Thermistor documenation wrong, or?
Been working on configuring my Duet WiFi board.
While doing so, I am setting up thermistor for my genuine E3Dv6 hotend.
In the Duet documentation source1, it reads:
The Semitec 104GT-2 thermistor supplied with the E3Dv6 hot end has a quoted B value of 4267, but the actual value over 25C to 220C is 4388. For greater accuracy, use a C parameter as well.
I dug some for more information on the E3D site, where they even have a section to setup on RepRapFirmware.
There are 2 items of interest here, where the first is the B Value:For firmware versions 1.16 and earlier, set the B parameter (beta value) to 4388. This value gives better accuracy at typical printing temperatures in the range 190 to 250C than the B value of 4267 quoted in the datasheet…...... For firmware versions 1.17 and later, set the B parameter to 4725
It actually means E3D is telling us the same thing: to use 4388 as B… but only for old firmware. E3D says we should set B at 4725 when using new firmware
.. does it mean Duets documentation on this is no longer valid?[h]Second thing is C and the main thing for me to post:[/h]
For firmware versions 1.17 and later, set the B parameter to 4725 and the C parameter to 7.06e-8.
I have tried it and C7.05e-8 does not result in an error, but is it right, or?
edited to correct a typo, which DC42 pointed out.
That section of the E3D wiki is correct. I wrote it. Which Duet documentation page is out of date?
The parameter C7.06e-8 (with the decimal point, which you left out) is correct.
David,
I was looking at this today. I think https://duet3d.com/wiki/Connecting_thermistors is the page in question. It mentions the 4388 value but doesn't mention the 1.17 firmware variation that I can see.
Out of interest, what sort of temp difference would you expect from B4388 vs B4725 C7.06e-8? Is it significant?
David
David,
David
That was sort of what I was asking (first part)
Ok, so it's a thing with the e-8? just looked so odd!
You can write C0.0000000706 instead but beware of using the wrong number of zeros.
Thanks for the link to the out-of-date page, which I have now corrected.
The improvement in accuracy is when you use the C parameter is zero at around 220C and AFAIR a few degrees at 300C and 140C.
…...........Ok, so it's a thing with the e-8? just looked so odd!
Scientific notation. It's another way of saying "times ten to the power of minus eight".
Glad to be able to finally help some and not just ask questions
I'd advice to write that the C7.06e-8 is not a typo and maybe put in what it means in your wiki page -
Cheers dintid I have added a quick line to the wiki page:
