    Simple question: How to read from IO
    1.7k
    • JBiscundefined
      JBisc @dc42
      @dc42 Thanks: I will try
      M409 K"sensors.inputs"
      Maybe some feedback: Does it make sense to include a small example in the gcode documentation, that I will be the last person who is asking? 🙂 Normally the people search for "read io"/ "read voltage" / "get sensor value" and its hard for them/me to find something in the documentation.
      My Setup: Duet 3 MB6HC Main Board with attached RPI
        dc42 administrators @JBisc
        @JBisc, you will need to create a GPIO port attached to your chosen pin using M950 with the J option, before you can see it in sensors.inputs.
        Yes an example would help. If you tell us what you are trying to achieve, we could use that as an example.
        JBiscundefined 2 Replies Last reply Reply Quote 0
        • JBiscundefined
          JBisc @dc42
          @dc42 I believe that my scenario is not a very common one. I am working on a complex algorithm to measure the 2D/3D-geometry of my workpiece. The algorithm is to complex to implement it in gcode, therefor I implement a supersiving software layer in python (think about a python-gcode wrapper) which calculates the algorithm. Then, the supervising software optimize the 3dprinter.
          • Danalundefined
            Danal
            Curious side question: Where are you running the Python?
            JBiscundefined 1 Reply Last reply Reply Quote 1
            • jens55undefined
              jens55
              Visions of automated probing are running through my head .... could be as simple as setting resolution for x and y, setting a range of x and y and telling the printer to measure every point. Might be painfully slow but hey, it could do it. Put every value into a spreadsheet which can then be imported into Fusion360 and presto, the beginnings of a model. Obviously some hand work is required.
              As a side question, just exactly how accurate is a 3D scanned object? Are the scanned objects dimensionally accurate or could manually probing increase accuracy?
              In any case, having a probing tool head for quality control of a printed object might be interesting.
              • JBiscundefined
                JBisc @Danal
                @Danal currently on the RPI. Ohhhh Danal, you are the author of the wrapper which I use. Great to meet you here! Thanks for your amazing work. I started with forking your project (https://github.com/DanalEstes/PythonDSF)
                • Danalundefined
                  Danal @JBisc
                  @JBisc said in Simple question: How to read from IO:
                  There's another choice now as well: DuetWebAPI. Requires network connectivity to the printer (can, but not required to, run on the attached Pi) and also abstracts away V2 to V3 differences.
                  • JBiscundefined
                    JBisc @dc42
                    @dc42 said in Simple question: How to read from IO:
                    If I use M950 by
                    M950 J4 C"io4.in"
                    I can get only a ditgital input by calling
                    which is not what i want.
                    If I define my sensor by
                    M308 S4 P"io4.in" Y"linear-analog" A"MySensor" F0
                    I don't know a method to return my analog sensor value (to the RPI). Does somebody has an idea?
                    • JBiscundefined
                      JBisc
                      Ok it seems to be easy:
                      just call
                      M308 S4
                      to get the sensor value.
                      • Danalundefined
                        Danal @JBisc
                        When you say "return to the Pi", what would happen? Push? Pull? what code reads it or responds or...
                        What do you want to happen?
                        • JBiscundefined
                          JBisc
                          I implemented in the following way now:
                          My python programm on the RPI sends
                          M308 S4
                          and i parse the response (on the RPI)
                          Sensor 4 (MySensor) type Linear analog using pin io4.in, reading 3.8, last error: success, unfiltered, range 0.0 to 1.0
                            You could also get it by using M409 to request that value from the object model.
                            JBiscundefined 1 Reply Last reply Reply Quote 0
                            • JBiscundefined
                              JBisc @dc42
                              M409
                              I remember that you posted in another post that analog values are not included in the current object model
                                M409
                                Raw analog inputs are not included, but the readings from configured sensors are:
                                20/04/2020, 09:55:19 	m409 k"sensors.analog[0].lastReading"
                                {"key":"sensors.analog[0].lastReading","flags":"","result":21.5}
                                • pouic1313undefined pouic1313 referenced this topic
