    Duet maestro not connecting to DWC or being recognised by PC
    1.4k
      A Former User
      The safe method is to use a current limited power supply; but yeah, I'd use an ftdi in a pinch - after - snipping off the 3.3v leg of the regulator (a flush side cutter, flush side down to the pcb so any forces isn't acting to pull up on one pad, but spread the load across all the others - but its not without risk
        A Former User @NEVER LUCKY
        @NEVER-LUCKY said in Duet maestro not connecting to DWC or being recognised by PC:
        so what im thinking of doing is: i cut the IC pins all of them, and then solder the 3,3 and gnd from the ftdi on the board. is that fine ?
        I'd start by just the 3.3v pin, if the it no longer gets hot the others can be left to reduce risk of damage to the board.
        and yes, it'd be fine under the assumption there is no other damage to the cpu, wifi or sd card among other things.
        Edit: Although you can simply use wires to connect to any pin labled ground and 3.3v on the wiring diagram to see if it works.
          A Former User
          Also if you have a meter, use it to measure the resistance between ground and 3.3v after taking the defective 3.3v regulator out of the equation. If there is still a short, then you'll need some serious repairs.
          • NEVER LUCKYundefined
            NEVER LUCKY
            wow, 3,3 and gnd seem to be connected, i did a continuity test
              NEVER LUCKY
              3,3 supply doesnt work... instead it just gets shorted.
                I'm sorry to hear of your misfortune. I think you have a short between one of the heater wires and the hot end metalwork, possibly inside the heater cartridge. Sadly this has caused VIN to be connected to +3.3V when your +3.3V wire touched the metalwork, which has caused components powered from +3.3V to fail.
                Shorts between heater wires and the hot end metalwork are not uncommon, that's why we protect the thermistor connections against shorts to VIN.
                If you are unlucky, multiple components will have failed and the board will be beyond repair. If you are lucky, only one or two components will have failed. The most likely to have failed are the SD card and the W5500 Ethernet chip. So remove the SD card, then apply USB power and see if the green 3.3V LED lights up. If it doesn't, check whether the W5500 or main processor or any other chips are getting hot.
                  NEVER LUCKY
                  i removed the sd card and the green led doesnt light up.
                  no other component gets hot.
                  the 3,3v regulator U2, i have cut the 3,3v pin to solder an external power source but when i measured between gnd and the pin, it was shorted and my external source got super hot, so i removed that.
                    NEVER LUCKY
                    as soon as the vcc crimp of the sensor hit the hotend, the printer disconected.
                    the crimp didnt stay on the hotend, it just made contact for less a second and fell away from it.
                      NEVER LUCKY
                      is there anything else i can try?
                        A Former User
                        you pulled the sd card and no 3.3v light
                        you isolated the 3.3v regulator and supplied exeternal 3.3v and no 3.3v light
                        that means you have a short in one of the other chips that need 3.3v; next step is to identify which ones get hot when you feed it 3.3v and remove one by one and when no more chips are getting hot and you get a 3.3v light start putting in new chips which requires smd rework tools to both remove and install.
                        which as i laid out before probably means you had a short to +12/24v and that causes more damage (than a short to ground; and you really want to find and isolate that short before repairing or replacing the Duet)
                          NEVER LUCKY
                          no other component gets hot... it was only the regulator, if the others dont get hot then how am i supposed to know which one i must remove?
                          I have no experience troubleshooting or fixing these boards nor do i have any smd rework tools.
                          can i send them to duet for repair?
                          because im not comfortable with removing and adding components, im afraid i might cause more damage than there is.
                            and you don't get a green 3.3v light if you apply externa 3.3v? its possible, but unlikely the led itself is damaged.
                              NEVER LUCKY
                              there is a short between 3,3 and gnd, the green led doesnt light up, when i apply voltage from usb and no other component gets hot.
                                A Former User
                                If you have a short between 3.3v and ground, it would, unless using a current limtied supply, get warm when external power is applied.
                                And as i pointed out yesterday if you still have a short between 3.3v and ground after taking the 3.3v regulator out of the equation then at least some of the other parts will need replacing. The only reason to see which one gets warm would be to get an idea of the parts needed.
                                I'd take a look if anyone in this thread is near your location, or otherwise find someone with the skills and tools to assist you. there isn't much we can do online at this point.
                                https://forum.duet3d.com/topic/13875/community-repairs/
                                  NEVER LUCKY
                                  I will consider sending it to someone for repairs.
                                  does duet themselves not repair boards? dont they have a repair service?
                                    A Former User
                                    dc42 has said they do*, but as he implied it could quickly be beyond (economical) repair if the fault was caused by shorting 3.3v to Vin and that does sound like the most likely cause at this point.
                                    the reason I started the other alternative is to avoid the boards to become landfill material as the largest cost is the labour and not the parts. doesn't matter to me if I spend an hour helping you on a forum or an hour repairing a board, if I have the time I'm happy to help the community either way.
                                    *) with covid restrictions they might not be in office to such things for a while as well.
                                      NEVER LUCKY
                                      I understand your concern, but the problem here is that right now i have a lot of free time and i want to put it to good use to build out my custom printer, however this small accident ruined the entire board and i cant get anything done. Im not saying that i dont care about the environment and all, but i just need this board fixed so i can get up and running again.. and because i dont have the expertise to fix it, and now is not the best time to sent the board to other people in the community because of the situation we have in the world, i am comfortable with sending it back to duet.
                                      Is there any way i can maybe get a replacement?
                                        I'm not concerend; point is it could quickly end up costing more than a new board, and if we can't determine the extent of the damage you'll end up paying for finding out even its nor repaired. so the sensible thing is likely to buy a new one.
                                        maaaaaybe, but its not for me to say; they have been known to offer refurbished boards at lower prices in such cases.
                                          NEVER LUCKY
                                          where should i request for one ?
                                            A Former User
                                            I'd wait for them to offer you one tbh. (and if you look at their website, you might see it could take awhile but I'm kinda done repeating myself)
