    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.7k
    • ChrisPundefined
      ChrisP @A Former User
      @bearer said in RepRapFirmware 3.01-RC6 released:
      @ChrisP said in RepRapFirmware 3.01-RC6 released:
      drive is unmounted
      by the sound of it its unable to load the config.g so that could explain why nothing else works.
      could you also try doing ls -l /opt/dsf/sdand ls -l /opt/dsf/sd/sys in an ssh shell to see what permissions you have?
      Thanks for picking this up, but that is not the porblem at this point. I've only seen that error once immediately after update and after power cycle, that hasn't happened again.
      Everything now seems to load and I can see all the files on the interface, however, it's still not booting properly. After a reinstall, I'm still getting a persistant "busy" state and no the tools show the bed, but not the extruder, temperature chart still sows both. Pressing emergency stop now seems to work, but then nothing is listed in the tools and it still sits being "Busy" - see image.
        A Former User @tobias_munich
        @tobias_munich said in RepRapFirmware 3.01-RC6 released:
        But after uploading the config.g to the sys folder and rebooting,
        care to share the file and/or try a empty file?
        tobias_munichundefined 1 Reply Last reply Reply Quote 0
        • tobias_munichundefined
          tobias_munich @A Former User
          @bearer I tried a lot of ways ....
          And after all the tests I made it seems it’s a problem with the virtual SD.
          Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
          Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
          Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
            the system has problems to access to the virtual SD
            no doubt about it, just curious if its the content or presence of the config.g file that makes a difference; as it seemed it did make a difference from your earlier post.
            • ChrisPundefined
              ChrisP
              I'd also be interested to see what (if any) errors you have in the log for the DCS service:
              sudo journalctl -u duetcontrolserver.service
              Because I get a massive log full of this repeating. So I guress it's to do with my laser filament monitor in this case.
              Apr 03 22:20:52 starttex DuetControlServer[359]: [error] Failed to merge JSON: {"key":"","flags":"d99fn","result":{"boards":[{"mcuTemp":{"current":47.2},"v12":{"current":11.3},"vIn":{"current":12.0}}],"fans":[{"actualValue":0,"requestedValue":1.00,"rpm":0},{"actualValue":0,"requestedValue":0,"rpm":-1}],"heat":{"heaters":[{"active":50.0,"current":20.5,"standby":0,"state":"standby"},{"active":200.0,"current":23.0,"standby":0,"state":"off"}]},"inputs":[{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":2450,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"},{"feedRate":50.0,"lineNumber":0,"state":"idle"}],"job":{"build":null,"duration":null,"filePosition":0,"layerTime":null,"timesLeft":{"filament":null,"file":null,"layer":null}},"move":{"axes":[{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0},{"homed":false,"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"requestedSpeed":0,"topSpeed":0},"extruders":[{"position":0,"rawPosition":0}],"speedFactor":1.0},"sensors":{"analog":[{"lastReading":20.5},{"lastReading":23.0}],"endstops":[{"triggered":false},{"triggered":false},{"triggered":true}],"filamentMonitors":[{"filamentPresent":null}],"inputs":[{"value":null},{"value":true}],"probes":[{"value":[1000]}]},"seqs":{"boards":0,"directories":0,"fans":4,"heat":7,"inputs":1,"job":0,"move":13,"network":3,"reply":0,"sensors":2,"spindles":0,"state":0,"tools":5,"volumes":0},"spindles":[{"current":0},{"current":0}],"state":{"atxPower":null,"currentTool":-1,"laserPwm":null,"nextTool":-1,"previousTool":-1,"status":"idle","upTime":779},"tools":[{"active":[200.0],"standby":[0],"state":"off"}]}}
              Apr 03 22:20:52 starttex DuetControlServer[359]:    System.Text.Json.JsonException: Failed to deserialize property [FilamentMonitor].FilamentPresent (type Boolean) from JSON null
              Apr 03 22:20:52 starttex DuetControlServer[359]:  ---> System.Text.Json.JsonException: The JSON value could not be converted to System.Boolean. Path: $ | LineNumber: 0 | BytePositionInLine: 4.
              Apr 03 22:20:52 starttex DuetControlServer[359]:  ---> System.InvalidOperationException: Cannot get the value of a token type 'Null' as a boolean.
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.Utf8JsonReader.GetBoolean()
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.Serialization.Converters.JsonConverterBoolean.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonPropertyInfoNotNullable`4.OnRead(ReadStack& state, Utf8JsonReader& reader)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.HandleNull(Utf8JsonReader& reader, ReadStack& state)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    --- End of inner exception stack trace ---
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.ThrowHelper.ReThrowWithPath(ReadStack& readStack, Utf8JsonReader& reader, Exception ex)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 287
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
              Apr 03 22:20:52 starttex DuetControlServer[359]:    at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
              Edit: and sure enough, commenting out my filament monitor in the config.g and everything (except for the filament monitor) is working again. Think this is one for @chrishamm .
              • chas2706undefined
                chas2706
                Did power cycling fix that issue for you? It did for me. MInd you, even when that works, the printer is still unusable
                How can you say that power cycling fixed it for you if the printer is still unusable?
                ChrisPundefined 1 Reply Last reply Reply Quote 0
                • ChrisPundefined
                  ChrisP @chas2706
                  @chas2706
                  Because power cycling fixed that issue (ie. the drive mounted and read file and config etc), but after rebooting it hit a different bug (mentioned in my post above) that still rendered the printer unusable at that point.
                  • chas2706undefined
                    chas2706
                    Ok that's an improvement but for me power cycling, resetting or re-installing made no difference.
                    I've had to revert to RRF3.01RC3 but now running on the wrong version of DWC because there is no indication anywhere how we SBC users can download a specific version of DWC.
                    A Former User? ChrisPundefined 2 Replies Last reply Reply Quote 0
                    • chas2706undefined
                      chas2706
                      This has learnt me a big lesson. Always, always, always make a current back up before you download a "new release"! My latest back up was from a few previous releases.
                        A Former User @chas2706
                        edit: NOPE, that was not a good idea.
                        maybe this works better, specifying all the packages to fulfill dependencies for duetsoftwareframework=1.2.5.0
                        grep duet3d -r /etc/apt | grep unstable && sudo apt install  duetcontrolserver=1.2.5.0 duetsd=1.0.5 duettools=1.2.5.0 duetwebserver=1.2.3.1 duetwebcontrol=2.0.7-1 reprapfirmware=1.2.5.0-1 duetruntime=1.2.5.0 duetsoftwareframework=1.2.5.0 || echo Please swtich to unstable list.
                        edit changed to fail if not on unstable list.
                        Also according to chrishamm switching to instead of adding the unstable list may be the way to go
                        #comment out stable list
                        sudo sed -i '/ stable/s/^/#/g' /etc/apt/sources.list.d/duet3d.list
                        #add unstable list
                        echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                        • ChrisPundefined
                          ChrisP @chas2706
                          @chas2706 said in RepRapFirmware 3.01-RC6 released:
                          As @bearer pointa out, rolling back isn't tricky. Tbh, theres a reason that it's a beta firmware, so it should be obvious that backups are wise when trying a new "upgrade".
                          I'd still be interested to know the output of you logs for the DCS service.
                            A Former User
                            the start of the log is probably more relevant than the end of it.
                            • chas2706undefined
                              chas2706
                              I understand the meaning of beta firmware but if you have Duet3 with SBC and dare to "upgrade" there is no guarantee that if upon failure an older backup will work.
                              I now have this problem running RRF3.01.RC3 from a backup:
                              So now I will be spending numerous hours starting afresh!
                              A Former User? ChrisPundefined 3 Replies Last reply Reply Quote 0
                                that would imply your backup isn't covering your needs. simply shutting down the pi and cloning or imaging the SD card would take care of all but the RRF firmware on the Duet which can be flashed after restoring an old SD card. (caveat if they changed the iap binary)
                                • ChrisPundefined
                                  ChrisP @chas2706
                                  @chas2706
                                  You really shouldn't need to start afresh. Even if you do, as long as you have a copy of the sys & macros folders it should take longer to burn a new raspbian image than it does to get that fresh Linux install to a working printer. I can't remember it taking more than about 15 mins following the guide on the wiki.
                                  You'll be back up and running in no time 👍
                                    droftarts administrators @Marco Bona
                                    @Marco-Bona said in RepRapFirmware 3.01-RC6 released:
                                    1_ I continue to have the problem with the correct visualization of the Layers (yesterday @droftarts said it would be solved with the new build)
                                    Strange, because this is mentioned specifically in the notes;
                                    Bug fixes:
                                    When printing a file, the first layer time was reported incorrectly, and when the print completed the total print time reported was incorrect
                                    Have you updated the firmware AND the DWC?
                                    Marco Bonaundefined 1 Reply Last reply Reply Quote 0
                                      see my edited post https://forum.duet3d.com/post/143326
                                      • Danalundefined
                                        Danal
                                        apt allows specification of a version after the thing you are installing.
                                        sudo apt install duetsoftwareframework=1.2.4.0
                                        This, plus a few more commands below, gives you total control over the duet installation on the Pi. You can force it into a good (or bad!) state.
                                        You may want to do 'uninstall' in certain circumstances, or use the --reinstall flag (which forces a complete install even if apt thinks that version is already installed) Examples:
                                        sudo apt uninstall duetsoftwareframework
                                        sudo apt install duetsoftwareframework --reinstall
                                        You can list all available versions via:
                                        sudo apt list -a duetsoftwareframework
                                        Listing... Done
                                        duetsoftwareframework/unstable,now 1.3.0 armhf [installed]
                                        duetsoftwareframework/unstable 1.2.5.0 armhf
                                        duetsoftwareframework/unstable,stable 1.2.4.0 armhf
                                        duetsoftwareframework/unstable 1.2.3.1 armhf
                                        duetsoftwareframework/unstable,stable 1.2.3.0 armhf
                                        duetsoftwareframework/unstable,stable 1.2.2.1 armhf
                                        duetsoftwareframework/unstable 1.2.2.0 armhf
                                        duetsoftwareframework/unstable 1.2.1.0 armhf
                                        duetsoftwareframework/unstable 1.2.0.0 armhf
                                        duetsoftwareframework/unstable,stable 1.1.0.5 armhf
                                        duetsoftwareframework/unstable 1.1.0.4 armhf
                                        duetsoftwareframework/unstable 1.1.0.3 armhf
                                        duetsoftwareframework/unstable 1.1.0.2 armhf
                                        duetsoftwareframework/unstable 1.1.0.1 armhf
                                        duetsoftwareframework/unstable 1.1.0.0 armhf
                                        duetsoftwareframework/unstable,stable 1.0.4.1 armhf
                                        duetsoftwareframework/unstable 1.0.4.0 armhf
                                        duetsoftwareframework/unstable 1.0.3.5 armhf
                                        duetsoftwareframework/unstable 1.0.3.3 armhf
                                        duetsoftwareframework/unstable 1.0.3.2 armhf
                                        duetsoftwareframework/stable 1.0.3.1 armhf
                                        Generally, when doing a simple install, apt will deal properly with dependencies. During uninstalls and reinstalls in often does not. You can list all dependencies via:
                                        apt-cache depends duetsoftwareframework
                                          Depends: duetcontrolserver
                                          Depends: duetsd
                                          Depends: duettools
                                          Depends: duetwebserver
                                          Depends: duetwebcontrol
                                          Depends: reprapfirmware
                                          A Former User @Danal
                                          @Danal said in RepRapFirmware 3.01-RC6 released:
                                          not when downgrading dsf it seems
                                          pi@raspberrypi:~ $ sudo apt install duetsoftwareframework=1.2.4.0
                                          Reading package lists... Done
                                          Building dependency tree
                                          Reading state information... Done
                                          Some packages could not be installed. This may mean that you have
                                          requested an impossible situation or if you are using the unstable
                                          distribution that some required packages have not yet been created
                                          or been moved out of Incoming.
                                          The following information may help to resolve the situation:
                                          The following packages have unmet dependencies:
                                           duetsoftwareframework : Depends: duetcontrolserver (= 1.2.4.0) but 1.3.0 is to be installed
        Depends: duettools (= 1.2.4.0) but 1.3.0 is to be installed
        Depends: reprapfirmware (<= 1.2.4.0-999) but 1.3.0-2 is to be installed
                                          E: Unable to correct problems, you have held broken packages.
                                          pi@raspberrypi:~ $
                                          thus my post detailing all the verions..
                                          • Danalundefined
                                            Danal @A Former User
                                            Agreed, during anything but a simple install, it often does not.
                                            That's why I showed the commands that list dependencies and versions.
