    Help needed to remap fan1
    269
    • S.Rolinundefined
      S.Rolin
      I had a wire break on my hot end fan and the wires shorted and fan1 port is no longer working. Can I use fan2 for the hot end and how?
      Duet2 maestro and firmware v3
      In advance thank you
      S. Rolin
      • bondusundefined
        bondus
        There should be a line in your config.g looking something like:
        you can change "fan1" to "fan2" and it will use that connector instead.
        S.Rolinundefined 2 Replies Last reply Reply Quote 1
        • S.Rolinundefined
          S.Rolin @bondus
          @bondus thank you I will try that.
          • S.Rolinundefined
            S.Rolin @bondus
            @bondus That did not work, did i miss somthing?
            M950 F1 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
            G10 P0 R0 S0
              Phaedrux Moderator @S.Rolin
              @S-Rolin said in Help needed to remap fan1:
              Did you also move the fan port for the hotend fan to Fan2 port?
              • S.Rolinundefined
                S.Rolin
                Yes i did, mabye it is blow to 😞
                  Have you checked the fan fuse?
                  Does the fan work when connected to the always on fan port?
                  S.Rolinundefined 1 Reply Last reply Reply Quote 0
                  • S.Rolinundefined
                    S.Rolin @Phaedrux
                    @Phaedrux yes it does, that what i've done to keep the printer running. where would i find the fan fuse?
                    sorry for alle the questions.
                    /Soren
                      Sorry, I see now that you're using a Duet Maestro, so no replaceable fan fuse.
                      Since this is the hotend fan, you could still use the always on fan port. If fan port 1 and 2 are no longer working.
                      Actually. the fan 2 block has it's own voltage select jumper, how is it set? Perhaps it's not set properly and that's why your Fan2 port isn't working as expected.
                      https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
