    Endstop do I need a resistor?
    2.3k
    • Danalundefined
      Danal
      @Synapsis said in Endstop do I need a resistor?:
      M574 Z2 S1 M581 Z2 S1 T2
      Hmm, that all looks correct. You say these have LEDs on them, those normally have three wires, one ground, one 3.3V, and one sense... how are those connected?
      • Synapsisundefined
        Synapsis
        Switch 1 Signal pin goes to signal pin on Duet the common goes to signal pin on Switch 2 which the goes to Ground pin on Duet. So I have it going from ground to signal on the board like I read in a post.
        • Danalundefined
          Danal
          Aha! Good old makerbot... long story, let's just fix it to work.
          Step 1: Parallel the switches. All three wires. Like this:
          NOTE DO NOT PLUG THESE IN YET, see step 2.
          Switch A:
          • Ground (black) to ground on Duet (black pin in diagram below)
          • Vin (red) to +3.3V on Duet (middle yellow pin)
          • Green to Duet XYZ stop (grey pin in diagram below)
          Switch B:
          You can "Y" the wires together any way you wish. Crimp in to same connector splice, etc.
          Step2: Modify BOTH endstop boards as follows:
          Clip out the "NC" connection on the physical switch.
          Now you should get what you want. Either switch pressed (or both) will make index 2 go "Yes".
          Synapsisundefined 1 Reply Last reply Reply Quote 1
          • zaptaundefined
            zapta @Synapsis
            ... the past a couple of times the Z-probe wasn't working the bed would crash into the nozzle ...
            On my printer I have mechanism hard stops such that the bed cannot push the nozzle more then a few mm which can absorbed by the flex of the X rods. Saved me a few times.
            • DocTruckerundefined
              DocTrucker
              With these makerbot boards you can remove all of the surface mount components then get a normally closed switch across the outer two connections on the plug.
              The surface mounts can be tricky to remove with a soldering Iron and will likely get destroyed doing so.
                DocTrucker
                With the boards as is there could be additional fault diagnosis on the boards but the added complexity would rarely be used.
                i.e. Open circuit is a fault, close circuit is switch not triggered, the voltage that causes a dim LED is switch triggered.
                Thinking on it further this could be an SPI board to achieve that...
                Edit; could an SPI board be checked regularly for an ok signal?
                • Synapsisundefined
                  Synapsis @Danal
                  @Danal said in Endstop do I need a resistor?:
                  Thanks for the fix but one question will it be a NO or NC because if I cut the NC
                  wouldn't it become a NO?
                  zapta 16 Apr 2020, 06:33
                  I have 2 linear guides on a 20x20 profile so I have no flex what so ever only thing to move it the head mount and head. 🙂 but like you were saved I wasn't saved . 😞
                  DocTrucker 16 Apr 2020, 08:57
                  I had tried with a tester and I have a closed circuit until I would press one of the two switches so thought the board had a internal resistor to detect it as NC.
                  • Synapsisundefined
                    Synapsis
                    OK so I see where I was mislead or better misread. On the Wiki Connecting endstop switches I read
                    "Microswitch
                    This applies to a bare microswitch, not to a microswitch on a board with a LED.
                    this i what i didn't see.
                    Duet WiFi, Duet Ethernet and Duet Maestro: connect the switch between GND and STP/IN. These are the outer 2 pins of the 3-pin connector. Note: this is not the same as on RAMPS."
                      DocTrucker @Synapsis
                      @Synapsis if you clip the leg like picture you will get a normally open switch, which is a poor choice for a limit switch as it can't detect the most likely failure of a wire breaking or plug pulling out. I remove all of the surface mount components and the outer two connections on the plug behave as normally closed, which is what you want for a limit switch or z-probe.
                      Synapsisundefined Danalundefined 3 Replies Last reply Reply Quote 0
                      • Synapsisundefined
                        Synapsis @DocTrucker
                        @DocTrucker said in Endstop do I need a resistor?:
                        Exactly what I thought, as I do want NC. Do you have a photo of how you did it?
                        Thanks for your help.
                        • Danalundefined
                          Danal @DocTrucker
                          No, he won't. The circuit effectively inverts the behavior (note, not logic, behavior).
                          And if he wires in parallel and doesn't clip it, triggering one switch WILL CROWBAR THE OTHER SWITCH, which could potentially damage the board to which they are plugged in.
                          Think of two of these in parallel, with one of them triggered. That combination just connected VCC DIRECTLY to ground.
                          • Danalundefined
                            Danal @DocTrucker
                            This will ALSO work. By removing ALL the components, this is a simple switch again, and you are absolutely correct, the outer two wires (com and nc) are what you want.
                            In fact, I'd remove the switch from the board.
                            AND... In that case the wiring is sequential, not parallel.
                            • Duet GND to outer terminal (doesn't matter which) on switch A
                            • Other outer of switch A to outer on switch B
                            • Other outer of B to TRIG on Duet
                            Forms a big "loop" between Trig and Gnd.
                            • Synapsisundefined
                              Synapsis
                              Thanks Danal and DocTrucker for the help.
                              • Synapsisundefined
                                Synapsis
                                Ok one last question, I hope, end stops now working ok took out the R1 and R2 and it works, question now if I use M581 Z2 S1 T0 C0 this will send a M112 and reset the board if I use T1 I would get a pause (which I want ) but this only works while printing?
                                I didn't want to use a trigger because there maybe a little delay before executing the command.
                                Am i forced to use T0?
                                • Danalundefined
                                  Danal @Synapsis
                                  What is your goal? When homing, the printer will stop itself if it hits either of those endstops.
                                  Do you want it to pause if it hits one while printing? Or something else?
                                  Synapsisundefined 1 Reply Last reply Reply Quote 0
                                    A Former User @Danal
                                    ouch; is that a common schematic for all those endstops with leds?
                                    • Danalundefined
                                      Danal @A Former User
                                      @bearer said in Endstop do I need a resistor?:
                                      Yeah, ouch indeed. I'm glad you see it as well.
                                      AFAIK it is common to anything that has that "Design by MakerBot" in one corner. Including BigTreeTech and several other retail/channel brands. Meaning, VERY common.
                                      • Synapsisundefined
                                        Synapsis @Danal
                                        They are a backup in case during homing the Z-probe for some reason does not work, so I want it to stop the movement of the bed but without having to reset the printer by recycling it off/on for example. There will be one near the two lead screws.
                                        • Danalundefined
                                          Danal @Synapsis
                                          Got it.
                                          During HOMING, it Duet allows both a Probe and Endstop defined on the same axis. I believe (double check) that either one stops the axis. This would mean no triggers or macros needed.
                                          During PRINTING, it would need to be a trigger. They do, by the way, trigger in milliseconds, plenty quick enough to prevent a crash (depending on what the triggered macro does).
                                          There is a bit of a dilemma on "kill it instantly" vs "pause it so it does not require a reset, and can be restarted". Consider the case of a long move. Any form of pause must occur at move boundaries. If this is a long move that hits the switch , there is no correct answer to pause/restart. This has nothing to do with the switches or the triggers or etc. It is literally the nature of G-Code.
                                          • Synapsisundefined
                                            Synapsis @Danal
                                            Ok still looking for the correct info but from what info i have It should work maybe.
                                            Doing a M119 I get
                                            Endstops - X: not stopped, Y: at max stop, Z: not stopped, Z probe: not stopped
                                            So I would think there are two on the Z axis also because i have a M574 Z2 S1 to define it. When I tried homing i triggered the switch but it did not stop the homing the Z probe did as usual.
