    Duet maestro not connecting to DWC or being recognised by PC
    1.5k
    • NEVER LUCKYundefined
      NEVER LUCKY
      is there anything else i can try?
        A Former User
        you pulled the sd card and no 3.3v light
        you isolated the 3.3v regulator and supplied exeternal 3.3v and no 3.3v light
        that means you have a short in one of the other chips that need 3.3v; next step is to identify which ones get hot when you feed it 3.3v and remove one by one and when no more chips are getting hot and you get a 3.3v light start putting in new chips which requires smd rework tools to both remove and install.
        which as i laid out before probably means you had a short to +12/24v and that causes more damage (than a short to ground; and you really want to find and isolate that short before repairing or replacing the Duet)
          NEVER LUCKY
          no other component gets hot... it was only the regulator, if the others dont get hot then how am i supposed to know which one i must remove?
          I have no experience troubleshooting or fixing these boards nor do i have any smd rework tools.
          can i send them to duet for repair?
          because im not comfortable with removing and adding components, im afraid i might cause more damage than there is.
            A Former User @NEVER LUCKY
            @NEVER-LUCKY said in Duet maestro not connecting to DWC or being recognised by PC:
            and you don't get a green 3.3v light if you apply externa 3.3v? its possible, but unlikely the led itself is damaged.
              NEVER LUCKY
              there is a short between 3,3 and gnd, the green led doesnt light up, when i apply voltage from usb and no other component gets hot.
                A Former User
                If you have a short between 3.3v and ground, it would, unless using a current limtied supply, get warm when external power is applied.
                And as i pointed out yesterday if you still have a short between 3.3v and ground after taking the 3.3v regulator out of the equation then at least some of the other parts will need replacing. The only reason to see which one gets warm would be to get an idea of the parts needed.
                I'd take a look if anyone in this thread is near your location, or otherwise find someone with the skills and tools to assist you. there isn't much we can do online at this point.
                https://forum.duet3d.com/topic/13875/community-repairs/
                  NEVER LUCKY
                  I will consider sending it to someone for repairs.
                  does duet themselves not repair boards? dont they have a repair service?
                    A Former User
                    dc42 has said they do*, but as he implied it could quickly be beyond (economical) repair if the fault was caused by shorting 3.3v to Vin and that does sound like the most likely cause at this point.
                    the reason I started the other alternative is to avoid the boards to become landfill material as the largest cost is the labour and not the parts. doesn't matter to me if I spend an hour helping you on a forum or an hour repairing a board, if I have the time I'm happy to help the community either way.
                    *) with covid restrictions they might not be in office to such things for a while as well.
                      NEVER LUCKY
                      I understand your concern, but the problem here is that right now i have a lot of free time and i want to put it to good use to build out my custom printer, however this small accident ruined the entire board and i cant get anything done. Im not saying that i dont care about the environment and all, but i just need this board fixed so i can get up and running again.. and because i dont have the expertise to fix it, and now is not the best time to sent the board to other people in the community because of the situation we have in the world, i am comfortable with sending it back to duet.
                      Is there any way i can maybe get a replacement?
                        I'm not concerend; point is it could quickly end up costing more than a new board, and if we can't determine the extent of the damage you'll end up paying for finding out even its nor repaired. so the sensible thing is likely to buy a new one.
                        maaaaaybe, but its not for me to say; they have been known to offer refurbished boards at lower prices in such cases.
                          NEVER LUCKY
                          where should i request for one ?
                            A Former User
                            I'd wait for them to offer you one tbh. (and if you look at their website, you might see it could take awhile but I'm kinda done repeating myself)
                              NEVER LUCKY
                              well alright.. ill wait.
                              should i do anything else or just wait here?
                                droftarts administrators @NEVER LUCKY
                                @NEVER-LUCKY Sorry for your mishap, it’s an expensive lesson in a moment. If you email sales@duet3d.com with a link to this thread, and ask Roland if he has any refurbished Duets if you want to keep the cost down. I have no idea how long delivery will take in these uncertain times, tho.
                                Unfortunately this kind of damage is not covered by the warranty (see https://www.duet3d.com/warranty), and as @bearer points out it quickly gets more expensive to repair a board than buy a new one.
                                  NEVER LUCKY
                                  thanks for the help guys.
                                  @bearer
                                  @droftarts
                                    Phaedrux Moderator @NEVER LUCKY
                                    @NEVER-LUCKY
                                    Username checks out. Sorry for your mishap.
