    Duet3 MB6HC Revision 1.0 firmware 3.0 beta12 can’t update
    Firmware installation
    451
    • Jimmykcundefined
      Jimmykc
      I want to use Duet3 as a standalone board. (No Pi)
      I want to use M997 to update firmware by USB.
      I download Duet3Firmware_MB6HC.bin and Duet3_SDiap_MB6HC.bin from the link.
      https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC6
      I put the bin files in \\www folder.
      Then I key M39 and the duet3 have response. (check SD card)
      I key M115 to check the firmware version. (3.0beta12)
      I key M997 S0 and the duet3 have response.
      Error: In-application programming binary "Duet3iap_sd_MB6HC.bin" not found<LF>ok<LF>
      So I change the “Duet3_SDiap_MB6HC.bin” file name to “Duet3iap_sd_MB6HC.bin”.
      Then I key M997 S0 again. The duet3 only restart.
      The duet3 show 3.0beta12, so it didn’t update.
      I show the testing process below
      A Former User? ChrisPundefined 2 Replies Last reply Reply Quote 0
        A Former User @Jimmykc
        @Jimmykc said in Duet3 MB6HC Revision 1.0 firmware 3.0 beta12 can’t update:
        you probably need to find the correct iap binary from the 3.0 release
        • ChrisPundefined
          ChrisP @Jimmykc
          The update binaries need to go in the sys folder.
          Jimmykcundefined 1 Reply Last reply Reply Quote 0
            Upgrade to 3.0 release first using the zip file, then you should be able to upgrade from there to 3.01-RC9.
            • Jimmykcundefined
              Jimmykc @ChrisP
              @ChrisP Thanks for your help. I make a mistake for my description, in fact I put the files in \\sys folder.
              • Jimmykcundefined
                Jimmykc @dc42
                @dc42 Thanks for your help. I follow your suggestion and download the Duet2and3Firmware-3.0.zip from the link
                My duet web control is 2.0.4.
                I update system files by DWC.
                The duet3 have response and show below.
                I update system files again.
                The duet3 show the CRC check error is random.
                I keep trying to update system files until the duet3 have no error message.
                The duet3 show 3.0beta12, and it didn’t update.
                • singhm29undefined
                  singhm29
                  I'm also pretty perplexed by this..I was able to update the DWC interface by uploading directly through DWC but when I try to update the Duet3 firmware it fails in a similar manner.
                  I tried using S3D as another method and got this
                  READ: Error: In-application programming binary "Duet3iap_sd_MB6HC.bin" not found
                  I checked the naming of that additional file and noticed it was
                  "Duet3_SDiap_MB6HC.bin"
                  NOT
                  So I tried renaming this file on the SD card and then trying through DWC to update and then again through S3D. No luck.
                  Don't mean to hijack the thread but our issues seem the same. I tried updating first to 3.0 and then to the latest RC but still had no luck.
                    @Jimmykc, the Ethernet interface ws unreliable in early versions of RRF 3.0beta for Duet 3, which explains the CRC errors. However, if the two binary files have now been uploaded into /sys on your Duet, you should be able to run M997 to install version 3.0. If that fails, you can install version 3.0 over USB using Bossa.
                      jay_s_uk
                      IIRC, somewhere around beta 12, a number of users had issues updating and the only action was to bossa the board.
                      I suggest following this guide
                      https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
                      • Jimmykcundefined
                        Jimmykc
                        @jay_s_uk @dc42 Thank you, I can install the last version 3.01-RC9 over USB using Bossa.
                        • singhm29undefined
                          singhm29
                          All good here as well. Thanks for clarifying everyone!
