    Height Map recall
    1.0k
      Firmware and DWC version?
      3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
      • 3DPrintingWorldundefined
        3DPrintingWorld @Phaedrux
        2.0.4
          Please test 3.01-RC9 and DWC 2.1.4
          https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC9
            Yeah, but do you not know the answer to my original questions?
            • chrishammundefined
              chrishamm administrators
              There are a couple of indicators:
              1. When you click on "Compensation & Calibration", the popup menu displays the current compensation type.
              2. If that shows that you are using a heightmap, you can see on the Heightmap page what the loaded heightmap looks like (provided you are using 3.01-RC7 or newer)
              Duet software engineer
              • nickpgreundefined
                nickpgre
                @3DPrintingWorld said in Height Map recall:
                ay to verify what height map is being used if one is called before a print?
                I am coming with the same question. On duet wifi 2, I upgraded to 3.01-RC9 and Duet Web Control 2.1.4 but loading the height map either with G29 S1 or through the Dashboard tab -> Compensastion & Calibration -> Load saved height map from SD Card the "Disable Mesh compensation" remains disabled.
                I see in the diagnostics the following even after I Execute G29 S1 or G29 S2
                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                Is this an issue with my configuration, some bug or anything else? I can see the height map from the height map tab but cannot tell whenever it is active or not even if i turn debugging on/off.
                  chrishamm administrators @nickpgre
                  @nickpgre I can confirm that, it will be fixed in the next DWC version.
                  nickpgreundefined 1 Reply Last reply Reply Quote 1
                  • nickpgreundefined
                    nickpgre @chrishamm
                    Thanks @chrishamm !
                    The only way to figure if it could be loaded, was to load the height map before homing so to get the warning message!
                    Have a good day!
                    • gtj0undefined
                      gtj0 @chrishamm
                      @chrishamm said in Height Map recall:
                      Actually, you only see what's in the file "heightmap.csv" not necessarily what was loaded, at least by my testing.
                      If I start with no heightmap loaded and no heightmap.csv, DWC shows "File 0:/sys/heightmap.csv not found".
                      If I do a G29 S1 P"heightmap-hot.csv", the DWC will automatically update and show the map but if I refresh, it goes back to "File 0:/sys/heightmap.csv not found".
                      I also note that move.compensation.file is always NULL in the DSF OM and missing altogether in the RRF OM.
                      garyd9undefined 1 Reply Last reply Reply Quote 1
                      • garyd9undefined
                        garyd9 @gtj0
                        @gtj0 said in Height Map recall:
                        On RRF 3.01-RC9+1 (duet3 standalone):
                        4/22/2020, 10:15:26 PM	m409 K"move.compensation.file"
                        {"key":"move.compensation.file","flags":"","result":"0:/sys/heightmap.csv"}
                        ; after running : G29 S1 P"another_map.csv"
                        4/22/2020, 10:19:23 PM	m409 K"move.compensation.file"
                        {"key":"move.compensation.file","flags":"","result":"0:/sys/another_map.csv"}
                        • gtj0undefined
                          gtj0 @garyd9
                          @garyd9 said in Height Map recall:
                          Well, that's quite odd...
                          M115
                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9+1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-22b1
                          G29 S1 P"heightmap.csv"
                          Height map loaded from file heightmap.csv
                          {"key":"move.compensation.file","flags":"","result":null}
                          Height map loaded from file heightmap-hot.csv
                          OK maybe it's just me.
                          garyd9undefined 1 Reply Last reply Reply Quote 0
                          • garyd9undefined
                            garyd9 @gtj0
                            @gtj0
                            SBC vs standalone?
                            No idea, but seems like a bug. @dc42?
                            • gtj0undefined
                              gtj0 @garyd9
                              @gtj0
                              SBC vs standalone?
                              Maybe. I'll create a separate thread for it.
                                3DPrintingWorld
                                To update DWC to 2.1.5 do I not just upload the .zip like I do for RRF? After I do this the status on the general tab does not change from 2.0.4.
                                  Phaedrux Moderator @3DPrintingWorld
                                  Yes, you should be able to. You can also do it manually by pulling the SD card and using a PC to extract the zip file into the /www folder.
                                  Try uploading DWC version 2.0.7 first. Maybe it's too out of sync.
                                    3DPrintingWorld
                                    Thanks! Updated RRF and DWC to the latest RC and the height map is now displaying properly.
