    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.0k
    • gtj0undefined
      gtj0
      Just FYI if you need streaming as well as time lapse. I set up ustreamer as the "owner" of the camera and pointed DuetLapse at its "/snapshot" URL. That way I have both a live stream and the time lapse at the same time.
      • arhiundefined
        arhi
        "camparams" error
        dunno if this helps
        [root@localdev LAPSE]# ./DuetLapse.py -duet http://ender5.local.lan
        Traceback (most recent call last):
          File "./DuetLapse.py", line 257, in <module>
            init()
          File "./DuetLapse.py", line 74, in init
            camparms = args['camparms']
        KeyError: 'camparms'
        [root@localdev LAPSE]# ./DuetLapse.py -duet ender5.local.lan
            init()
        [root@localdev LAPSE]# host ender5.local.lan
        ender5.local.lan has address 192.168.89.246
        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246
            init()
        [root@localdev LAPSE]# python --version
        Python 3.7.6
        [root@localdev LAPSE]# fswebcam -d /dev/video0 -F 1 kkk
        --- Opening /dev/video0...
        Trying source module v4l2...
        /dev/video0 opened.
        No input was specified, using the first.
        Adjusting resolution from 384x288 to 352x288.
        --- Capturing frame...
        Captured frame in 0.00 seconds.
        --- Processing captured image...
        Unable to load font 'sans': Problem doing text layout
        Disabling the the banner.
        Writing JPEG image to 'kkk'.
        and here you can see how non python developer try to follow up before giving up 😞
        [root@localdev LAPSE]# ./DuetLapse.py camparms -h
        usage: DuetLapse.py camparms [-h] [-- ...]
        camparm -parms xxx where xxx is passed to fswebcam, raspistill, or wget.
        optional arguments:
          -h, --help          show this help message and exit
          -- ..., -parms ...  Extra parms to pass to fswebcam, raspistill, or wget.
        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246 -camera usb -parms -d /dev/video0
        usage: DuetLapse.py [-h] -duet DUET [-camera {usb,pi,web,dslr}]
                            [-seconds SECONDS] [-detect {layer,pause,none}]
                            [-pause {yes,no}] [-movehead MOVEHEAD MOVEHEAD]
                            [-weburl WEBURL] [-dontwait]
                            {camparms} ...
        DuetLapse.py: error: invalid choice: '/dev/video0' (choose from 'camparms')
        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246 -camera usb -parms "-d /dev/video0"
                            {camparms} ...
        DuetLapse.py: error: invalid choice: '-d /dev/video0' (choose from 'camparms')
        [root@localdev LAPSE]# ./DuetLapse.py -duet 192.168.89.246 -camera usb "-d /dev/video0"
                            {camparms} ...
        • Danalundefined
          Danal
          Well, drat, I obviously have gaps in my test cases.
          Will be fixed and upload in 20 min or so.
          • Danalundefined
            Danal
            OK, now fixed.
            While I was there, I added the ability to press Ctrl+C one time, while waiting for pre-start or print running, and it will move directly to making a video. In other words, if you wish to end it before the print ends, and still want the vid, press Ctrl-C once.
            • arhiundefined
              arhi @Danal
              @Danal said in DuetLapse available for Alpha testing:
              I edited the code and removed the whole camparms thing and hardcoded the call to fswebcam to test it. Having some issues now of other kind (that's a fedora vm with usb camera connected trough vm-terminal as the camera with good view of the printer is on usb on my desktop so I can monitor during testing phase 😄 ) so don't have the test video yet but so far it seems to be working. Anyhow the device and resolution are hardcoded? Why? fswebcam will use -d /dev/video0 as default anyways so I don't see reason for you to hardcode it and if user want to use other one like i420:/dev/video1 you can't pass that parametar to fswebcam as you already hardcoded video0, also resolution, what if I want 1280x960 as that's native to C270, you hardcoded 800x600 ?
              Maybe let fswebcam use default values (low res, video0 ..) and show in help example how to get some decent values (higher res etc..)
              • arhiundefined
                arhi @Danal
                @Danal that's a nice feature (ctrlc once) 🙂
                I'll test the new code asap 🙂
                • Danalundefined
                  Danal @arhi
                  @arhi said in DuetLapse available for Alpha testing:
                  Yeah, you have very valid points. I THOUGHT I did the minimum to get a usable image... but it really looks like I should have let more things default.
                  I can do it two ways:
                  1. Remove everything I can and risk the auto stuff not working for a true "newbie" for some reason or another
                  (Probably going to do this... low risk...)
                  1. Have camparms replace EVERYTHING, except the file name.
                  • Danalundefined
                    Danal
                    OK, I did a little of both. Removed quite a bit from the 'defaults', AND changed it so that if you specified 'camparms -parms' the only thing that is added is the filename.
                    And, introduced "vidparms -parms '. Works the exact same way, except it is passed to ffmpeg.
                    Ready for test right now.
                    • Danalundefined
                      Danal
                      pi@duet3:~/DuetLapse $ ./DuetLapse.py -h
                                          {camparms,vidparms} ...
                      Program to create time lapse video from camera pointed at Duet3D based
                      printer.
                      optional arguments:
                        -duet DUET            Name or IP address of Duet printer.
                        -seconds SECONDS
                        -pause {yes,no}
                        -weburl WEBURL
                        -dontwait             Capture images immediately.
                      subcommands:
                        {camparms,vidparms}   DuetLapse camparms -h or vidparms -h for more help
                      pi@duet3:~/DuetLapse $ ./DuetLapse.py camparms -h
                      pi@duet3:~/DuetLapse $ ./DuetLapse.py vidparms -h
                      usage: DuetLapse.py vidparms [-h] [-- ...]
                      vidparms -parms xxx where xxx is passed to ffmpeg.
                      • PaulHewundefined
                        PaulHew
                        @Danal I have been using your tool for a week now and there is one thing which would be nice.
                        I have to log into the Pi to send the DuetLapse.py -camera pi - detect layer -duet 192.168.0.7
                        All this Pi does is run the TimeLapse software.
                        When it has finished I have to log back in again and do it all again.
                        Is there a way that it can run all of the time as a service and maybe send a telnet command from the Duet to say,
                        I am about to print, get ready!!
                        i.e. M118 P4 S"Print Starting"
                        Which in turn enables DuetLapse with the users setting.
                        Just a thought
                        Regards,
                        Paul.
                        • Danalundefined
                          Danal
                          I will think about a way to do this... while minimally banging on the printer between prints.
                          • PaulHewundefined
                            PaulHew
                            Had a Malloc error, used all default settings.
                            Capturing frame   522 at X10.00 Y280.00 Z120.00
                            Now making 523 frames into a video at 10 frames per second.
                            This can take a while...
                            x264 [error]: malloc of size 25549312 failed
                            Video encoding failed
                            Killed
                            Video processing complete.
                            Video file is in home directory, named ~/DuetLapse0413200101.mp4
                            😞 Was looking forward to this TimeLapse
                            • Danalundefined
                              Danal
                              As long as you have NOT started the overall script again, or rebooted, the images are still there and you can try to make the video over and over.
                              The actual command issued is:
                              ffmpeg -r 10 -i /tmp/DuetLapse/IMG%08d.jpeg -vcodec libx264 -y -v 8 ~/DuetLapse0413200101.mp4
                              You could try other ffmpeg options (I am not an expert), try making two videos out of half the images, and stitch the vids together later, etc, etc.
                              To be clear, the images are in /tmp and are named
                              Etc.
                              • mrwulffundefined
                                mrwulff
                                Awesome program. One issue I've always had is that my wifi and or duet do not like each other and disconnect constantly, but will always reconnect eventually. Is it possible to automatically 'skip' a frame if there is no connection to the printer at that time and not to throw an error?
                                Also would be nice if it looked at the file name it was printing and made subfolders with the name of the print
                                • Danalundefined
                                  Danal @mrwulff
                                  @mrwulff said in DuetLapse available for Alpha testing:
                                  Yes, I will add some error handling to the key spots.
                                  Hey, great idea!
                                  • Baenwortundefined
                                    Baenwort @Danal
                                    @Danal does DuetLapse require RRF3 or a certain version or above of DWC?
                                    I'm interested in trying it.by I don't know.what you mean by the step that says to place the DuetLapseAPI.Ph in the python libpath? Is it enough to place all the .py files in one directory?
                                    • Danalundefined
                                      Danal
                                      @Baenwort said in DuetLapse available for Alpha testing:
                                      • Supports Duet printers running V2, V3 standalone and V3 +Pi.
                                      • Printer must be reachable via the network.
                                      That step actually says: Copy included module https://github.com/DanalEstes/DuetWebAPI/blob/master/DuetWebAPI.py to the same directory, or to anywhere in python's libpath.
                                      Thanks for the questions, I will do a bit of readme editing to make all above more clear.
                                      • tekkydaveundefined
                                        tekkydave
                                        If it helps with putting caption overlays on your output movie files I have been playing with ffmpeg in the last few days. The command I am using is
                                        ffmpeg -r 10 -i ./IMG%06d.jpg -vcodec libx264 -crf 15 -s 800x600 -pix_fmt yuv420p -y -v warning -vf drawtext="fontfile=/usr/share/fonts/truetype/ttf-dejavu/DejaVuSerif.ttf: text='Text to put on screen':fontsize=40:fontcolor=yellow:box=1:boxborderw=5:boxcolor=black@0.5:x=10:y=10" movie.mp4
                                        This will give you a caption in the top-left with a semi-transparent black box around
                                        HTH
                                        Dave
                                        ~ tekkydave ~
                                        D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
                                        FreeCAD, PrusaSlicer
                                        • Danalundefined
                                          Danal
                                          What people are requesting changes as the frames flow. Things like Z height, etc. I believe those overlays need to be part of the stills.
                                          tekkydaveundefined 1 Reply Last reply Reply Quote 1
                                            tekkydave @Danal
                                            That's true, if they need to reflect things changing as the print progresses.
                                            I'm writing a similar program to yours. I use motioneye to generate my original images from a picam which is then displayed in the DWC Webcam view (or via a browser window).
                                            Motioneye uses motion which has a http api available.
                                            e.g. To take snapshots
                                            http://localhost:7999/1/action/snapshot
                                            will cause motion to take a snapshot from Camera 1 and place it in
                                            /var/lib/motioneye/Camera1
                                            I'm picking them up from there, creating a movie when the print is complete (ffmpeg) and uploading it to my NAS server.
                                            I had thought of doing something like this for a while but you have inspired me to get it done. I admit I have "borrowed" a few ideas from your program. 🙂
                                            Also I'm using Java as it's what I'm more comfortable with. I like Netbeans as an IDE as it's perfect for Java development.
                                            ~ tekkydave ~
