    RepRapFirmware 3.01-RC6 released
    Beta Firmware
    27
    165
    12.8k
    • tobias_munichundefined
      tobias_munich @dc42
      RC6 works for me in standalone mode and is stable.
      SBC mode is still unstable.
      think the reason is still the current version of the duet framework.
      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
      • jmjcokeundefined
        jmjcoke
        I have tried, sudo service duetcontrolserver restart and I still have Drive is unmounted. Any help on how I can goto RC5 from here, I cannot seem to get duetframework to anything but 1.3.1.
        Joshua Coke
        Trick Laser Metal Max with Smart Effector
        Duet Wifi
        Zesty Nimble
        Mosaic Pallette+
        At work
        Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
        tobias_munichundefined 1 Reply Last reply Reply Quote 0
          tobias_munich @jmjcoke
          @jmjcoke the problem is not RC6, it’s the Duetframework.
          if you run RC6 in stand-alone mode you shoudnt have issues.
          • SpoonUnitundefined
            SpoonUnit
            Successfully setup and printed with RC6. Only issue is that my kill switch isn't working. It's setup with this, to invoke trigger2.g:
            M581 P"duex.e2stop" S1 T2 C0
            Trigger 2 is working if I invoke with M98, and M999 (the only command in the trigger) also does it's job. I've tried all 4 permutations of the command that seem to make sense:
            M581 P"duex.e2stop" S0 T2 C0
            M581 P"!duex.e2stop" S1 T2 C0
            M581 P"!duex.e2stop" S0 T2 C0
            None of them result in activation of the trigger when the button is pressed.
            The command executes fine from the console, and worked as intended with RC1. I can't see any reference in the notes for each release between RC1 and RC6 for this, but could have missed something.
            Is there a way to simply report on the state of a given pin?
            This output doesn't give me confidence it's been made available, but I never needed to investigate to this depth previously, so I'm not sure what the output in RC1 was:
            M409 K"sensors.endstops" F"v"
            {"key":"sensors.endstops","flags":"v","result":[{"triggered":false,"type":"inputPin"},{"triggered":false,"type":"inputPin"},null,{"triggered":false,"type":"motorStallAny"}]}
            I'm not sure where else in the object model to look. Could this be it?
            M409 K"inputs[5]" F"v"
            {"key":"inputs[5]","flags":"v","result":{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":false,"feedRate":50.0,"inMacro":false,"lineNumber":0,"name":"Trigger","stackDepth":0,"state":"idle","volumetric":false}}
            If so, I don't see any key there for the value.
            Any help appreciated.
            deckingmanundefined dc42undefined 2 Replies Last reply Reply Quote 0
              deckingman @SpoonUnit
              @SpoonUnit Something did change with M581. I'm on a phone right now so not easy for me to say exactly what. IIRC you need to add an M950 with a (I think) J parameter.
                dc42 administrators @SpoonUnit
                @SpoonUnit, read the upgrade notes for 3.01-RC2, or https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M581_RepRapFirmware_3_01RC2_and_later.
                  SpoonUnit
                  This was the end result of the conversion, which now works.
                  ; buttons
                  ;RRF 3.01 RC1
                  ;M581 P"duex.e2stop" S1 T2 C0
                  ;RRF 3.01 RC6
                  M950 J1 C"duex.e2stop" ; Define Input J1 for pin duex.e2stop
                  M581 P1 T2 C0 S1 ; Connect Input J1 (P1) to trigger 2 (T2) always (C0) for inactive to active (S1 - also default)
                  One source of confusion was that M950 J1 alone reports this, regardless of whether the button is pressed or not:
                  M950 J1
                  Pin duex.e2stop, active: true
                  I guess this is reporting that the pin is active in the model, and not that the pin state is open. Where in the object model will J1 sit once defined? It doesn't seem to be in inputs or sensors.
                  Also spotted on the M950 example:
                  M950 J1 C"!^e3stop" ; Input 1 uses e0Stop pin, inverted, pullup enabled
                  Should this not read that Input 1 uses e3stop, instead of e0stop?
                  • chrishammundefined
                    chrishamm administrators @ChrisP
                    @ChrisP Thanks for reporting this, I'll try to reproduce and fix it.
                    Duet software engineer
                      @SpoonUnit said in RepRapFirmware 3.01-RC6 released:
                      ;RRF 3.01 RC6
                      M950 J1
                      As you have not inverted the input, it should report 'active: true' when the input is high and false when it is low (i.e. shorted to ground).
                      It should already be in sensors.inputs[1].
                      Thanks, I've corrected the example.
                        I've just tested exactly that configuration: M950 J1 C"duex.e2stop". M950 J1 always reports "active: false" which is incorrect. I will fix this in RC7. M409 K"sensors.inputs" reports it correctly.
                        SpoonUnitundefined 1 Reply Last reply Reply Quote 0
                          SpoonUnit @dc42
                          @dc42 Strange I get active:true, regardless of whether the button is pressed or not, whereas you get false. Good to know what you intended for it.
                          echo sensors.inputs[1].value
                          Reports true, where I expect it to report false. Regardless, the button is performing its intended function now.
                            Is the button NO or NC? What's happening is that the button state is being read when the port is created, but then M950 J1 is reporting that initial state, not the current state. I am testing with a NC button, so it's active when the button is pressed. With a NO button it would be active when the button is not pressed, unless you invert the pin.
                              SpoonUnit
                              I honestly don't know what N0 or NC is. However, I've just had a moment to test and I can see the sensors.inputs[1].value does flip when the button is pressed. I guess my button (just an arcade button) is NO (default:open ?).
                                @SpoonUnit NO - Normally Open, NC = Normally Closed. HTH
                                • garyd9undefined
                                  garyd9
                                  Something seems to have broken my delta auto-calibration script (bed.g) between RC3 and RC6 related to the 'iterations' variable on my duet3 running in stand-alone. (I don't see anything in WHATS_NEW related to that variable.) Each time I run G32, it does the initial probe, and then immediately breaks the loop assuming iterations is = 5. For a complete context:
                                  My bed.g contains (comments removed):
                                  G28 ; always home before calibration
                                  M98 P"/sys/Calib-Probe-Points.g"
                                  while true
                                  	if iterations = 5
                                  		abort "Too many auto-calibration attempts"
                                  	if {abs(move.calibration.final.deviation - move.calibration.initial.deviation)} < 0.005
                                  		break;
                                  	echo "Repeating calibration to merge deviations"
                                  echo "Auto calibration successful"
                                  G1 X0 Y0 Z150 F8000			; get the head out of the way of the bed
                                  ... and Calib-Probe-Points.g contains:
                                  G30 P0 X0.00 Y130.00 Z-99999 H0
                                  ; .. G30 P1 thru G30 P17
                                  G30 P18 X0 Y0 Z-99999 S8
                                  Running G32 results in a single run of Calib-Probe-Points.g and then the script aborts. (It also aborts if the deviation is too great and it should try again.)
                                  Calibrated 8 factors using 19 points, (mean, deviation) before (-0.008, 0.028) after (0.000, 0.027)
                                  I doubt I'm the only person using a script like this for calibrating, and I don't see anyone else complaining, so I'm assuming (hoping) that I missed something in one of the 3.0.1 RCx changes (or discussions.) If so, please point me in the correct direction (and perhaps add something to the 'update notes' in WHATS_NEW.)
                                  EDIT (with solution at the end):
                                  I've narrowed this down and it doesn't seem to have anything to do with the 'iterations' variable at all, but instead with the loop processing. Again, this used to work fine with RC3... Rather than describe every change, here's an updated bed.g:
                                  ;M98 P"/sys/Calib-Probe-Points.g"
                                  ; start looping...
                                  while true
                                  	echo iterations
                                  	if iterations = 5
                                  		G1 X0 Y0 Z150 F8000
                                  ; dummy comment
                                  ; dummy comment
                                  		break;
                                  The key changes are that I added something to display the value of 'iterations' each iteration, and I have some dummy comments in there (that used to contain different variations of testing the deviation.) When I run G32 with those changes in place, I see the following in the console:
                                  0
                                  1
                                  Notice how it's iterating the loop, but not displaying the 'repeating calibration' message? That gave me the clue I needed... If I remove the two dummy comments, everything works as expected.
                                  My best guess is that a previous RC would completely ignore comment lines, but the current RC will use still use the comment line indentation to determine end of loop.
                                  mwolterundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  • zerspaner_gerdundefined
                                    zerspaner_gerd
                                    Hi there,
                                    Can it be that the G30 S-3. is no longer working properly?
                                    With RRF2.05 this was saved automatically, max. an M500 was necessary.
                                    Now it only works again with M500 P31
                                    DWC shows the following message:
                                    But config-override.g was not saved
                                    greetings
                                    Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
                                    • mwolterundefined
                                      mwolter @garyd9
                                      @garyd9 Try indenting the two dummy comments to the same level as the while loop. Have a feeling it sees them unindented and stops the while loop at that point
                                        dc42 administrators @garyd9
                                        @garyd9 said in RepRapFirmware 3.01-RC6 released:
                                        That's correct. RRF used to throw comment lines away early on during processing. It no longer does that, because it parses certain comments for useful information during printing, e.g. comments containing object labels.
                                        • gtj0undefined
                                          gtj0
                                          @dc42 I don't think this has been reported already but move.extruders.factor only reports to 1 decimal place precision so for instance, if you do a M221 and set the value between 96 and 105, the reported value is still 1.0. This is the RRF value reported from M409 as well as from DSF.
                                          • gtj0undefined
                                            gtj0 @gtj0
                                            @gtj0 said in RepRapFirmware 3.01-RC6 released:
                                            It looks like the move speedFactor is the same way.
