BLTouch Smart won't accept a reset from error condition
Duet Web Control 2.0.7
Board: Duet Maestro 1.0
Firmware: RepRapFirmware for Duet 2 Maestro 2.05.1 (2020-02-09b1)I'm running the BLTouch Smart on the Z Probe input of the Maestro.
I can't figure out what PORT to use to do a Alarm reset on the BLTouch. (M280 Px S160).
I've tried 0-12 and gave up, always get a "port error".
So, what port should i use?
It's not an end of the world thing but it's annoying to power down to reset it.I searched and searched but no joy.
For the Maestro I believe the servo number is P64, which should match what you have in the deploy and retract probe macros.
Thanks @Phaedrux ! I knew it was one of those "Duh" things. {Sigh}
I'll check it when it's back up, I'm replacing a fan so it's apart.
EDIT: Well, that did the trick! Thanks again!
I'm having the same issue on a Duet Wifi. BL Touch is working fine, but I want to create a macro button for an error reset on the probe.
I have this:
deployprobe.g
; called to deploy a physical Z probe
M280 P3 S10 I1 ; deploy BLTouchso in my macro I tried this:
M280 P3 S160 ; reset BL TouchI don't get an error, but the probe doesn't stop blinking.
Any tips?
I hadn't seen the INVERT option relative to the reset -but that did the trick. Thanks.
