Incident report: RRF 3 RC6 DWC 2.1.0 Lockup during print.
Beta Firmware
11
41
2.3k
    A Former User
    @chas2706 said in Incident report: RRF 3 RC6 DWC 2.1.0 Lockup during print.:
    because there are no bugs in 3.01-RC6.
    I would think its obvious that we're talking about "known" bugs; and plans change.
    Virtually no amount of testing can prove the absence of bugs.
      Danal
      Same print job finished just fine, about 3 hours, on RC4 and friends.
      Duet Web Control 2.0.7
      Board: Duet 3 MB6HC v0.6 or 1.0 (MB6HC)
      DSF Version: 1.2.5.0
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC4 (2020-03-16b1)
        gtj0
        I would report all DSF issues to @chrishamm on github...
        https://github.com/chrishamm/DuetSoftwareFramework/issues
        or in this thread... https://forum.duet3d.com/topic/15343/dsf-1-3-1-unstable-released
          Danal
          @gtj0 How would I determine whether to post in RRF 3.0RC6 vs. DSF 1.3?
          undefined undefined 2 Replies Last reply 13 Apr 2020, 00:08 Reply Quote 0
            droftarts administrators @Danal
            @Danal run the job in Duet 3 standalone with the same settings and firmware version?
              gtj0 @Danal
              @Danal said in Incident report: RRF 3 RC6 DWC 2.1.0 Lockup during print.:
              I have asked that question many times and I've never received a satisfactory response.
              @droftarts said in Incident report: RRF 3 RC6 DWC 2.1.0 Lockup during print.:
              Don't get me started.
              It's not always easy to just "run in standalone mode". In my case, I have to remove the covers from the printer to get to the sd card and remove the cable between the Duet and the SBC.
              I also don't believe it's the user's responsibility to have to determine which component of the system is at fault. That should be Duet3D's responsibility. The fact that RRF and DSF seem to be owned and operated by 2 separate companies irks me to no end.
              undefined 1 Reply Last reply 14 Apr 2020, 08:11 Reply Quote 0
                Danal
                I agree. From a user's perspective, DSF and RRF are the same thing. Gcode goes in one end and motion comes out the other.
                For example, it is incredibly weird that M999 restarts RRF but not DSF, even when it is absolutely reproducible that any number of hangs are cleared ONLY by restarting DSF. Which a user of this "gcode everywhere" system has no way to do (other than on the Pi, and with sudo no less!)
                I love Duet and have been a happy advocate for at least a few years. I am aghast at the latest directions and actions. I sincerely hope they course correct. (To be clear, I'm all in favor of SBC/Pi integration. It is the way that's being accomplished that is going to send a great company downhill if they don't change something).
                ? 1 Reply Last reply 13 Apr 2020, 10:24 Reply Quote 0
                  Danal
                  Also, as regards how easy to "reproduce in stand-alone", I don't have any ethernet that will reach. I am not the first owner of this house, and there is not an inch of Cat anything in it (except about 1 foot (1/2 meter) between the cable modem and the main wireless router). I'm also not real motivated to make a special SD card, run special ether, etc, etc, to run the printer in a mode which I will literally never run. It goes back to DSF and RRF being layers of the same thing, and they should be supported that way.
                    Danal
                    OK, rant over. Sort of.
                    undefined 1 Reply Last reply 13 Apr 2020, 14:06 Reply Quote 0
                      bot
                      And here I am, just sad that RRF 2 isn't getting the attention it needs and deserves! We need an LTS team!
                      *not actually a robot
                        chas2706
                        I had my sarcastic rant earlier when I quoted DC42's statement that RRF 3.01-RC6 has no bugs.
                        I agree, I too am not interested if any particular bug is within the RRF, DCS, or DSF. They should all work together as one whole package.
                        The issue I have is that like you I love the idea of Duet 3 with SBC but there are many problems at the minute and all I seem to get is "It works ok in standalone mode".
                        If I wanted "stand alone" I would not have purchased RRF 3 and Raspberry Pi 4!
                        Rant over!
                        undefined 1 Reply Last reply 14 Apr 2020, 08:21 Reply Quote 0
                          A Former User @Danal
                          this was a topic way back when, sort of intermingled with permissions on the /opt/dsf/sd folder and /dev/spi nodes and the priority was to get it working first, then revisit.
                          as such i didn't poke in great detail, but as access to the spi node can be solved by group permissions, listening to port 80 (or any port below 1024) sounds like the last hurdle. the easy woraround would be nginx and a reverse proxy which would also ease setting up ssl with sometihng like letsencrypt (even if not exposed to the internet)
                          There are larger issues to deal with first i guess - but I will say the state of the supporting firmware and software has not been clearly communicated following the release of the hardware.
                          I believe I in August said I expected to run RRF2 as the stable version for 6-12 months, and the unfortunate truth of it is that with the limited team developing RRF3 + DSF they need the depend on the community for testing to stand a chance at getting ready for main stream use in such a short timeframe.
                          At the end of the day its up to the user to choose something tried and true, or accept that early adoption comes with a price tag in more than one sense.
                          undefined 2 Replies Last reply 14 Apr 2020, 18:31 Reply Quote 0
                            Okay, sorry I mentioned it.
                            Okay, sorry, won't mention it again! We appreciate all your support!
                            @chas2706 said
                            Rant over!
                            No, really, I'm sorry for suggesting it, I'll never say it again!
                            I agree. It's just taking time to get DSF (which is pretty much brand new) up to speed with the rest of the firmware (painstakingly developed over many years). But without community interest and expertise getting it working, reporting bugs and fixing, it will take much longer. So once again, thank you all for your continued support.
                            undefined undefined 2 Replies Last reply 14 Apr 2020, 18:49 Reply Quote 0
                              chas2706
                              The activity shown on GitHub regards DSF says it all.
                                dc42 administrators @gtj0
                                @gtj0 said in Incident report: RRF 3 RC6 DWC 2.1.0 Lockup during print.:
                                I find that I can switch between standalone and SD mode just by inserting the SD card or not, without removing the SBC cable.
                                  dc42 administrators @chas2706
                                  I was sure I typed "no known bugs" when I composed the message, however I composed it on a smartphone and somehow the "known" got lost.
                                  There are now some known bugs in RRF 3.01-RC6 so we are preparing to release 3.01-RC7 along with updated DSF and DWC. See https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md for the changes to RRF.
                                    Danal @A Former User
                                    @bearer said in Incident report: RRF 3 RC6 DWC 2.1.0 Lockup during print.:
                                    Disconnects in the way that RRF vs DSF are being handled by Duet the company are equally applicable to the 'full' releases.
                                      I withdraw my comment regarding sudo. It diverted attention from the real issue: What is the GCODE to restart the system ?
                                        Danal @droftarts
                                        This completely misses the points being discussed by at least three or four vocal users. It is a powerful indication of the "blind spot" within Duet that causes me to invest the energy in typing these responses:
                                        Any rational person would expect a new major section of software to climb a maturity curve. Totally agree with you on that. And introducing major new architecture and function in V3.x, I believe we all expect it to take time to stabilize. Regardless of where it runs or what tech stack it uses or... it will just take time, testing, feedback, and improvement. Agreed, D'accord.
                                        All of that has nothing to do with the pervasive attitude that RRF and DSF are two separate things. From the viewpoint of the end user they are one thing with defined external interactions (Gcode, Web API, etc).
                                        There are numerous examples of this mis-perception. All of which are seriously complicating the ability to build, deploy, test with the community, upgrade, downgrade, and generally "deal with" the product that fits under the general header of Duet V3. And the folks at Duet appear to be unable to see or acknowledge this is even happening.
                                        When I said "sort of." above, this is what I meant. I don't believe I am ranting anymore; yet there is still more to discuss. I sincerely hope these strong words are read with the intent they are written: To help Duet get better.
                                        ? 1 Reply Last reply 14 Apr 2020, 19:27 Reply Quote 3
                                          garyd9 @droftarts
                                          Sadly, RRF3 (Duet3 standalone) is significantly more functional than RRF3 (Duet3+SBC.) As long as this is the case, people (such as myself) will use (and test) the standalone code and ignore the SBC/DSF/etc.
                                          For example, do a search for threads where people request PanelDue working properly (for file commands) with a SBC attached to the duet. I've seen "it's easy", "will add that soon" and "it's already there, just need the duet to send the command." Yet.. it hasn't happened. Until that "easy", "will be added soon" and "is already there" bit of functionality works, I won't attach the ribbon cable to my RPi4. (I don't have a computer near my printer, and I won't start a print or macro unless I'm standing near the printer.)
                                          How about the conditional gcode stuff? Is that working in SBC mode yet?
                                          The lack of SBC functionality isn't about community interest, reporting bugs, etc. It's about getting DSF up to a more usable state. I'd happily attach my RPi4 to my duet3 board if I could get a similar level of (even untested) functionality - assuming, of course, I'd have reasonable expectations of bugs getting fixed as fast as dc42 fixes RRF3 bugs. (Which is another gripe: There have been long spans of time where DSF has gone untouched while RRF3 has been moving along.)
                                          I just think it's important to get the ordering of "cause" and "result" correct. The lack of community is a result of lack of development. Not the other way around.
                                          Edit: Just to be clear, I'm not really complaining. I'm happy using my duet3 in stand-alone mode while things move along. However, don't imply that I'm part of the reason that DSF (collectively used to mean all the duet s/w running on the SBC) is lagging so far behind RRF3.
                                          20 out of 41
