    Error: Temperature reading fault on heater 0
    2.1k
    • felixlvhundefined
      felixlvh
      it worked yesterday. and today i turned on this errors appear
        A Former User
        Check the (sensor) wiring, and which Duet is it?
        • giostarkundefined
          giostark
          When I saw this message on my printer I had not good contact between some pins. I use the multimeter for check if the cables were open and whey were. (in that case they touch yes and no). To fix the contact make that 2000 disappear. Maybe vibration moved them a little? Did you Inadvertently maybe touched them?
          • felixlvhundefined
            felixlvh
            pretty sure it's not wiring issue. its duet web
            • felixlvhundefined
              felixlvh
              i read about some posts it could be vss fuse issue. any idea how to identify and fix this?
              • giostarkundefined
                giostark
                I found this that should be where you lies at this point:
                https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_VSSA_fuse
                But right now I'm not capable enough to give suggestions 😕
                  A Former User @felixlvh
                  @felixlvh said in Error: Temperature reading fault on heater 0:
                  see if this thread helps? https://forum.duet3d.com/topic/15331/error-on-thermistors
                  • felixlvhundefined
                    felixlvh
                    more details below; run some commands
                    Heater 0 uses Thermistor sensor channel 0, last error: sensor open circuit, T:100000.0 B:3950.0 C:0.00e+0 R:4700.0 L:54 H:-97
                    Heater 1 uses Thermistor sensor channel 1, last error: sensor open circuit, T:100000.0 B:4725.0 C:7.06e-8 R:4700.0 L:0 H:0
                    Heater 0 model: gain 90.0, time constant 700.0, dead time 10.0, max PWM 1.00, calibration voltage 0.0, mode bang-bang, inverted no, frequency default
                    Heater 1 model: gain 550.2, time constant 241.2, dead time 7.0, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
                    Computed PID parameters for setpoint change: P11.2, I0.272, D54.8
                    Computed PID parameters for load change: P11.2
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2020-02-09b1
                    Board image : https://ibb.co/9n1mwS5
                      A Former User
                      @felixlvh said in Heater Fault:
                      Hi @dc42, i have the same issue as mentioned above. can you eleborate how can i use a multimeter to verify if i have vssa fuse blown? i am pretty sure all wiring are ok and now i am getting open circuit error message. thanks a ton!
                      @dc42 said in Heater Fault:
                      Yes, if your Duet is a revision 1.0 or 1.01 then with power off, use a multimeter to measure the resistance between VSSA on a thermistor pin and GND on an endstop pin. It should read no more than a few ohms. If instead it's very high, the VSSA fuse has blown, which will make all thermistors read 2000C.
                      https://www.google.com/search?q=test+fuse+multimeter
                      • felixlvhundefined
                        felixlvh
                        @bearer said in Error: Temperature reading fault on heater 0:
                        Hi @bearer thanks for your reply.
                        I look closer to my board and found something is blown as screenshot. I am not sure if this is VSSA, can you point me to the right fuse?
                        https://ibb.co/3FKtpV2
                          A Former User
                          Which revision board is it?
                          First picture is a fan output, looks damaged. (TR1 designates transistor, as in mosfet)
                          Fuse should have been a fairly large 1206 smd part (3.6x1.6mm) in the second picture, fuses are designated Fn.
                          • felixlvhundefined
                            felixlvh
                            Hi @bearer
                            It should be 1.02. i searched around and found the vssa. assumed i am on the right fuse, the multimeter doesn't give me any reading. do i need to connect to power? thanks again!
                            https://ibb.co/TYb2MNS
                              no, it should measure as close to 0 ohm when its ok, but it can be tricky to pierce oxide layer on old solder joints. You could repeat the measurement between Vin- and both pins on the thermistor input (one of them should be close to 0 ohm if the fuse ok)
                              Looks to be the right part, but smaller on rev 1.2.
                              • felixlvhundefined
                                felixlvh
                                Thanks @bearer , in this case i don't think my vssa fuse is blown.
                                • felixlvhundefined
                                  felixlvh
                                  @dc42 @bearer
                                  i have tried to disconnect all wires to isolate the issue. i am plugging in the extruder heaters e1, extruder thermistors, bed thermistor, heated bed still showing the same error. do you think is should get a new board?
                                  • Turboundefined
                                    Turbo
                                    This post is deleted!
                                      A Former User
                                      if you measure the resistance across the two pins of the thermistor plug, when its not connected to the board wht do you get?
                                      felixlvhundefined 1 Reply Last reply Reply Quote 0
                                      • felixlvhundefined
                                        felixlvh @A Former User
                                        @bearer , i got reading 80.3K
                                          80.3K
                                          config says its a 100k thermistor so it should be about right
                                          maybe you should connect vssa directly to ground on a unused thermistor input now that you have nothing else connected; power from usb and see if that makes a difference
                                          • felixlvhundefined
                                            @bearer Thanks, i am still uncertain about the vssa fuse. if you see the image here, https://ibb.co/TYb2MNS i got reading 90.9K. i can now confirm board is v1.01.
