    I am erasing duet but which firmware can I use?
    Firmware installation
    1.4k
    • jcv1977undefined
      jcv1977 @A Former User
      @bearer Well there is some progress! Using AP mode works fine now and i can finally see the web control page. But it can't seem to connect to my router nor having an ip assigned even if i set at the freaking router a static one.
      Using macros or manually (using M587 S"MYWIFI" P"MYPASSWORD" I192.168.1.128 the blue light of the esp8266 gets blue, but i can't ping to that IP and i can't get to web control page nothing is displayed. Also in my router 192.168.1.128 is not shown at all and the duet appears with a fixed ip 192.169.1.9 but it can't be ping at and it is not browseable.
      I 've already reset to factory setting the router but i dont understand why that fixed IP is still there?????
        A Former User @jcv1977
        @jcv1977 said in I am erasing duet but which firmware can I use?:
        (using M587 S"...
        lets turn on wifi debugging and see if it gives you any more info (doubt it, but worth a try)
        send M111 S1 P14 to the duet before M552 S1
        you could also perhaps try adding the mac address manually for each IP one at the time?
        arp -s 192.168.1.128  b4-e6-2d-52-ff-37
        ping 192.168.1.128
        arp -d 192.168.1.128
        then try
        arp -s 192.169.1.9  b4-e6-2d-52-ff-37
        ping 192.169.1.9
        arp -d 192.169.1.9
          A Former User
          hang on; is that a typo or the actual address?
          192.168.1.128 vs 192.169.1.9
          if a typo, un-typo my commands above, if not a typo run route print on the computer.
          • jcv1977undefined
            jcv1977
            It was a typo, could not delete ips manually. And the debugging returned:
            Debugging enabled for modules: WiFi(14)
            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15)
            ok
            ok
            ok
            WiFi: mode : sta(b4:e6:2d:52:ff:37)
            WiFi: add if0
            WiFi: wifi evt: 8
            WiFi: scandone
            WiFi: ../src/SocketServer.cpp(353): found network DIRECT-0c-HP M29 LaserJet
            WiFi: ../src/SocketServer.cpp(353): found network NETGEAR64
            WiFi: ../src/SocketServer.cpp(353): found network ATTBCVg3dS
            WiFi: ../src/SocketServer.cpp(353): found network ATTevrXIVS
            WiFi: ../src/SocketServer.cpp(353): found network MYWIFI
            WiFi: ../src/SocketServer.cpp(353): found network 8831B2
            WiFi: ../src/SocketServer.cpp(353): found network NY Giants 2.4
            WiFi: ../src/SocketServer.cpp(353): found network AC4F3D
            WiFi: ../src/SocketServer.cpp(353): found network VIZIOCastDisplay0071
            WiFi: ../src/SocketServer.cpp(353): found network NETGEAR76
            WiFi: ../src/SocketServer.cpp(353): found network NETGEAR50
            WiFi: ../src/SocketServer.cpp(353): found network DIRECT-C5-HP OfficeJet 3830
            WiFi: ../src/SocketServer.cpp(353): found network Area 51
            WiFi: ../src/SocketServer.cpp(353): found network Torresnunez
            WiFi: ../src/SocketServer.cpp(353): found network Bchehade24
            WiFi: ../src/SocketServer.cpp(353): found network NETGEAR78
            WiFi: ../src/SocketServer.cpp(353): found network belkin.fac
            WiFi: ../src/SocketServer.cpp(353): found network belkin.fac.guests
            WiFi: ../src/SocketServer.cpp(353): found network ARLO_VMB_1570254913
            WiFi: sleep enable,type: 2
            WiFi: STUB: dhcp_stop
            WiFi: scandone
            WiFi: state: 0 -> 2 (b0)
            WiFi: state: 2 -> 3 (0)
            WiFi: state: 3 -> 5 (10)
            WiFi: add 0
            WiFi: aid 2
            WiFi: cnt
            WiFi:
            WiFi: connected with MYWIFI, channel 6
            WiFi module is connected to access point MYWIFI, IP address 192.168.0.128
            WiFi: ip:192.168.0.128,mask:0.0.0.0,gw:0.0.0.0
            WiFi: wifi evt: 0
            WiFi: wifi evt: 3
            WiFi: pm open,type:2 0
            It has to be something between the wifi module and the freaking router they just don't like each other.
            I changed the ip also to check but still nothing.
            A Former User? jcv1977undefined 2 Replies Last reply Reply Quote 0
              ? permissions or wrong command? might need to run as admin.
              thats probably food for @dc42 he knows more about RRF than i do about networks ^^
                A Former User
                it be interesting to see the debug for that without I192.168.1.128 (i.e. let the duet (try to?) obtain the dhcp lease) and while you're at that, do run route print from the computer just so we can confirm its all on the up and up.
                • jcv1977undefined
                  jcv1977 @jcv1977
                  @jcv1977 I did run the arp command as admin, and the commands were accepted but the ip was still on the router pool.
                  This is debbugging result with dhcp i just cut a whole lot of Network scan failed :
                  ok
                  ok
                  ok
                  WiFi: state: 5 -> 0 (0)
                  WiFi: rm 0
                  WiFi: pm close 7
                  WiFi: del if0
                  WiFi: usl
                  WiFi: mode : null
                  WiFi: wifi evt: 1
                  WiFi: STA disconnect: 8
                  WiFi: wifi evt: 8
                  WiFi module is idle
                  ok
                  WiFi: add if0
                  WiFi: wifi evt: 8
                  WiFi: scandone
                  WiFi: ../src/SocketServer.cpp(353): found network NETGEAR94
                  WiFi: ../src/SocketServer.cpp(353): found network NETGEAR21
                  WiFi: ../src/SocketServer.cpp(353): found network Internetmine
                  WiFi: ../src/SocketServer.cpp(353): found network ACCA31
                  WiFi: ../src/SocketServer.cpp(353): found network ARRIS-FD86
                  WiFi: scandone
                  WiFi: add 0
                  WiFi: aid 2
                  WiFi: cnt
                  WiFi:
                  WiFi: dhcp client start...
                  WiFi: wifi evt: 0
                  WiFi reported error: Timed out while trying to connect to MYWIFI
                  WiFi module is idle
                  WiFi: rm 0
                  WiFi: pm close 7
                  WiFi: del if0
                  WiFi: usl
                  WiFi: mode : null
                  WiFi: Fatal exception 28(LoadProhibitedCause):
                  WiFi: epc1=0x4000df2f, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000033, depc=0x00000000
                  WiFi:
                  WiFi: Exception (28):
                  WiFi: epc1=0x4000df2f epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000033 depc=0x00000000
                  WiFi:
                  WiFi: ctx: sys
                  WiFi: sp: 3ffffc90 end: 3fffffb0 offset: 01a0
                  WiFi:
                  WiFi: >>>stack>>>
                  WiFi: 3ffffe30:  3ffeface 3fff4d4c 40223f10 40105dd8
                  WiFi: 3ffffe40:  40216def 00000006 00000005 402298d9
                  WiFi: 3ffffe50:  00000033 00000010 40217705 3ffee6bc
                  WiFi: 3ffffe60:  3fff4d4c 00000000 3ffe9ff8 3fff516c
                  WiFi: 3ffffe70:  3fff4d4c 4021762d 3ffee6bc 4020b004
                  WiFi: 3ffffe80:  3ffe9ff8 00000002 00000022 00000000
                  WiFi: 3ffffe90:  3fff4dce 3fff4ec4 00000000 00000000
                  WiFi: 3ffffea0:  3ffe9ff8 3ffe9ff8 00000033 4021957b
                  WiFi: 3ffffeb0:  3ffeedc0 40219174 4020b004 3ffeedc0
                  WiFi: 3ffffec0:  40218cf0 402344e0 3ffee740 00000000
                  WiFi: 3ffffed0:  00000001 00000001 00000000 00000000
                  WiFi: 3ffffee0:  402191af 3ffeeeb8 3ffeeeb8 40106df4
                  WiFi: 3ffffef0:  4021b11c 3ffeeeb8 ffff8000 00000001
                  WiFi: 3fffff00:  3ffee740 4021b0e0 3ffee6bc 00000002
                  WiFi: 3fffff10:  40219164 40219138 3ffee740 00000002
                  WiFi: 3fffff20:  40219103 3ffee6bc 00000002 40106c5e
                  WiFi: 3fffff30:  402196b4 3ffee6bc 3ffee838 4020b004
                  WiFi: 3fffff40:  402190e1 3ffee838 00000003 3ffee838
                  WiFi: 3fffff50:  40218e84 3ffeee78 3ffef5a0 f3ecd39c
                  WiFi: 3fffff60:  60000600 0000010f 00000001 00000000
                  WiFi: 3fffff70:  4022dfa9 3ffef5d4 3ffef5a0 f3ecd39c
                  WiFi: 3fffff80:  4022dfee 3fffdab0 00000000 3fffdcb0
                  WiFi: 3fffff90:  3ffef5b0 3fffdab0 00000000 00000005
                  WiFi: 3fffffa0:  40000f49 40000f49 3fffdab0 40000f49
                  WiFi: <<<stack<<<
                  WiFi module is idle
                  WiFi reported error: no known networks found
                  WiFi module is idle
                  WiFi reported error: network scan failed
                  WiFi module is idle
                  WiFi: ⸮nP|!-1K5⸮К⸮⸮XK!⸮~)Q*!⸮⸮ "pkt⸮E,-⸮@⸮⸮P⸮1%(⸮yh=⸮nzA⸮ )i⸮⸮P1⸮N⸮⸮fP1⸮N⸮R⸮t⸮1Z⸮Q⸮
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi: epc2:0x00000000 epc3:0x00000000 excvaddr:0x00000033 depc:0x00000000
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi: add if0
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                  WiFi: wifi evt: 8
                  WiFi module is idle
                  WiFi module is idle
                  WiFi module is idle
                    arp on the computer won't affect the router, just where the computer will send and IP packet; i.e. trying to force the computer to direct the packets to the duets mac address for either address. bit if ping failed then moot point.
                    would probably need big cheese to evaluate the debug info (or maybe run wireshark if your wifi adapter can do promiscuous mode capture, but few on windows does)
                    jcv1977undefined 1 Reply Last reply Reply Quote 0
                    • jcv1977undefined
                      @bearer said in I am erasing duet but which firmware can I use?:
                      Great!
                      We will wait for him!!!! Thanks Bearer!!!!
                      • jcv1977undefined
                        jcv1977 @dc42
                        @dc42 I think i found it! Evidently there is a bug:
                        https://forum.duet3d.com/topic/15207/duet-wifi-wlan-vs-wpa2-connection-error/8
                        https://forum.duet3d.com/topic/14993/cannot-connect-duet-wifi-to-new-wifi-router
                        @bearer You aked me if its a vodafone and its not, but in one of the post it says its an Arris router and mine is Arris too. I gues this freaking router has something that is not compatible. Just for starters i can't turn off dhcp nor update the router's firmware wich is BS. So i guess by now i'll just use it on AP mode until y buy a proper UNIFI Gear.
