    commissioning a new custom 4'x4'x4' printer..have questions
    My Duet controlled machine
    1.4k
      Phaedrux Moderator @Jim46
      @Jim46 said in commissioning a new custom 4'x4'x4' printer..have questions:
      I'm very new at this.
      And you've jumped right into the deep end to boot!
      It may be easier if you set the rpi aside for the moment and tried to get the Duet 3 setup in standalone mode. Once you have commissioned the machine, you can re-integrate the rpi, by then there will likely be some more stable and fully featured versions available.
      • Jim46undefined
        Jim46
        Hi All,
        thanks for all the comments and advice. I'll see if I can run the Duet3D 6HC on its own. Do I have to install the microSD card to do this. Or, if I have the Duet connected to the router would it be easier to get working?
        Here are the screen shots I hope
        Nope: Error
        Something went wrong while parsing server response.
          Yes, to run the Duet 3 in standalone mode you would need a SD card (formatted as fat32) in the Duet 3 SD card. It would need your config.g and all the other files present. The Duet 3 would be connected to your network via the ethernet port. You would connect to it via the DWC using the duet name or IP address provided by the router.
          For the photos, can you try dragging them onto the forum post window, or even copy pasting them? That may work. Otherwise you may be able to put them on dropbox or google drive and sharing a link to them here.
          • Jim46undefined
            Jim46
            my pic file sizes are half the size limit 4096 kB and yet I am still the error: Something went wrong while parsing server response. I'll try other methods.
              test upload
                Seems to work for me on chrome on a mac. What browser are you using?
                  A Former User @Jim46
                  I get this about 50% of the time lately. Refresh the page and retry works 11 of 10 times in my case. Also using chrome.
                  • Jim46undefined
                    Jim46
                    Lovely test upload
                    I moved to chrome and it worked. The Edge browser didn't work after rebooting.
                    You can see in the middle pic a message on the systems table that the drive is unmounted. Not turned our or worse?
                    Jim
                    • Jim46undefined
                      Jim46
                      Here is something most curious.
                      When RRF Configtool.reprapfirmware.org finishes and generates the system files:
                      bed.g
                      config.g
                      homeall.g
                      homex.g
                      homey.g
                      homez.g
                      pause.g
                      resume.g
                      sleep.g
                      stop.g
                      which in this case are unzipped
                      give this screen with varying files, shown here...
                      Yet, when I send to the PC download in order to load into raspberrypi (DWC), the files are all only 1 kB
                      Is this wrong? if not what should it be?
                      thanks i advance,
                      Jim
                        I think windows is just rounding up to 1KB. Possibly due to size on disk.
                        If you open the files in a text editor, do you see the contents? That's what matters most.
                          dc42 administrators @Jim46
                          Presently, the motors are sitting on my work table, not installed in the printer.
                          I've run M65 H0. then G91. Followed by G1 H2 X20 and Y20 and Z20. And, then M654 H0 S0 followed by G91, then G1 H2 X10, and Y10 and Z10. The microSD card is not installed in the Duet. The RPi4 is connected to the router via Lan Cable.
                          Now movement when directed by the PC or when doing the same on the RPi4 screen. Its a mystery!
                          I presume you mean "No movement". Please send the following commands to check that the drivers are assigned correctly and have the currents set:
                          M584
                          M906
                          M913
                          M92
                          • Jim46undefined
                            Jim46
                            Hi Guys and Gals,
                            After a couple days of tech grimlins having Comcast reset the cable modem and Linksys reset the router, I'm back trying the all the commands on the PC DWC which were recommended. Still no motor movement.
                            Q: I have a RPi4 connected to the Duet3D. THe Pi has its microSD card installed and seems to be working well. Re-reading the Duet3D start-up instructions https://duet3d.dozuki.com/Wiki/SD_Card trying to set up to run Duet3D standalone to see if that works to get the motors to respond.
                            BTW, the DWC (raspberrypi) screen on the PC continues to say: The following axes are not homed: X, Y, Z.
                            Ok, now what as I thought the codes sent stepped past the Home requirement sent my motors are just sitting on my desk?
                            as always your help is deeply appreciated.
                            Jim
                            • Jim46undefined
                              Jim46
                              Oh, the SD card instructions seem to say one needs to put the Duet3D SD card in the RPi4 when its a connected setup. Is this true? If so, then could it be why the motors don't respond to the commands?
                                if you're refering to using the Duet 3 with the Raspberry Pi and Duet Software Framework, then yes, SD card goes in the Raspberry Pi and only in the Raspberry Pi.
                                however, something doesn't add up, because if the Pi is working it already has an SD card it it with the operating system for the Pi. The files that goes on the SD card in stand alone mode then needs to be put into /opt/dsf/sd on the SD card that also has the Pi operating sytem (where /opt/dsd/sd becomes a virtual SD card that DSF present to the Duet 3).
                                • Jim46undefined
                                  Jim46
                                  HI,
                                  the SD card in the Pi4 came with it and was set up according the the https://www.raspberrypi.org/forums/. It is still in the Pi. So, the question boils down to is it required when Duet3 and Pi4 are connected to use the Duet3 SD card in the Pi? So, I don't know it the Duet Software Framework is on it. How to find out?
                                  Duet3 standalone operation: it seems clear that you use the Duet3D SD card. I now have to figure out how to set up the Duet3 SD card.
                                  cheers
                                    If you intend to use the Duet in standaloen mode, disconnect the pi. You can leave the SD card in the pi and use a seperate SD card for the Duet standalone config. That way you can go back to the connected Pi more easily in the future.
                                    To prepare an SD card for the Duet, see here: https://duet3d.dozuki.com/Wiki/SD_Card
                                    • Jim46undefined
                                      Jim46
                                      Oh one other thing. I continue to get a G28 error about "Failed to enable endstops"
                                      I just trying to test run the motors w/o having endstops.
                                      Doing something wrong?
                                      • Jim46undefined
                                        Jim46
                                        Phaedrux, that was exactly what I wanted to know. Keep the Pi SD card in the Pi even when connect to the Duet. If I want (which I do), to run the Duet standalone then I use the SD card that came with the Duet. I have a separate high speed card reader/writer connect to PC USB port which is I'll try to set up the Duet card. Is this okay?
                                          Sure, as long as it's formatted as described in the SD card link in my last post, and you have the Pi and the Duet ribbon cable disconnected.
                                            A Former User @Phaedrux
                                            you're not making it easy to help you; if you don't intend to use the rPi4 put it in a drawer and stop talking about it.
