doubt about it, just curious if its the content or presence of the config.g file that makes a difference; as it seemed it did make a difference from your earlier post.
                    • ChrisPundefined
                      ChrisP
                      I'd also be interested to see what (if any) errors you have in the log for the DCS service:
                      sudo journalctl -u duetcontrolserver.service
                      Because I get a massive log full of this repeating. So I guress it's to do with my laser filament monitor in this case.
                      Apr 03 22:20:52 starttex DuetControlServer[359]: [error] Failed to merge JSON: {"key":"","flags":"d99fn","result":{"boards":[{"mcuTemp":{"current":47.2},"v12":{"current":11.3},"vIn":{"current":12.0}}],"fans":[{"actualValue":0,"requestedValue":1.00,"rpm":0},{"actualValue":0,"requestedValue":0,"rpm":-1}],"heat":{"heaters":[{"active":50.0,"current":20.5,"standby":0,"state":"standby"},{"active":200.0,"current":23.0,"standby":0,"state":"off"}]},"inputs":[{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":2450,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"}],"job":{"build":null,"duration":null,"filePosition":0,"layerTime":null,"timesLeft":{"filament":null,"file":null,"layer":null}},"move":{"axes":[{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"requestedSpeed":0,"topSpeed":0},"extruders":[{"position":0,"rawPosition":0}],"speedFactor":1.0},"sensors":{"analog":[{"lastReading":20.5},{"lastReading":23.0}],"endstops":[{"triggered":false},{"triggered":false},{"triggered":true}],"filamentMonitors":[{"filamentPresent":null}],"inputs":[{"value":null},{"value":true}],"probes":[{"value":[1000]}]},"seqs":{"boards":0,"directories":0,"fans":4,"heat":7,"inputs":1,"job":0,"move":13,"network":3,"reply":0,"sensors":2,"spindles":0,"state":0,"tools":5,"volumes":0},"spindles":[{"current":0},{"current":0}],"state":{"atxPower":null,"currentTool":-1,"laserPwm":null,"nextTool":-1,"previousTool":-1,"status":"idle","upTime":779},"tools":[{"active":[200.0],"standby":[0],"state":"off"}]}}
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    System.Text.Json.JsonException: Failed to deserialize property [FilamentMonitor].FilamentPresent (type Boolean) from JSON null
                      Apr 03 22:20:52 starttex DuetControlServer[359]:  ---> System.Text.Json.JsonException: The JSON value could not be converted to System.Boolean. Path: $ | LineNumber: 0 | BytePositionInLine: 4.
                      Apr 03 22:20:52 starttex DuetControlServer[359]:  ---> System.InvalidOperationException: Cannot get the value of a token type 'Null' as a boolean.
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.Utf8JsonReader.GetBoolean()
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.Serialization.Converters.JsonConverterBoolean.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonPropertyInfoNotNullable`4.OnRead(ReadStack& state, Utf8JsonReader& reader)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.HandleNull(Utf8JsonReader& reader, ReadStack& state)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    --- End of inner exception stack trace ---
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.ThrowHelper.ReThrowWithPath(ReadStack& readStack, Utf8JsonReader& reader, Exception ex)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 287
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                      Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                      Edit: and sure enough, commenting out my filament monitor in the config.g and everything (except for the filament monitor) is working again. Think this is one for @chrishamm .
                      • chas2706undefined
                        chas2706
                        How can you say that power cycling fixed it for you if the printer is still unusable?
                        • ChrisPundefined
                          ChrisP @chas2706
                          @chas2706
                          Because power cycling fixed that issue (ie. the drive mounted and read file and config etc), but after rebooting it hit a different bug (mentioned in my post above) that still rendered the printer unusable at that point.
                          • chas2706undefined
                            chas2706
                            Ok that's an improvement but for me power cycling, resetting or re-installing made no difference.
                            I've had to revert to RRF3.01RC3 but now running on the wrong version of DWC because there is no indication anywhere how we SBC users can download a specific version of DWC.
                            A Former User? ChrisPundefined 2 Replies Last reply Reply Quote 0
                            • chas2706undefined
                              chas2706
                              This has learnt me a big lesson. Always, always, always make a current back up before you download a "new release"! My latest back up was from a few previous releases.
                                A Former User @chas2706
                                edit: NOPE, that was not a good idea.
                                maybe this works better, specifying all the packages to fulfill dependencies for duetsoftwareframework=1.2.5.0
                                grep duet3d -r /etc/apt | grep unstable && sudo apt install  duetcontrolserver=1.2.5.0 duetsd=1.0.5 duettools=1.2.5.0 duetwebserver=1.2.3.1 duetwebcontrol=2.0.7-1 reprapfirmware=1.2.5.0-1 duetruntime=1.2.5.0 duetsoftwareframework=1.2.5.0 || echo Please swtich to unstable list.
                                edit changed to fail if not on unstable list.
                                Also according to chrishamm switching to instead of adding the unstable list may be the way to go
                                #comment out stable list
                                sudo sed -i '/ stable/s/^/#/g' /etc/apt/sources.list.d/duet3d.list
                                #add unstable list
                                echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                                • ChrisPundefined
                                  ChrisP @chas2706
                                  @chas2706 said in RepRapFirmware 3.01-RC6 released:
                                  As @bearer pointa out, rolling back isn't tricky. Tbh, theres a reason that it's a beta firmware, so it should be obvious that backups are wise when trying a new "upgrade".
                                  I'd still be interested to know the output of you logs for the DCS service.
                                    A Former User
                                    the start of the log is probably more relevant than the end of it.
                                    • chas2706undefined
                                      chas2706
                                      I understand the meaning of beta firmware but if you have Duet3 with SBC and dare to "upgrade" there is no guarantee that if upon failure an older backup will work.
                                      I now have this problem running RRF3.01.RC3 from a backup:
                                      So now I will be spending numerous hours starting afresh!
                                      A Former User? ChrisPundefined 3 Replies Last reply Reply Quote 0
                                        that would imply your backup isn't covering your needs. simply shutting down the pi and cloning or imaging the SD card would take care of all but the RRF firmware on the Duet which can be flashed after restoring an old SD card. (caveat if they changed the iap binary)
                                        • ChrisPundefined
                                          ChrisP @chas2706
                                          @chas2706
                                          You really shouldn't need to start afresh. Even if you do, as long as you have a copy of the sys & macros folders it should take longer to burn a new raspbian image than it does to get that fresh Linux install to a working printer. I can't remember it taking more than about 15 mins following the guide on the wiki.
                                          You'll be back up and running in no time 👍
                                            droftarts administrators @Marco Bona
                                            @Marco-Bona said in RepRapFirmware 3.01-RC6 released:
                                            1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
                                            Strange, because this is mentioned specifically in the notes;
                                            Bug fixes:
                                            When printing a file, the first layer time was reported incorrectly, and when the print completed the total print time reported was incorrect
                                            Have you updated the firmware AND the DWC?
                                            Marco Bonaundefined 1 Reply Last reply Reply Quote 0
