    Simple question: How to read from IO
    1.8k
    • JBiscundefined
      JBisc
      Sorry for the stupid question (neither google nor the forum search helped me):
      I could not find a Gcode command to read one of my IO? How is it possible? I would assume that there is a gcode command witch returns a json...
      For Marlin I found M43, but for duet it seem to be different....
      My Setup: Duet 3 MB6HC Main Board with attached RPI
      • JBiscundefined
        JBisc
        Ok it seems to be easy:
        just call
        M308 S4
        to get the sensor value.
          Use any or all of:
          • M577 to wait for an input pin to be in a particular state
          • M581 (and possibly M582) to cause some action to take place when the state of an input pin changes
          • In RRF 3.01, M409 or conditional GCode to query the value of sensors.inputs[n] for some n
          JBiscundefined 1 Reply Last reply Reply Quote 1
          • JBiscundefined
            JBisc @dc42
            @dc42 Thanks: I will try
            M409 K"sensors.inputs"
            Maybe some feedback: Does it make sense to include a small example in the gcode documentation, that I will be the last person who is asking? 🙂 Normally the people search for "read io"/ "read voltage" / "get sensor value" and its hard for them/me to find something in the documentation.
              dc42 administrators @JBisc
              @JBisc, you will need to create a GPIO port attached to your chosen pin using M950 with the J option, before you can see it in sensors.inputs.
              Yes an example would help. If you tell us what you are trying to achieve, we could use that as an example.
              JBiscundefined 2 Replies Last reply Reply Quote 0
              • JBiscundefined
                JBisc @dc42
                @dc42 I believe that my scenario is not a very common one. I am working on a complex algorithm to measure the 2D/3D-geometry of my workpiece. The algorithm is to complex to implement it in gcode, therefor I implement a supersiving software layer in python (think about a python-gcode wrapper) which calculates the algorithm. Then, the supervising software optimize the 3dprinter.
                • Danalundefined
                  Danal
                  Curious side question: Where are you running the Python?
                  • jens55undefined
                    jens55
                    Visions of automated probing are running through my head .... could be as simple as setting resolution for x and y, setting a range of x and y and telling the printer to measure every point. Might be painfully slow but hey, it could do it. Put every value into a spreadsheet which can then be imported into Fusion360 and presto, the beginnings of a model. Obviously some hand work is required.
                    As a side question, just exactly how accurate is a 3D scanned object? Are the scanned objects dimensionally accurate or could manually probing increase accuracy?
                    In any case, having a probing tool head for quality control of a printed object might be interesting.
                    • JBiscundefined
                      JBisc @Danal
                      @Danal currently on the RPI. Ohhhh Danal, you are the author of the wrapper which I use. Great to meet you here! Thanks for your amazing work. I started with forking your project (https://github.com/DanalEstes/PythonDSF)
                      • Danalundefined
                        Danal @JBisc
                        @JBisc said in Simple question: How to read from IO:
                        There's another choice now as well: DuetWebAPI. Requires network connectivity to the printer (can, but not required to, run on the attached Pi) and also abstracts away V2 to V3 differences.
                        • JBiscundefined
                          JBisc @dc42
                          @dc42 said in Simple question: How to read from IO:
                          If I use M950 by
                          M950 J4 C"io4.in"
                          I can get only a ditgital input by calling
                          which is not what i want.
                          If I define my sensor by
                          M308 S4 P"io4.in" Y"linear-analog" A"MySensor" F0
                          I don't know a method to return my analog sensor value (to the RPI). Does somebody has an idea?
                          • JBiscundefined
                            JBisc
                            just call
                            M308 S4
                            • Danalundefined
                              Danal @JBisc
                              When you say "return to the Pi", what would happen? Push? Pull? what code reads it or responds or...
                              What do you want to happen?
                              • JBiscundefined
                                JBisc
                                I implemented in the following way now:
                                My python programm on the RPI sends
                                M308 S4
                                and i parse the response (on the RPI)
                                Sensor 4 (MySensor) type Linear analog using pin io4.in, reading 3.8, last error: success, unfiltered, range 0.0 to 1.0
                                  You could also get it by using M409 to request that value from the object model.
                                  JBiscundefined 1 Reply Last reply Reply Quote 0
                                  • JBiscundefined
                                    JBisc @dc42
                                    M409
                                    I remember that you posted in another post that analog values are not included in the current object model
                                      M409
                                      Raw analog inputs are not included, but the readings from configured sensors are:
                                      20/04/2020, 09:55:19 	m409 k"sensors.analog[0].lastReading"
                                      {"key":"sensors.analog[0].lastReading","flags":"","result":21.5}
                                      • pouic1313undefined pouic1313 referenced this topic
